JumboJack for president!
Trade: Hilti walking billboard
Severed Main Electrical Line
Can someone help me on this one. I have a call into my electrician, but i haven't talked to him yet. The main electrical line at the service panel in the basement has been cut at a property. I need to repair the severed line. How much would something like this cost? Thanks
Trade: electrician Phoenix AZ
Re: Severed Main Electrical Line
Depends on how much time and material is involved
![]() Seriously, how do you suppose anyone could give an answer with so few details?
Just because it's within code doesn't make it safe. Just because it's against code doesn't make it unsafe. |
#3 | |
Re: Severed Main Electrical LineQuote:
If i asked you to install 100 feet of 12/2 wire i would approx know what you would charge, but this is as simple of a question as it gets. |
Re: Severed Main Electrical Line |
Trade: Licensed Electrician
What gauge service? What kind of cable exactly? Is it accessible? Is it inside the exterior wall where it was cut? Is in in pipe that some jackleg backed his truck into? How exactly was it severed? Has the power been turned off at the pole?
Still think you described the situation well enough? |
Main wire coming in from house to panel is severed about 2 feet above panel feed. Wire must be what...220 size? Would you need to re-run wire from outside meter inside to panel? Forget about price then. Just want to get an idea of difficulty. Its not like updating service is it?
#7 | ||
In the first post you told me nothing except its function ![]() Quote:
Well there you go.
If he has access all the way to the panel it will probably take him a half day and maybe a hundred or two in materials.
#9 | |
Grey thick wire, yes it is accessible. Runs inside basement. The reason it is cut...someone was evicted from residence and they thought it would be funny to cut wire entering home. I think the power is on to house. Talk about electrical hazard |
Fentoozler
Over head...underground
Which side of meter....yours or the power company etc
#13 | |
Fentoozler
Talk about? Call someone now. Add the bill to the suit you are already filling against the tenants. Money is no object when you will be using someone else's money
#15 | |
220/221, whatever it takes.
Al Smith
how did the tenant not get killed without pulling the meter? Was there a disconnect outside?
electrical company must have cut power due to non payment. Tenant then cut the lines. Once bank took possession of home the power was transferred and that is when i found that the line had been severed. The electrical company thought nothing of it, because it is inside the home.
#18 | |
Fentoozler
So you are the new owner? The electric company has no authority - nor concern - with what happens on your side of the meter.
#19 |
Service & Repairs
Trade: Electrician
$5800!
#20 |
No, im not the new owner. i was contacted by lender to have the problem corrected.
| Electrical License in PA | ABLE1 | Low Voltage | 29 | 10-25-2010 12:20 PM |
| Main v.s. Load 2 Gang Meter | Bubbles | Electrical | 5 | 10-05-2007 08:05 PM |
| Main line clean out | chris n | Plumbing | 23 | 08-29-2007 10:21 AM |
| Main waste line cleanout plug | FP Home improv | Plumbing | 3 | 10-22-2006 08:49 AM |
