Service Entrance
Old 01-10-2007, 12:00 PM   #1
Tom M's Avatar
Service Entrance
Electricans I need Help. I recently did a remodel that replaced all the exterior siding. The new material thickness did not fill the space from the previous layers. The local building inspector failed the job for not reattatching the meter to the house. The meter is recessed in the wall cavity and the exterior meter is directly opposite the panel. I cant screw from the outside because I will go into the panel inside---usually the meter would be piped with hard conduit into the panel inside but is not. The utility company wants me to remove the globe and fasten the box and so does the inspector. I have never heard of this before. This is dangerous I am not an electrican number one and number two what utility company want people removing there tag and tapering around their equipment. What should I do? I advised the customer to call an electrican but he keeps requesting me to do it.
Tom M is offline
Old 01-10-2007, 01:13 PM   #2
GregS's Avatar
Trade: Low Voltage
Re: Service Entrance
Why does the customer keep requesting that you do it as opposed to a licensed electrician? Do they think it will cost more?
Why not call an electrician yourself and subcontract it and bill the customer?
GregS is offline
Old 01-10-2007, 01:20 PM   #3
macmikeman's Avatar
Trade: Master Electrican, Electrical Contractor
Do not attempt to do this. Get an electrician.
macmikeman is offline
Old 01-10-2007, 01:48 PM   #4
Tom M's Avatar
I have not done this yet. It is ridiculous have you ever heard of a utility company doing this. I advised the customer 6 months ago when the job was completed to get an electrican. I guess he thinks this is my responsbilty since the inspector returned 3 times to check.
Tom M is offline
Old 01-10-2007, 06:04 PM   #5
mdshunk's Avatar
Have you been paid in full on this job? Will this go against your bond (if any) if you don't attach it? In any event, this is certainly the realm of the electrician's work, as others have said. It seems like, in your case, it is unclear who exactly will be paying that electrician. What you're describing is normally only a 15 minute job, but it can take much administrative hassle to get things arranged to actually do the work.
mdshunk is offline
Old 01-10-2007, 07:52 PM   #6
Union Electrician
Sparky Joe's Avatar
Trade: Inside Wireman
Power company won't do anything to a persons house(period) even run 4 screws into the wall, for liability issues. And in all honesty; it's not their problem and they are a completely different breed from construction electricians.
So I'm assuming you removed the meter socket from the house to remove the siding? Did you notice how the meter can was attached before? Is there any reason why the meter can't be pushed against the house(you mention there was no conduit between meter and panel). Can you do any sort of "bump out" to allow the meter to be attached the same distance from the wall as it was before and to spread the mounting points far enough away from the panel on the opposite side and also to allow you to do it your self?
Sparky Joe is offline
Old 01-10-2007, 08:59 PM   #7
Speedy Petey's Avatar
Trade: Electrical
I am waiting for meter pans with external mounting lugs so this does not have to happen EVERY time!
Why has no one (manufacturers) thought of this yet????
Speedy Petey is online now
Old 01-10-2007, 09:32 PM   #8
Union Electrician
Sparky Joe's Avatar
I'm not following Pete......explain?
Old 01-10-2007, 10:02 PM   #9
mdshunk's Avatar
Many of the 60 amp round meter cans had external mounting tabs. Not since then, however, and that is a shame.
mdshunk is offline
Old 01-10-2007, 11:12 PM   #10
Trade: Electrical
You know. Tabs sticking out from the sides of a meter pan to mount the box. Like most weatherproof boxes have, only on a larger scale.
Old 01-10-2007, 11:57 PM   #11
Union Electrician
Sparky Joe's Avatar
huh
I'm sorry, I'm just not around the stuff.
Perhaps a picture for a moron?
Old 01-11-2007, 07:07 AM   #12
Trade: Electrical
OK Mr. Industrial, this is my last try.
Picture an iron FS box with external mounting lugs/tabs. Meaning no screws through the inside back of the box.
Old 01-11-2007, 08:34 AM   #13
Tom M's Avatar
Sparky,I did not have to remove the screws prior because there wasnt any. The box sat at an angle or a thick layer of wood shakes that have been since removed. The straps were on the utlity wires so to attach this box flush against the haouse again I would need to shorten this wire. I couldn't repoisition the meter to take up the slack because the eave was tight against the top of it. The cable was brought to the house from the front and wrapped around the house dowm the fascia board. I'll figuire it out. Thanks guys
Tom M is offline
Old 01-11-2007, 10:30 AM   #14
Flying Monkey's Avatar
Trade: Residential Building Inspector
My first thought is to have the utility co. come out and pull the meter at 11:50. They go to lunch. You screw in the pedestal. They return from lunch and replace the meter.
I don't know of ANY electrician who will pull that meter. It should be utilities responsibility. It will cost a bit, but be done in an hour.
Flying Monkey is offline
Old 01-11-2007, 12:28 PM   #15
Philadelphia electrician
RobertWilber's Avatar
Trade: Electrical contractor
around here we pull the meters all the time, PECo will come remove a barrel lock if there is one but we have to pull the meter.
You don't want to go screwing around in a hot meter can!
I would cut the taps and reterminate the hots when I was done if I had to remount a can. [we do taps here as well]
RobertWilber is offline
Old 01-11-2007, 08:55 PM   #16
Union Electrician
Sparky Joe's Avatar
Oh I get it now, screw holes outside of the box.
And does anyone actually use those little tab things that come with a weatherproof box?
I tried a few times but the screws always stripped out of that cheap tin when trying to attach the tabs to the box.
Old 01-11-2007, 08:58 PM   #17
Trade: Electrical
Yes, true. I was just using that as an illustration.
Old 01-11-2007, 09:10 PM   #18
Union Electrician
Sparky Joe's Avatar
You'd think manufacturers would realize their product didn't work and do it differently.
When I drill holes in the box I then have to caulk along the top to keep it waterproof.
If there were a better/simpler system I'd definetely go with that
Old 01-13-2007, 06:00 PM   #19
GC / Remodeler
dshcontracting's Avatar
Trade: General Contractor/Remodeler
Send a message via AIM to dshcontracting
As RobertWilber said, Peco around here makes you hook the lines up to your weatherhead if you do a service upgrade. If you do a siding job, you can yank the meter too. they used to care about meter tags way more in the past, nowadays, they use cellnet meters that use IP technology over the power lines. They can turn the power off to a single house with the push of a button, they also know when you pull the meter! I do a decent amount of electrical when we do additions here, and I'm still not a fan of hooking up live pieces of 4 gauge copper!
dshcontracting is offline
Service Entrance Size GregS Electrical Picture Post 17 02-15-2009 08:47 AM
Service Magic's new service Grumpy Marketing & Sales 12 08-02-2008 04:31 PM
Can anyone make any sense out of this? Teetorbilt Technology 24 04-16-2007 12:21 PM
Service upgrade question ATS Electrical 17 09-05-2006 09:48 PM
May offer a New Service ?? tzzzz216 General Discussion 15 07-16-2006 12:00 PM
