Service Change?
Old 02-26-2007, 07:11 AM   #1
Liquid Force's Avatar
Trade: Electric
Service Change?
When you're doing a service change that is going to require the replacement of the feeders from the meter to the service main, does the utility company have to come out and remove the meter, can they give the homeowner the ok to do that themselves, or can they just open the circuit in the meter without actually removing the meter?
A friend of mine just moved into a house with a main disconnect next to the meter outside, and apparently at some point some bozo added a 16spc MLO "sub-panel" for pool equip and an AC condener unit next to the disconnect and just shoved #6's under the load side lugs of the 200a main breaker, along with the 2/0's going into the house. So what we want to do is get the power shut off, pull the "sub-panel" and disconnect off, and put a weatherproof MCB panel up(does it need to be 42 circuit?) next to the meter.
Can he as the homeowner call the power company and have them remove the meter and then reinstall it when he's ready, and does he need to pull a permit with the county first? Basicaly what are his rights and abilities as homeowner?
Liquid Force is offline
Old 02-26-2007, 10:27 AM   #2
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Re: Service Change?
It depends on what state we're talking about since local codes vary from state-to-state. Around here the POCO will charge at least $195 p/ hour just to pull out the meter but they'll come do it if you wish. I'm sure you'd like to do this work for your friend yourself but it if you're asking questions about pulling a meter I feel you have no business in attempting to do a service upgrade. Contact a licensed electrician.
Just my $0.02
Magnettica is offline
Old 02-28-2007, 08:23 AM   #3
Philadelphia electrician
RobertWilber's Avatar
Trade: Electrical contractor
Re: Service Change?
This is the second question you have asked that indicates you aren't in the trade. Please use the DIY forums
[this isn't a DIY project]
RobertWilber is offline
Old 02-28-2007, 04:39 PM   #4
Administrator
Nathan's Avatar
Trade: Admin
Re: Service Change?
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractor's to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.diychatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
Nathan
"He is no fool who gives what he cannot keep to gain that which he cannot lose." - Jim Elliot
Nathan is offline
Service Magic's new service Grumpy Marketing & Sales 12 08-02-2008 04:31 PM
Can anyone make any sense out of this? Teetorbilt Technology 24 04-16-2007 12:21 PM
After service a change, what is best way for temp. connect of power RandyMc Electrical 14 10-03-2006 06:58 AM
service change code updates?? marxie Electrical 6 08-06-2006 11:20 PM
May offer a New Service ?? tzzzz216 General Discussion 15 07-16-2006 12:00 PM
