tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
Residential Windmill
Old 01-07-2017, 01:20 PM   #1
KG007's Avatar
Trade: Flooring & cabinetry
Rewards Points: 268
Hey Everyone:
My background is not electrical, and I have never received an answer from anyone on this question that was definitive.
We've had windmills for centuries, and have used them to make electrical power for decades. My understanding is to use them in a home, you have to have a bank of batteries and inverter or transformer. The windmill actually re-charges the batteries, and the home runs off the batteries.
My question is, if I had a windmill on my roof, why couldn't I use whatever power it produces without a battery system? When it is turning, I get electric. If it isn't producing enough, I run on the power lines coming into the house. There would be some kind of transformer and have to run it through a power filter of some kind to "merge" the sources and prevent spikes, I guess.
Is this totally not doable, eliminating the clumsy and expensive batteries in exchange for accepting it will be only part of my power supply?
KG007 is offline
Old 01-07-2017, 01:43 PM   #2
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 9,000
Re: Residential Windmill
Firstly, if it was doable - wouldn't there be a bunch of people doing it?
So....no.
Now that's pretty God Damned definitive.
SmallTownGuy is online now
The Following User Says Thank You to SmallTownGuy For This Useful Post:
Fouthgeneration (01-09-2017)
Old 01-07-2017, 02:01 PM   #3
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 768
For what the cost is it is not really doable. If you wanted to run things on like 12 volt or something maybe.
A friend of mine put up a wind generator a number of years ago. He has a average size house and family. It was suppose to maintain a zero reading on the meter, you are pumping what you make back into the grid turning the meter back. Anyhow it does not do that. This is not a little cheapo unit neither. So now is trying to sell it. Has had it up a good 15 years. To many thing that affect it. Just because you have wind does not mean it is good or ideal wind for making power. I honestly don't think over the long run you save any money over being on the grid.
Randy Bush is offline
Old 01-07-2017, 02:04 PM   #4
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 68
If you want to live off the grid then you need the batteries just like solar, if not then no batteries are required & you can either use the power in your house or send it back to the grid. If you want to know more about it: http://thehtrc.com/2011/going-off-gr...ions-for-power
As for delivering enough power - well you have to properly size it based on prevailing winds.
SLSTech is offline
Old 01-07-2017, 02:05 PM   #5
hdavis's Avatar
Rewards Points: 7,249
Run the numbers, they'll answer whether it makes sense to do that. The answer is no, it doesn't make sense.
hdavis is online now
Randy Bush (01-07-2017)
Old 01-07-2017, 02:07 PM   #6
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 6,308
This is an assumption and I am not going to research it, but a windmill should work like solar assuming you are attached to the grid. You get a special meter that counts production and usage, which is then calculated on your bill/credit.
No way a "normal" roof can support a windmill for energy production. You wouldn't need an industrial unit but something of decent size is going to produce a lot of side loading forces.
Why not a solar system? Probably last longer than a windmill, with less mechanical maintenance, and the panels with inverters like Enphase carry a 25 year warranty. If you have a bill over $100, they usually have around a 7 year ROI, and from there on it is money in the bank. Effectively most power bills double every 10 years too, so what it is today, is not what the bill is going to be in the future.
Peter_C is online now
The Following User Says Thank You to Peter_C For This Useful Post:
Rio (01-07-2017)
Old 01-07-2017, 02:11 PM   #7
hdavis's Avatar
There's a company doing installs up here with no real up front cost - you pay for the system out of the cost savings over time.
Old 01-07-2017, 02:18 PM   #8
Randy Bush's Avatar
Rewards Points: 768
Before I wasted a dime on a system I would try any talk to people in the area that have one , if any. Would not go by what some sale person or even the power company tell you. My friends is a 120' tower and think it ran him 30 thousand after a grant for it too. And that was for a unit that was suppose to generate 1500 -2000 . Rarely ever happened.
The Following 2 Users Say Thank You to Randy Bush For This Useful Post:
Fouthgeneration (01-09-2017), SmallTownGuy (01-07-2017)
Old 01-07-2017, 02:19 PM   #9
Randy Bush's Avatar
Rewards Points: 768
Originally Posted by hdavis View Post
There's a company doing installs up here with no real up front cost - you pay for the system out of the COST SAVING over time.
