Remote Gate Operators.
My new 6 ft. shadowbox fence will be going in shortly and will have a pair of 6ft. gates that I want to operate by wireless remote control.
The ones that I have found on the web seem absurdly expensive. I was wondering if anyone had some experience with these things? If I end up shelling out the big bucks, I want to make sure that I'm getting a good product.
#2 | |
Trade: underground
Re: Remote Gate Operators.Quote:
I put these in from time to time. I generally frankenstein parts from several manufacturers to keep the cost down. For keypad/call box pedestals, I use Door King. For wireless remotes.keyfobs and receivers, I use Stanley. For the linear actuators and actuator drive boards, I use several different manufacturers. Don't forget about a backup battery and trickle charger. If you're running power out there for this thing, might as well pull a phone line too so that people can buzz the keypad and you can talk to them with the phone and type #XX to open the gate.
Yes, regardless how you do it, it is absurdly expensive. There are only ways to make it "less" really expensive. If you wanted to make a slider gate, that's a tad cheaper, but not as dramatic as two leaves opening as you approach. Speaking of approach, you can get an acessory driveway sensor so that the gates open automatically on your way out without you doing anything. |
Pipe, this one can go just the same as the last one did. The M-DHVWC only specs 4 ft. fences and we like our privacy. We will also have another dog in our future and we are not the poodle type.
md, I have considered a number of DIY options from modifying garage door openers to pneumatic systems. The gate is at the side of the house, not at the end of the driveway and on the garage side, so any power system is convienient. The object is to put the van behind it prior to a neighborhood uprising, rich folks are taking over my little piece of paradise and are beginning to groan about commercial vehicles parked out front. I have been through all of this a few times in Ft. Lauderdale, over time, no one remembers that you were here first and that they moved into YOUR neighborhood. Back on track, swing gates are my only option. Let's see if anyone else weighs in. It looks like I may have to cobble something together too.
I'm curious if you have a electric gate is there a manual way to open them if the power goes out or something messes up.
#6 | |
I like the call from anywhere and you can open it up. As far as ups or fedex i wouldn't want those guys being able to open my gate.
#8 | |
| Remote switch | knothole | Electrical | 1 | 07-02-2007 02:01 PM |
| Operators, Carpentures, Laborers Needed | Les728 | Help Wanted or Looking For Work | 5 | 01-24-2007 02:06 AM |
| remote data backup | PipeGuy | Technology | 3 | 06-09-2006 08:41 AM |
| gate valve compaction tool | dayexco | Excavation & Site Work | 4 | 04-19-2006 07:46 PM |
| Help - I need some advice from equipment operators. | ann2255417 | Excavation & Site Work | 22 | 02-28-2006 07:19 PM |
