Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Electrical
Old 10-11-2009, 09:55 PM   #1
Master Electrician
Bubbles's Avatar
Trade: Electrical
Rubber Conduit
Just curious about what I saw today at an event. Haven't been in the Marina Section yet but can you run rubber conduit to subpanels in a park on the river that floods??? It looks like 3 ungrounded conductors (#4 Cu) and 2 Grounded Conductors (#6Cu) in a 1.5" Rubber conduit (I sqeezed it). On a side note I saw a recent job with GFCI's in tree mulch at a brand new shopping center 1" off ground. Meters 2ft or 8ft off ground, etc... Should I carry tickets to sporting events and drop them on floor when inspector shows up? Please tell...How can these big companies get away with this stuff?? I'm not sure how that park would be classified anyhow. It's 25ft above normal water level but in bad floods it gets covered and there are boats close by but not necessarily a marina area.
Bubbles is offline   Reply With Quote
Old 10-11-2009, 10:28 PM   #2
Resident Lurker
Trade: Electrical Products Manufacturer
That looks like SO or SJ cord. The wisps of filler inside the jacket are a giveaway. You can get that cord in a number of different conductor combinations. It looks like the cord came out of the malleable iron cord grip. As for the install, I am not sure if its power feed or some kind of control wiring.
BTW...There is no such thing as "rubber conduit".
Larry
LJSMITH1 is offline   Reply With Quote
Old 10-11-2009, 10:49 PM   #3
Master Electrician
Bubbles's Avatar
Trade: Electrical
Rubber
Rubber conduit was a joke. It looks to me that SO and SJ is not applicable to that environment?? Could it be another type? Not really sure. Here is larger view. It doesnt seem like very good protection for a very public environment. No support either is this pic? about 2 ft from ground.
Old 10-12-2009, 05:44 AM   #4
mrmike's Avatar
Trade: Electrical & Carpentry
That also looks like SO cord to me as we used alot of it in the "plant" mostly for hooking up temporary "but ended up permanent" stuff like big fans & portable power stations, etc. It is very tough but It is definately not kosher in that situation. It may be feed for a underwater pump of some sort as alot of them have a rubber jacket like that.
I used to run the rubber jacket a few inches past the squeeze nut & tape the heck out of it so it could not pull out like that one did............... I don't see a lock on that Box either !
mrmike is offline   Reply With Quote
Old 10-12-2009, 05:48 AM   #5
Trade: Electrical
We often run this "rubber conduit" to floating docks, although we support it with Kellums grips or strain reliefs.
BTW, it is very difficult to pull in another conductor so make sure you pull in the correct # the first time.
TxElectrician is offline   Reply With Quote
Old 10-12-2009, 06:53 AM   #6
Trade: Electrical Contractor
Its SO cord. The core of Engineers here actually requires it for floating docks. We do these dock inspections every once in a while.
Ohmy is offline   Reply With Quote
Old 10-12-2009, 03:01 PM   #7
Electron Flow Manipulator
480sparky's Avatar
Trade: Electrons for cash
If that's conduit, I bet it was a nut-buster pulling all those conductors in when it probably works out to 95% fill. Jam coefficient would have made it near impossible to pull unless it's a very short run.
Age is just a number but mine is unlisted.
480sparky is online now   Reply With Quote
Old 10-12-2009, 03:42 PM   #8
BLDG Inspector, G.C
Trade: BLDG Inspector, G.C
Is that a panel facing a wall with no clearance ?
Or i'm I not seeing the picture right.
spdtrx is offline   Reply With Quote
Old 10-12-2009, 04:22 PM   #9
480sparky's Avatar
By cracky, I think you're right.
Not 'no' clearance, but not near enough!
Old 10-12-2009, 07:53 PM   #10
Master Electrician
Bubbles's Avatar
Trade: Electrical
clearance
they must have added that concrete pillar after because the door wouldnt even open all the way. Thats where the breakers were. The front side you see had 4 quad receptacles. None of the 12 around the park had locks and little boys were playing on or around them. I know that's what I would of done at 12. I would of had a knife and see if I can cut through the wires
Old 10-12-2009, 09:23 PM   #11
Trade: electrician
Looks to me like wouldn't open all the way is an understatement. Unless the picture is decieving I bet you don't get 45 deg, no less 90.
s.kelly is offline   Reply With Quote
Old 10-13-2009, 07:49 AM   #12
woodchuck2
woodchuck2's Avatar
No way is that panel compliant and is definetly a safety hazard. Its amazing how much hack work is out there that can be spotted on a daily basis.
This is the type of flexable conduit i have been using http://electrical.hardwarestore.com/...it-683266.aspx . It works well and uses decent fittings but anything over 6' long as an absolute nightmare to pull through. I have been using this conduit for generators mainly but i also used it on some electrical equipment in a pump house where the was high humidity and a chance of water intrusion.
06 Chevy D-Max ECSB, 8' Fisher plow, 6' Salty Dogg in bed sander,
06 Chevy D-Max RCLB, 8' Fisher plow, 98 Sumitomo mini excavator, 96 7k 16' Phoenix car trailer, 06 12K 18' Cam-Superline equipment trailer
04 7k 6'X10' Kristi dump trailer, 07 7k 7X14 Continental V-nose enclosed trailer
woodchuck2 is offline   Reply With Quote
Old 10-13-2009, 09:04 AM   #13
Elect Cont/Wiring Insp
Trade: Electrical
Send a message via AIM to InspWires
Code Violation
Since I do not see any other feeders going into the panel I am assuming that the cord are the feeders. This is a code violation and its use is not permited by Art 400.7 of the NEC. I would of had a field day doing this inspection.,
InspWires is offline   Reply With Quote
Old 10-13-2009, 02:16 PM   #14
Master Electrician
Bubbles's Avatar
Trade: Electrical
conduit
Maybe it was done by the city's electrical dept or puco . There exempt from NEC probably.
rubber cost consolidatedbui Roofing 0 04-03-2009 02:50 AM
Rubber roof hole Mitch M Roofing 39 04-02-2009 11:18 AM
small rubber roof repair jclem Roofing 2 10-28-2008 08:10 PM
Pricing for painting 1" conduit saucedo80 Painting & Finish Work 10 10-06-2006 12:27 AM
Removing old wiring from conduit duke Electrical 3 01-29-2006 11:04 PM
