Security Lights Shorting Circuit
Old 11-17-2009, 06:48 PM   #1
72chevy4x4's Avatar
I just finished a crawlspace remediation and got a call that the sump pumps may be have tripped a breaker....so I checked it out tonight and when resetting the breaker it buzzes then within approximately one second it trips. The onsite maintenance guy said the power supply in the high power exterior building lighting sometimes shorts out.
question: being as they look like a 175w sodium wall mount, will the power supply's some times short out (high current draw)? Don't worry, I don't fix this kind of stuff, but I thought when they go bad you'll have an open or non-igniting light; what is the likely cause?
72chevy4x4 is offline
Old 11-17-2009, 07:00 PM   #2
rselectric1's Avatar
Re: Security Lights Shorting Circuit
A sump pump should be on a dedicated circuit. Are the lights on the same circuit as the pump?
rselectric1 is online now
Old 11-17-2009, 07:25 PM   #3
72chevy4x4's Avatar
sorry I didn't clarify-the sump pumps were disconnected from the outlet (nothing is plugged in) which they thought was tripping the circuit-but I doubt the outlets in the crawlspace were part of the security light circuit.
Old 11-17-2009, 07:41 PM   #4
Electrosexual
Zinsco's Avatar
Trade: Electrical Contractor
Yeah, they can go bad. I'd try disconnecting one at a time to see if one is bad...
Zinsco is offline
Old 11-17-2009, 07:49 PM   #5
KennMacMoragh's Avatar
Trade: Repair/Remodel
Send a message via MSN to KennMacMoragh
Doesn't a short cause the breaker to trip in more like 1/1000th of a second? If it takes a second before tripping, that indicates an overloaded circuit doesn't it? Not a short. I saw a similar problem once before with outdoor lights, whenever some of the bulbs were about ready to die, they would draw more power and start flipping the breaker.
KennMacMoragh is offline
Old 11-17-2009, 08:03 PM   #6
Capra aegagrus
Tinstaafl's Avatar
Usually, but not necessarily. Depends on the length of the run, quality of intervening connections and so forth. And don't forget, the term "short" gets abused more than a remodeler looking for work on CL.
Tinstaafl is online now
Old 11-17-2009, 08:16 PM   #7
Service & Repairs
Magnettica's Avatar
Trade: Electrician
My guess would be the sump pump motor is bad (shorted, ground fault), because the HPS fixture will take a few minutes to warm up and get going before it would overload a circuit.
Magnettica is offline
Old 11-18-2009, 07:43 AM   #8
mrmike's Avatar
Trade: Electrical & Carpentry
These lights are probably HPS & most outside lights like this don't really have a power supply, but a starter circuit, a Capacitor & a Ballast which is basicly a transformer. Yes, usually when one of these parts short or open the light will not come on. But I have seen where the secondary side of the Ballast to the light shorts to ground without burning up the ballast & keep right on working.. Take load checks on each individual light & some signs to look for is a brighter or dimmer light than the others.
Another note - these lamps usually go off & on for a while when the lamp is going bad- and if the lamps are the wrong wattage they will do the same...........
mrmike is offline
Old 11-18-2009, 06:21 PM   #9
72chevy4x4's Avatar
they fixed the issue and indicated it was the power supply (or transformer ??).
so, if the transformer shorts, does anyone have the knowledge as to what is actually shorting? is it a step up transformer to give an initially higher voltage to ignite or start the lamp? Is the winding on one side of the core the part that typically shorts? Just trying to learn a little
Old 11-18-2009, 06:43 PM   #10
Electrosexual
Zinsco's Avatar
Could be the capacitor shorted, not the transformer. They aren't being really specific when they say power supply...
Zinsco is offline
Old 11-19-2009, 06:52 AM   #11
mrmike's Avatar
Like Zinsco Stated they aren't being very specific to what they fixed- They either changed the capacitor, the starter "Igniter" or the Ballast. Which part are they calling the power supply??
Anyhow the starter "igniter" is usually a small circuit board in the light housing that when, it is given the voltage to turn on it, lets the ballast step up voltage beaucoup to "ignite" the gas & get it flowing inside the encapsule in the Lamp. Once it starts & warms up the Starter circuit drops out & the voltage drops & regulates to the wattage of the lamp..
It is hard to say which side of a Ballast shorts out but most I have seen are usually "charred" from shorting out & getting very Hot...............
mrmike is offline
"Wireless" LED Trailer Lights DirtMoverUSMC67 Landscaping 5 10-12-2009 10:19 AM
Motion activated security lights Robie Electrical 1 07-28-2009 10:48 AM
Security wire code?? Jason Whipple Low Voltage 24 03-19-2009 09:02 PM
Can Lights tlrupp@charter. Electrical 3 12-27-2008 04:53 PM
