Romex? Say It Ain't So...
Old 04-10-2007, 03:41 AM   #1
JamesNLA's Avatar
Trade: Plumbing & Electrical
Was having a discussion with a forman today. With respect to a complete rewire in a gutted 40'X100' office building. While I don't particularly do too much commercial work, I know that it should be done...or at least I do that sort of work with FMC or NMT for all the conductors. However I was challenged with the question of why not romex?
During lunch I looked it up...again.... Type 3-4-or 5 building. 15 minutes and while Romex can be visible, cannot be in a place where it can get damaged. I had actually already known that, but I was looking for some magical code refference with respect to commercial applications. And I couldn't find any. So are there any situations that Romex IS allowed in commercial office space, given the aformentioned?
Thanks
JamesNLA is offline
Old 04-10-2007, 05:41 PM   #2
jbwhite's Avatar
Trade: Electrician
Re: Romex? Say It Ain't So...
James, you answered your own question. Romex is allowed in any building that is type III, IV, or V. It does not matter if the structure is residential or commercial. Industrial is probably out of the question as it would most certainly be type I.
A good rule of thumb is that: If the walls and roof are made of wood, romex is allowed except in the drop ceilings. Be sure to check with the bldg dept regarding exactly what type construction the building actually is.
jbwhite is offline
Old 04-10-2007, 05:59 PM   #3
mdshunk's Avatar
Romex is also not permitted in a non-dwelling occupancy anymore, where it is exposed.
334.12 Uses Not Permitted.
(A) Types NM, NMC, and NMS. Types NM, NMC, and
NMS cables shall not be permitted under the following
conditions or in the following locations:
(1) In Type I or II construction unless permitted to be
Types III, IV, or V construction.
(2) In non-dwelling construction unless the cables are
concealed within walls, floors, or ceilings that provide
a thermal barrier of material that has at least a 15-
minute finish rating as identified in listings of firerated
assemblies.
(4) Exposed in dropped or suspended ceilings in other
than one- and two-family and multifamily dwellings.
In other words, if this is a non-dwelling occupancy, you can normally use romex BUT if you can see the romex, it's a violation. No exposed romex home runs at surface mounted panels. No exposed romex in commercial attics and crawls, etc. You can still normally use romex in the walls of non-dwelling occupancies and drywalled ceilings of non-dwelling occupancies.
Technically speaking, this section also prohibits you from having any exposed romex in detached garages on a residential property, because detached garages are not a dwelling.
mdshunk is offline
Old 04-10-2007, 06:29 PM   #4
jbwhite's Avatar
Trade: Electrician
I think you are taking it to an extreem when saying that the attic and crawl space wiring is exposed.
Do we have any inspectors here?
jbwhite is offline
Old 04-10-2007, 06:42 PM   #5
mdshunk's Avatar
It's not behind a 15 minute finish if you can see it. No two ways about it.
We're talking non-dwelling, here.
mdshunk is offline
Old 04-10-2007, 06:49 PM   #6
jbwhite's Avatar
Trade: Electrician
It would be behind a 15 min finish from where the occupants are to where the wire is.
jbwhite is offline
Old 04-10-2007, 07:03 PM   #7
frenchsparky's Avatar
Trade: master electrician USA / France verison
"334.12 Uses Not Permitted.
NMS cables "
Marc ,,
Will you please clearify this a little what the you called NMC and NMS what the heck is that ??
but if iam reading right teh NMC is the same as UF ???
I just want to make sure i am reading this right
Merci , Marc
frenchsparky is offline
Old 04-10-2007, 07:42 PM   #8
mdshunk's Avatar
NMS cables "
Marc ,,
I can't. I've never seen the stuff, as far as I know. I'm not even sure it exists. I only use NM type B.
mdshunk is offline
Old 04-10-2007, 07:43 PM   #9
mdshunk's Avatar
But that's not what it says. That's what you want it to say.
mdshunk is offline
Old 04-10-2007, 07:57 PM   #10
JamesNLA's Avatar
Ok, in the walls which are drywalled is OK, but not in the attic?
Maybe I mis read that:
This particular building has an attic, however it will have a drywalled ceiling when complete. So, would that mean I can use Romex from lets say a recept or a switch box, run it up the stud, to a Jbox just before the plate, than switch to flex going through the plate than off into the attic? That can't be right.
