Trade: Electrician
Rough Inspection
Hello, I am doing a basment remodel, my question is does the inspectors want to see the recessed lights in place, (it will be a drop ceiling)
I know all the other items that have to be done just not sure about the lights, I was just going to drop a temp light where the first light would go. Thanks. |
And I do electrical, too!
Re: Rough Inspection
I've never had an inspector require recessed cans in place for a rough if it's going to be a drop ceiling.
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. |
Trade: Electrician
Thanks, thats what I was thinking, I just wanted to double check.
#4 | |
Fentoozler
Re: Rough InspectionQuote:
Service & Repairs
Trade: Electrician
Tell the inspector of your plan (how many lights, etc), then offer to leave a tile or two open so he'll be able to see the work.
| The Following User Says Thank You to Magnettica For This Useful Post: | ampman (09-30-2009) |
Trade: Electrical Contractor
You can do it two ways. First, the commercial building way where you get a wall cover, ceiling cover, and final. We use this method for basements with drop ceilings. The second method is to install all the recessed lights (putting in the tiles you need for the lights yourself) and call of the rough. Either way, a good inspector will want a ladder set up and a ceiling tile removed on the final as well.
Electrician in Alpharetta, Roswell, Atlanta |
huntington beach, ca.
Trade: electrical
If the ceiling grid is in, then put the tile in and install the can. Obviously if there is no grid you , you could just hang the can. Can lights are rough, so better install it.
| Heat Exchanger Inspection Methods Symposium | MechAcc | HVAC | 3 | 08-15-2009 02:10 PM |
| Ahh it's a good day today! But a rough week | J-Peffer | Roofing | 4 | 09-01-2008 02:06 AM |
| rough in inspection | chris n | General Discussion | 10 | 09-27-2007 06:10 PM |
| Residential Rough in Estimate Central Florida | Surface Tension | Plumbing | 7 | 06-17-2007 12:23 AM |
