Trade: Hardwood flooring contractor
Running 220 For 125 Feet
I'm doing a 4 suite apt complex (Hardwood floor refinishing). My machine runs on a 220 line and the closest one is approx 125 feet away. Can i run 125 feet of wire this length without damaging my machine? I've been told that running over 100 feet of wire, my machine would lose a handful of voltage and could blow my engine on my sander?? Is there any merit to this?? If this is not a problem what gauge wire should i purchase? I usually bring my own 30 amp breaker, then clip onto the ground in the box. Thanks so much....i'll swap info for floor sanding techniques...
Chris Frate Pasquale Floors |
Trade: Electrician
Re: Running 220 For 125 Feet
To do a voltage drop calculation we need the amperage of the equipment as well as the voltage.
Also how to you clip on to the power? It sounds like something very unsafe. Especially since you said that you clip onto the ground in the box. This part tells me that you have no clue as to what you are hooking up to, beyond knowing that it has not killed you yet. |
19 amps on the machine. I can take a reading tomorrow to see what the dryer receptacle is.
#4 | |
daveselectric
Trade: Electrical
Re: Running 220 For 125 FeetQuote:
Service & Repairs
Trade: Electrician
I always love how the floor guys come in and just have their way with panel. Most of them DO put the panel cover back after they're finished, but that's not the point. The point is that the flooring contractor needs to contact the electrician (or sub one out), instead of having an inexperienced floor tech attempt to make a lethal electrical connection.
Leaving the 240V elec dryer line live is a good idea but not all floor subs "splurge" for the male cord end. |
Union Electrician
Trade: Inside Wireman
If you're 'clipping' on to utilize any of the current carrying conductors(hots or neutral if there is one) then you're defeating the purpose of using an oversized cord because if it's not a solid/bolted connection then all your voltage drop will be in that one point.
You're not off base asking about voltage drop and extension cord length. What kills the motor is overheating due to lack of power. In the power equation you have amps squared times resistance. Resistance being the length and gauge of your cord and amps being what the tool/motor uses, but the key ingredient of the equation is the amps being that it's squared in the equation. Now after the lesson.....What do you know about sanding a travertine floor? |
Sparky.. thank you so much. Travertine??.. I do wood floor my brother. If your looking to clean a travertine floor i would recommend a 16in buffer with a red pad (no sanding!!) using a high quality travertine cleaner bought at any tile distributor. If you lived by me i would let you use my buffer at no charge.. not sure where you reside though.
Sparky.. what is my best option here without peeing everyone off due to my lack of electrical knowledge. I've been told by some very expierenced flooring contractors to get some 10-3 wire and purchase a booster that way i could run a lenght over 100 feet. Im not able to purchase a booster right now. Could i get away with just getting the wire and plugging into the dryer receptacle.. or is the answer just not that easy??? Thanks so much. I know that when other trades come into this forum and ask stupid questions like my self, people get upset.. and i understand and I am aware that they are looking out for my safety and that is appreciated. Im on a flooring forum where h/o's sneak on and i try to hae patience with them as you are with me. Grant it, it would be difficult to kill yourself sanding floors. Thanks
Pasquale... do you feel there is a market for such "boosters" for floor sanders? If so, I'll build you one for free if you can sell 10. No joke.
md... You would be surprised how many flooring contractors use them. I'm still trying to figure if i need one. Most flooring distributors sell them from $300 to over $900.. I would only be intrested in purchasing 1. I don't think I could get rid of any for you also.. but thanks for asking.
What would you do if you were me in this predicament?? I will take your advice.
#10 | |
I do know that some flooring contractors have asked the GC, who have in turn asked me, to provide with with certain power provisions. I always provide whatever the floor guy needs temporarily, at no additional cost to the GC, as a goodwill gesture. I'd rather set up a temporary receptacle for the floor sander for free than to have the floor guy use clips in my panel. It only takes me a short drive and a few minutes work to set up something proper. |
Re: Running 220 For 125 Feet |
Union Electrician
Pasquale, from the numbers you gave your voltage drop is near 6 volts. thats only a difference of 2.5%. As a wireman I'm not allowed to run a branch circuit with more than a 3% voltage drop. But most motors are safe with a 10% variation in rated voltage.