That is the real problem no real cost savings.
Old 01-07-2017, 02:37 PM   #10
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 11,662
I had a client that put one in, when it was roaring away the meter was spinning backwards.
Inner10 is online now
Old 01-07-2017, 02:42 PM   #11
John the Builder
Youz guyz already lost track of what the OP asked - is wind doable without the battery+inverter combo.
Solar/wind/hydro - all are doable. And you can save money.
Looka here, the OP even answered his/her own question. That "some kind of transformer" and "power filter" - that's called an inverter.
Old 01-07-2017, 02:44 PM   #12
John the Builder
Hey Randy, aren't you an off-grid guy?
Old 01-07-2017, 02:46 PM   #13
John the Builder
Yup. those blades make noise. I darn sure wouldn't want one on my roof telegraphing that vibration/thrumming through the structure...
Old 01-07-2017, 03:21 PM   #14
Randy Bush's Avatar
Rewards Points: 768
Yep wood cookstove. Kerosene lamps, horse and buggy. We are so far back in they have to pump sunlight to us. Lol
Sent from my LG-V520 using Tapatalk
The Following 6 Users Say Thank You to Randy Bush For This Useful Post:
Philament (01-07-2017), PRP (01-09-2017), Sisyphus (01-07-2017), SmallTownGuy (01-07-2017), Tom Struble (01-10-2017), TxElectrician (01-07-2017)
Old 01-07-2017, 03:22 PM   #15
Randy Bush's Avatar
Rewards Points: 768
Oh and the noise they make when shutting down from to much wind.
The Following User Says Thank You to Randy Bush For This Useful Post:
Old 01-07-2017, 03:27 PM   #16
Randy Bush's Avatar
Rewards Points: 768
We have an old 32 volt I think out at the farm. I have seen pictures of them batteries blanks they use to have.
Old 01-07-2017, 03:34 PM   #17
John the Builder
I remember now - you have to truck in water.
That would be a killer for me.
One of those mountain top towns in Arizona - Flagstaff - maybe it was Prescott - anyway, that geoseismic (harumph) outfit I worked for - one of their civilian jobs I was on was locating possible new water well locations - seems that being a mile high and having to go 10,000 feet down for water was putting some stress on their growing community.
Old 01-07-2017, 03:37 PM   #18
John the Builder
Somewhere around here, I have an old Kohler 4 cylinder 32 volt rig.
Was always gonna pull the motor and put it in an early garden tractor and make a retro mini rod out of it.
hmmm, so many ideas, getting too soon old....
Old 01-07-2017, 04:42 PM   #19
Peter_C's Avatar
That is a lease, and you do not own the system. Sun Run is one of the most popular finance companies. They will lower your energy bill with no out of pocket money. They will save you money long term. It is NOT an investment. Purchasing your own system using a home equity of line of credit, county financing if available or cash offers the best ROI. Far better than most stock market investments.
On that note, most solar systems today are installed on a lease...
Anyone who claims solar systems are not cost effective and do not pay back are ignorant. (Only time they do not pay back is lack of available light, or low bills.)
Old 01-08-2017, 11:25 AM   #20
hdavis's Avatar
I bought a bunch of 60W equivalent LED 8.5W bulbs for $1.50 each. Lifespan alone compared to a CFL makes it a good investment - the energy savings are gravy.
Electricity costs vary widely around the country, as does useful solar generation ability and subsidy programs for solar, so ROIs are all over the place.
Peter_C (01-08-2017), Tom Struble (01-10-2017)
Residential Flat roof Nac Roofing 8 04-23-2013 09:51 PM
Trying to get my Residential GC in North Carolina Ashevillian Contractor Licensing 8 03-05-2013 07:51 PM
Passing the Illinois residential roofing test. WTH stombaugh85 Roofing 0 07-30-2012 09:04 PM
OSHA acts to protect residential roofing workers Grumpy Roofing 20 04-29-2011 05:10 PM
