Replacing Old 2 Wire Receptacles
Old 02-28-2006, 09:51 PM   #1
GC/JE
steveprichard's Avatar
Trade: electrical
I want a thread on replacing a 2 prong ungrounded receptacle.
What's code, what you've done before, and what you've done at your own home.
steve
Steve
"Keep thee thy airspeed, lest the earth rise up and smite thee!"
steveprichard is offline
Old 02-28-2006, 10:16 PM   #2
GC/JE
Trade: electrical
Re: Replacing Old 2 Wire Receptacles
I will not put a 'jumper' from ground to neutral when replacing a recepatacle.
Steve
Old 02-28-2006, 10:40 PM   #3
electrical contractor
bigjay's Avatar
Trade: electrical
Look at 406.3(D) (1) (2) (3) in the 2002 NEC. It basically says you can use a
grounding type receptacle if you install a grounding conductor with the new receptacle. Replace the non grounding type with the same. You can replace a
non grounding type receptacle with a GFCI receptacle and mark it "No Equipment Ground" A non grounding type receptacle(s) shall be permitted to be replaced with grounding type receptacles where supplied through a ground fault circuit interrupter. These receeptacles shall be marked "GFCI Protected"
and "No Equipment Ground" It addresses a little more, this is the short version. As for my old house, It had 2 wire receptacles throughout now they are three wire.
bigjay is offline
Old 03-01-2006, 12:22 AM   #4
DGFVT
CE1's Avatar
Trade: Electrical
If it is a 2 wire system I always upgrade the wiring to 2 wire w/ground. One at a time if I have to.
"Kicking and screaming into the 21th century we go"
CE1 is offline
Old 03-01-2006, 05:12 PM   #5
GC/JE
Trade: electrical
Thanks guys.
I've got some outside walls with zero attic space, so I think I use GFCI receps upstream for them, and then upgrade others where possible.
Steve
Old 03-01-2006, 07:12 PM   #6
bigjay's Avatar
Trade: electrical
Just a footnote to my first post. There is a bad side to using the ungrounded
GFCI receptacle. There are cord and plug connected items that must be grounded in residential occupancies and are listed in Section 250.114(3).
They include refrigerators,freezers, air conditioners,clothes dryers, dihwashers,waste disposers,information technology equipment, sump pumps,
aquarium equipment,hand held tools,motor operated tools, hedge clippers,lawn mowers,snow blowers,wet scrubbers and portable hand lamps.
Long story short a GFCI is not a substitute for grounding, it operates only on line to ground faults. It will not prevent shock only reduce the duration.
bigjay is offline
Old 03-01-2006, 11:14 PM   #7
49FRANKS's Avatar
Trade: ELECTRICAL
Look At Your Cords! How Many Have Grounds Short Of Electronic Componets
RIGHT AS RAIN ON EVERY THING ELSE IS MY OPINION
49FRANKS is offline
Old 03-19-2006, 02:55 PM   #8
sparkysteve's Avatar
Trade: Electrical
I usually go with a GFCI Breaker to save time by not looking for the homerun to sort out line and load.
sparkysteve is offline
Old 03-20-2006, 09:05 AM   #9
Philadelphia electrician
RobertWilber's Avatar
Trade: Electrical contractor
I vote with 49franks
If your wiring isn't damaged and you don't NEED a ground for a particular piece of equipment, why bother?
I usually recommend just running a new circuit to point-task loads if you really need a ground, unless the homeowner is undertaking a general remodeling project.
RobertWilber is offline
Old 04-21-2006, 04:17 PM   #10
Trade: Electrical
Install GFCI breakers on the circuits you upgrade to 3-prongs.
Steve
Master Electrician/Self-Proclaimed Handy-Man
Old 04-22-2006, 07:14 PM   #11
Electrical Apprentice
darren's Avatar
Trade: Electrical
So I understand the fact that you can use a GFCI in place of a two prong plug. Now if I were to put a GFI on one and then connect the rest to the load side(like you would do if you jumped two bathrooms together) would this be considered right as well
darren is offline
Old 04-22-2006, 07:25 PM   #12
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
Yes. Everything down stream of the GFI must be labeled "GFI Protected" and "No Equipment Ground".
The stickers are included with the GFI.
Speedy Petey is offline
Wire balustrades karma_carpentry Decks & Fencing 11 09-17-2007 06:10 PM
Number of Receptacles in reference to hallisseydesign ryandumas Electrical 19 08-06-2007 09:58 AM
Another aluminum wiring question ron schenker Electrical 18 03-08-2007 06:54 PM
For the old-timers here... What's that old wire? steve-in-kville Electrical 27 09-08-2006 01:03 AM
safe hot wire driver Electrical 13 05-12-2006 11:18 PM