In other words you're safe without a booster, though I am curious how MD would build one even if you ran a #12 gauge cord you would have less than 4% drop at that length. I would say that your still safe there Last edited by Sparky Joe; 04-14-2007 at 03:57 PM. |
md... i believe floorstyle.com sellls them if you want to check out their site. I know some of them allow you to "dial in" the numbers you need and this raises the cost. Appreciate the effort.
Sparky.. what wire should i run?? 10-3? and what is 10-3 while we are it it.. Im assuming 10 is the gauge and 3 is the amount of wires provided?? Anything else i should know while wire shopping? Is this available at H Depot or should i go to an electrical supply house??? You are not the first person to tell me that same scenario.. so i'll go with it.. Thanks so much!.. appreciate the patience with me.. Md.. site note.. i have seriously tamed down my involvement with electrical work.. mostly due to those nasty pics you posted ... ... thanks again..
Union Electrician
10/3 is what you want, it will have a black white and green inside it, make sure the green is in the right place when you wire it up, the black and white don't matter so much because they are both being used as hots.
Home Depot will have the wire but not have the cord caps and you'll find much better deals at the supply house. Tell them you need a male and female cord caps for 30 amp 240 volt(non twist lock). In fact draw a little picture of your receptacle that you plug into to make sure you get the right thing. as for the cable itself, it will be pricey you might want to call around. I'm pretty sure what you need is called SO cord, although SJ may work fine too. |
Union Electrician
#18 |
Union Electrician
So what type of cable would you use MD to make the proposed extension cord above? SO would be a first choice and SJ is cheaper but not as heavy duty(or as heavy). Or is there some other type of cable just for an extension cord application that I don't even know of?
And are those buck boost's really as tricky to hook up as I've heard? And don't they have a minimum of 12 volt boost(or buck)? such as a 12/24 or 16/32? |
#19 | |
Trade: master electrician USA / France verison
there are few single phase motor can work pretty well on 208 volts on some area which they only have that voltage avabile. But as i will remind ya real quick the code get pretty tricky with buck/boost transformer . the cost of the B/B is not very expensive but you have to know the VA of the line current to the B/B transformer. I am not sure which website have easy chart to show you to get the correct verison [ there is at least 20 diffrent way to get diffrent voltage as needed ]. I will give you a quick example 19 amp @ 240 volt normally and the supply voltage is at 208 volts one example of the link http://www.squared.com/us/products/t...ckandboost.htm and real caluation here: http://www.bulletproof.com/jdesigner...alculator.html I know it get pretty compated with the forumla to figure it out in correct way I will put in more details later on the time unless other members join in and help fill it in for me as well . Merci , Marc |
#20 |
Buck Boost transformers are not complicated at all !!
They're auto transformer connected, so they're not a separately derived system, so none of the special grounding issues to worry about. You size they by KVA of the load. This will NOT match the KVA of the BB transformer. They have a HUGE capacity when connected for BB. Once you have the right size BB trans picked out, you just follow the diagrams to connect them for 5% or 10% boost, or 5% or 10% buck. You can hook 2 or 3 (depending) together for 3-phase applications. The 12/24 and 16/32 has nothing to do with the amount of buck or boost. When a buck boost transformer is not auto transformer connected, it's a 120/240V primary by 12/24V secondary and 120/240V primary with 16/32V secondary, respectively. They're not complicated at all. I've built a few rigs for RVers. I generally put a heavy cabinet handle on top to carry it, put a little 4x4x4 Hoffman box on the side with a flanged inlet in the cover for the equipment to plug into, and a 6' hard usage cord coming out of the BB trans with a Kellems type cord grip. A guy could rig up a toggle switch to change between boost percentages. Last edited by mdshunk; 04-15-2007 at 01:29 PM. |
| What is everyone running for Fiber in new home Construction? | voiceguy | Low Voltage | 9 | 04-09-2008 06:20 PM |
| Is your business running YOU or are you running your BUSINESS? | Mr. Wms | General Discussion | 21 | 01-27-2007 02:47 PM |
| difference between running a bus. and a contracting bus. | dirt diggler | General Discussion | 22 | 11-01-2006 06:45 PM |
| Makes any sense? | Mike Finley | Electrical | 11 | 01-15-2006 08:02 PM |
