tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
Running Electricity To Trailer
Old 10-29-2017, 08:19 PM   #1
Flawless Flooring
FFlooring's Avatar
Trade: Hardwood Floor Installer/Refinisher
Rewards Points: 26
Need some help from the electricians out there. I'm a hardwood flooring contractor and have a 16ft enclosed trailer that I'd like to run power to. I have it set up as a mobile woodworking shop, equipped with a table saw, miter saw, vacuum, compressor, lights,etc.. Right now I run a long extension cord to the customers house and typically plug into their garage for a 20 amp circuit. On the other end, my tools get plugged into a 20 amp surge protector. Here is my dilemma, I cannot run the table saw with the vacuum and lights on all at the same time. Is there some kind of amplifier I can use? Or do you have any other suggestions of how else to set this all up? I really don't want to use a generator due to having it run all day long, and waste gas/money. Rather use the customers electricity if I can.
Thanks in advance for the help
FFlooring is offline
Old 10-29-2017, 08:25 PM   #2
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 10,408
Re: Running Electricity To Trailer
You're gonna need more than a 20a circuit if you want to use more than 20a. If there was such a thing as an amplifier, we'd all have 2-amp services in our homes.
Solar is about your only other option.
Why is there not a Flat Mars Society?.
480sparky is online now
Old 10-29-2017, 09:08 PM   #3
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,881
You could get more juice by plugging into a 240V clothes dryer or electric range outlet, but of course you'd need the appropriate cord/plug for that, as well as a subpanel in the trailer.
You could also run two cords, plugged into outlets on different phases. But in either case, you ought to have an electrician set you up. A generator would probably cost less.
Tinstaafl is offline
Old 10-29-2017, 09:37 PM   #4
480sparky's Avatar
Originally Posted by Tinstaafl View Post
...........You could also run two cords, plugged into outlets on different circuits .........
Fify.
Old 10-29-2017, 09:41 PM   #5
Capra aegagrus
Tinstaafl's Avatar
Potayto, potahto. It's late, I'm sore. But thanks.
Old 10-29-2017, 09:46 PM   #6
480sparky's Avatar
Potayto, potahto...
Not really. Most homes only have one phase. That's why it's called single phase.
Old 10-29-2017, 10:04 PM   #7
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 878
Making sure of running a lease a 12 ga cord would help too. I have run my saw and vac a lot of times on just a 20amp. I always pack my gen with me too, so if need more I have it. Good way to burn up a compressor if running to small of a cord with low voltage.
Randy Bush is online now
Old 10-29-2017, 10:32 PM   #8
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,224
heavy gauge and as short as possible cord, a 20A circuit close to the panel, you can probably run both at once. Or just use two cords.
Golden view is online now
Old 10-30-2017, 07:44 AM   #9
This space for lease
RangoWA's Avatar
Trade: General
Rewards Points: 4,628
Invest in cordless tools.
RangoWA is offline
Old 11-02-2017, 07:28 PM   #10
kixnbux's Avatar
Rewards Points: 1,440
Mines set up like that. 21’ rolling Shop. I use a 12 gauge cord. All led lighting in my trailer though for minimum draw. Run a 12” dewalt miter saw combined with vac and lights no problem. It’ll run tablesaw and lights no issue as well.
Just for kicks I tried leaving the router table running. All the lights and the miter saw with shop vac and it did that ok too
kixnbux is offline
On the Trail of A thief knothead Off Topic (Non Trade) 85 04-29-2015 01:31 AM
What tow vehicle do you think would be best for a mobile blasting trailer? Blast Off Sandblasting 0 03-06-2013 01:06 PM
Trailer size & Truck size(towing capacity) Dmitry Vehicles 19 01-24-2013 08:30 PM
Enclosed Trailer Insulation SCOTT@SCRSLLC Tools & Equipment 19 11-25-2012 05:44 AM
Drawer-Based Trailer Project (Lots of Photos) BuildersII Tools & Equipment 48 04-10-2011 11:12 AM
