tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
Sealing Off Old Smoke Detector
Old 09-10-2017, 10:32 AM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 974
An old smoke detector has been disconnected. Layered with heavy coats of paint...no other info on it (security system/fire alarm, etc) other than it looks dipped in paint.
Need to pull it, but before I get into cutting that build off this relic and maybe cracking or breaking the housing in the process - what if it is an older 120v? Box the wires with a flush ceiling cap for access? If it's low volts (had the interconnected transmitter wire back then?)...tape them and stuff them up inside?
Could get a pic but don't know if the outside alone would help much...
artinall is offline
Old 09-10-2017, 12:25 PM   #2
hdavis's Avatar
Rewards Points: 4,459
Re: Sealing Off Old Smoke Detector
Plan on boxing it with a blank plate. Obviously check to see if it's hot before you do anything.
hdavis is online now
artinall (09-10-2017)
Old 09-10-2017, 12:27 PM   #3
artinall's Avatar
Rewards Points: 974
Blank plate - you mean a metal plate or decorative plastic plate? Does it matter as long as there is access?
artinall is offline
Old 09-10-2017, 12:31 PM   #4
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 11,225
Plastic isn't that decorative. Any round blank plate if there's a round box.
If it's battery-operated, your choice is remove and patch, or just replace it.
MarkJames is offline
The Following 2 Users Say Thank You to MarkJames For This Useful Post:
artinall (09-10-2017), Josep Tito (10-23-2017)
Old 09-10-2017, 12:32 PM   #5
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,068
Doesn't matter.
Tinstaafl is online now
slowsol (09-10-2017)
Old 09-10-2017, 02:59 PM   #6
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 10,046
You only need to maintain access if there's a splice in the box.
If it's the end of the run, wire-nut and tape the wires up and bury 'em as you see fit.
Chuck Norris can cut through a knife with hot butter.
480sparky is online now
The Following User Says Thank You to 480sparky For This Useful Post:
hdavis (09-10-2017)
Old 09-10-2017, 07:12 PM   #7
artinall's Avatar
Rewards Points: 974
Is it safer to maintain access, a coverplate over the box - and does it matter if a plastic or metal box is used?
artinall is offline
Old 09-10-2017, 07:15 PM   #8
rrk's Avatar
Rewards Points: 1,080
are you sure its a smoke detector? I have never seen a smoke detector painted, heat detectors yes.
Residential single family?
rrk is online now
Old 09-10-2017, 07:47 PM   #9
artinall's Avatar
Rewards Points: 974
It is residential single family.
artinall is offline
Old 09-10-2017, 08:12 PM   #10
480sparky's Avatar
Probably not.
I- and does it matter if a plastic or metal box is used?
Either is acceptable but not required.
The Following 2 Users Say Thank You to 480sparky For This Useful Post:
artinall (09-10-2017), Sisyphus (09-12-2017)
Old 09-11-2017, 08:18 PM   #11
artinall's Avatar
Rewards Points: 974
Okay - that was a heat detector and wiring was part of the security system which is all disabled. So I'll crimp or wire nut.
But elsewhere I need (2) smoke and Carbon monoxide detectors that are interlinked. So if one alerts so does the other...the hard wiring in the boxes are live so I'm all go except for the fact that I can't find them in wireless hard-wired. Only strictly batteries, AA for power. Does anyone make these hardwired that are not "smoke only" but have the carbon monoxide feature?
artinall is offline
Old 09-11-2017, 08:32 PM   #12
rselectric1's Avatar
Rewards Points: 556
I have yet to locate one that does both with RF.
https://www.amazon.com/dp/B00PC5S5UK...a-320901479735
is the closest thing I've been able to find. Hopefully they will invent something soon.
rselectric1 is offline
Old 09-11-2017, 09:11 PM   #13
artinall's Avatar
Rewards Points: 974
Yes. Since I'm thinking the double A's can't last too long, running on them full time.
artinall is offline
Old 10-22-2017, 12:55 AM   #14
Hotneutral's Avatar
Trade: Electrical
Rewards Points: 8
Junction boxes must remain accessible. If its a straight pass through you may be able to get away with it but if it contains a joint or even a dead end it needs to be accessible. Invisiplates are the way to go for ceilings. they can be painted and don't look obtrusive. I wasn't aware that rf connected smoke detectors were allowed. I've always hard wired them on a dedicated circuit but if that is an option it would be very useful. Any references on the usage of those in the US?
Hotneutral is offline
Old 10-22-2017, 12:48 PM   #15
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 5,688
FWIW not RF, but NEST smoke detectors are both CO and smoke, but operate on WIFI. Both of mine failed, one almost causing me to call the fire department as we were out of town, when I got the text message. Fortunately the neighbor was reachable and walked down the driveway to tell me there was no fire burning.
NEST warranty was a breeze.
Peter_C is online now
The Following User Says Thank You to Peter_C For This Useful Post:
rselectric1 (10-22-2017)
Old 10-22-2017, 12:56 PM   #16
480sparky's Avatar
Originally Posted by Hotneutral View Post
........... but if it contains a ...... a dead end it needs to be accessible. ............
Take it out of the box, cap it off and bury it. Problem solved.
Old 10-23-2017, 07:29 AM   #17
Josep Tito's Avatar
Trade: 24/7 Electrician
Rewards Points: 16
And more to know, plastic is heat resistant/insulating so that is also safe to use, both in DIY as well as for electricians.
Josep Tito is offline
Smoke Detector Issue tonyc56 Electrical 18 07-06-2017 08:02 AM
I have a burning question JonM Tools & Equipment 25 02-26-2013 09:08 PM
Sealing Metal Valley Section artinall Roofing 20 11-07-2012 12:18 PM
Smoke Detector katoman Electrical 5 12-30-2011 07:24 PM
smoke detector chirping woodworkbykirk Electrical 7 03-24-2009 08:51 AM
