Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Electrical
Old 10-27-2009, 02:01 AM   #1
huntington beach, ca.
Trade: electrical
Replacing Low Voltage can light transformer
Short story, a retro-fitting company( ie friend of mine), not licensed. Installed the wrong type of Occupency sensors in a beautiful multi-million brand new building and burned up 32- 277 volt low voltage magnetic ballast can lights.
He hired me to go straighten this mess out, my question would be, can I install a LV electronic ballast in each can? Should it be a manufacture spec transformer? or just any 277v magnetic trans? Or who knows where I can buy a 277v/12v transformer?
hbelectric is offline   Reply With Quote
Old 10-27-2009, 08:09 AM   #2
Master Electrician
Bubbles's Avatar
Trade: Electrical
burnt
I don't really understand the question, but, you might want to go here and call the tech guy.
http://www.lutron.com/Products/produ...ingmount&cid=0
Bubbles is offline   Reply With Quote
Old 10-30-2009, 09:12 PM   #3
Trade: electrical
My question is should I replace the ballast, with a direct factory replacement? So far the OEM has not returned my calls or email.
They use a magnetic 277 volt ballast, but it has to fit inside the fabricated box in the can, so it can't be just any ballast.
I'm also asking if I can use a Electronic ballast, where is it defiantly smaller and easier to buy, but it is not original.
I'm concerned that I replace these ballast, with non factory replacement, I might have some type of liability issues, that I don't want. In fact, I will write in my contract, no warranty, no responsibility for jack.
Old 10-30-2009, 09:35 PM   #4
God Bless America
Magnettica's Avatar
Trade: Electrician
Just replace all the fixtures unless you want to be held liable for re-using blown up hi-hats that some other "electrician" damaged badly and you rewired.
Classic Electric LLC
Repairs, Renovations, Rehabilitation
Magnettica is offline   Reply With Quote
Old 10-31-2009, 03:45 PM   #5
Trade: electrical
The fixtures are recessed 277v 4" IC rated can lights. New construction style, box style fixture, hard lid ceiling, no access above ceiling. Commercial office building.
I appreciate your reply, that is a pretty good idea, not possible and a remodel would not be code.
Old 11-01-2009, 07:59 AM   #6
Baltimore Electrician
JohnJ0906's Avatar
Trade: Electrician
It will be fun changing those ballasts.
Actually, damn near impossible.
John from Baltimore
"One Day at a Time"
All replies based on the 2008 NEC
Originally Posted by celtic
Deny Everything, Admit Nothing, Demand Proof
JohnJ0906 is offline   Reply With Quote
Old 11-01-2009, 04:56 PM   #7
Trade: electrical
I removed a ballst out of one, it is actually a good design, to work with.
Old 11-02-2009, 05:30 PM   #8
Trade: Electrical
I'm sure your buddy would love you to do this as cheap as possible, but if you change those ballasts out with non-standard ones .. and they give problems.. is he that much of a buddy that he'll cover the costs for you to go back and replace them a second time?
If he is? ... send me his name and number, i can always use a buddy like that.
IMO .. a ballast is a ballast, shouldn't make too much of a difference.
However once you start putting non-standard pieces in fixtures your taking on the role of an engineer and CSA ( i'm Canadian ) takes a very dim view of that.
The second problem is that God forbid there is ever a fire .. the insurance companies would eat you alive if they found out that you had replaced the ballasts with one that wasn't approved for that use.
Immanuel is offline   Reply With Quote
Old 11-03-2009, 01:10 AM   #9
Trade: electrical
Thank you. The manufacturing finally got back with me, so hopefully they will tell me where to buy them or send me some free ones.
Old 11-07-2009, 07:16 AM   #10
JohnJ0906's Avatar
Trade: Electrician
You removed it through the 4" recessed opening?
John from Baltimore
"One Day at a Time"
Old 11-08-2009, 11:11 PM   #11
Trade: electrical
http://www.prescolite.com/products/s...fr_inc_025.pdf
This is the fixture, very easy to remove. My buddy just found out he is not getting paid for this job, so I don't think I will be going back for the repair. Was quoted $30 per ballast =14 ballast x30= $420+tax+labor wow what a screw up.
Old 11-15-2009, 02:36 AM   #12
JohnJ0906's Avatar
Trade: Electrician
Looks a lot easier than the ones I have done.
He's not being paid for the job, or not being paid to fix the screw-up?
John from Baltimore
"One Day at a Time"
Old 11-15-2009, 11:27 AM   #13
Electrosexual
Zinsco's Avatar
Trade: Electrical Contractor
There's been a couple of times I've converted existing fluorescent cans to incandescent by opening the j-box from inside the can and changing things. It's totally do-able, so changing ballasts is no big deal. But not for free.
Zinsco is offline   Reply With Quote
low voltage light bulbs Hatter Low Voltage 1 09-10-2009 10:40 PM
high voltage landscape lighting Paul J Outdoor Lighting 3 06-21-2009 07:27 PM
Locate transformer indoors photocell outdoors? Stainless Steel Outdoor Lighting 5 03-27-2009 07:18 AM
How many members of CT does it take to change a light bulb? Bill Off Topic (Non Trade) 19 01-05-2008 01:13 PM
low voltage transformer for Zone valves. kiffys General Discussion 3 12-07-2007 07:16 AM