So let me ask another question, why is flex so dominant in other commercial building just like this one. type V with sheet rock....and the other requirements met?
EDIT:
Wait a minute here, the first line of the quote I just did...
Meaning if it was a commercial non dwelling that had no ceiling (drop ceiling is a no no, and I know that) comprised of sheetrock or any other material (lath) that gives the 15 minutes THAN romex cannot be in the attic? That makes sense for the required 15 finish. Is that correct?
JamesNLA is offline
Old 04-10-2007, 08:03 PM   #11
mdshunk's Avatar
What I'm saying is that this 334 requirement is very clear, but oft overlooked. You need something along the lines of MC or EMT anytime you can physically put your eyeballs on the wiring in non-dwelling construction. Feel free to use NM cable when the wiring is concealed in the appropriate construction types. Don't get upset with me, but the code text is very clear. The inspectors might overlook it a bit, but that's their problem.
mdshunk is offline
Old 04-10-2007, 08:11 PM   #12
JamesNLA's Avatar
NO NO, I'm not at all upset with you, I appreciate the input, very much so.
This is actually important to me, because if I can go all romex, it will save alot of time/money for the client. I'm gonna go reread 334, thanks MD!
JamesNLA is offline
Old 04-10-2007, 08:35 PM   #13
jbwhite's Avatar
Trade: Electrician
NO, that is what you want it to say.
To me exposed means that when the building is finished and in normal use, the occupants will not see it. If one must lift a tile, open a crawl door, or remove some other type access panel to get there, it is not exposed.
Otherwise all wireing is exposed always. I can always remove drywall or open box covers to get to it.
jbwhite is offline
Old 04-10-2007, 08:44 PM   #14
mdshunk's Avatar
To me exposed means that when the building is finished and in normal use, the occupants will not see it. .
Yes, but "exposed" was my term. The code says the cables must be "concealed within" that 15 minute barrier. That means INSIDE. You can't be within a thermal barrier if it's only on one side.
I remain solid and steadfast, that if you can see the romex in a non-dwelling occupancy, it's a violation under 334.
mdshunk is offline
Old 04-10-2007, 08:50 PM   #15
jbwhite's Avatar
Trade: Electrician
If it is in the attic, then it is concealed within the ceiling. If it is in the crawl space it is concealed within the floor.
If I come to have a beer, I will not be able to see either.
jbwhite is offline
Old 04-10-2007, 09:02 PM   #16
jbwhite's Avatar
Trade: Electrician
md, Ryan agrees with you, and he is the best code gooo rrooo I know of..
So you must be right.
jbwhite is offline
Old 04-10-2007, 09:09 PM   #17
mdshunk's Avatar
I wish more inspectors agreed with him. I see so much exposed romex slipping through on commercial work that I didn't win, it sorta ticks me off. I bid EMT and MC on these jobs, and the hacks get it with exposed NM and get it passed.
mdshunk is offline
Old 04-10-2007, 09:53 PM   #18
JamesNLA's Avatar
OK, so to summerize this one last portion up, Because it's an "attic" meaning it has a means to enter into (access cover) that makes it exposed, and NOT concealed within.
An example of the latter would be a finished ceiling (drywalled) and then some kind of ply wood or non removeable sheeting that would conceal the wiring (no eyeballs can see it). And now that I think about that more, it makes sense. Thanks for the input, beers are on me!!
JamesNLA is offline
Old 04-11-2007, 12:14 AM   #19
Dustball's Avatar
A friend of mine bought a small commercial building last year and gutted it and built it to suit his needs. He had the whole building roughed in with romex and the electrical inspector ordered him to take it all down even though it was all going to be above drop ceilings. It was all re-done with MC cable.
Dustball is offline
Old 04-11-2007, 04:41 PM   #20
jbwhite's Avatar
Trade: Electrician
Romex cannot be run above drop ceilings except in residential work.
jbwhite is offline
Romex Protection Capt2 Electrical 8 03-12-2007 09:41 PM
Romex to Steam Pipe clearance? K2 Electrical 3 02-22-2007 10:01 PM
Electrical for fireplace insert Mike Finley Electrical 22 05-13-2006 10:26 AM
Light fixture without junction box ChuckEA Electrical 3 03-22-2006 09:54 PM
Question about a Light Fixture canada4 Electrical 18 08-20-2005 06:48 PM
