Relay Switch 1950's Burnt!
Old 02-09-2008, 07:09 AM   #1
Master Electrician
Bubbles's Avatar
Trade: Electrical
Had troubleshoot call 2 days ago. 1950's home One bathroom just went out says homeowner. Started with usually culprits and started working down the list. Well..after about an hour I knew this wasnt going to be quick one...took off to other jobs and went back next morning with the chief (dad). We lost a feed between breaker and sink light box(thats where old romex was). Finished ceilings, no access to attic above bath. I went up in attic to find a way to get above bath and low and behold an old relay box with no cover and wires looked like some sort of spider web formation. Right away I smelled burnt rubber. The whole house was booby trapped. Every box you open (1/2 didnt even have junc boxes) wires fell right out of wire nut barely twisted. So had to repair ALL (7) ones I found burnt. Finally, hidden behind the spiders lair was a load conductor burnt off at the junction of the relay. We bypassed it and shazamm. Turns out they are 15amp rated controling whole house lighting and some receptacles? A heater in the bath exhaust was the main culprit we were thinking (1800 watts heater only) plus everything else on that circuit. BTW it was on a 20 amp breaker. this wasnt even a big house or nice house. We usually only see these from affluent areas in town from the 50'/60's mostly.
Question o' day
Has anyone replaced these old touchplate systems keypads,transverters, and all. Some guys I talk to say just replace that system and the other 1/2 rewire the house considering all the other jury rigged things I saw. Seems to be 1/2 to 1/3 the cost of rewiring a house from what I can see everything considered. Of course, the numbers will make the decision.
Bubbles is offline
Old 02-09-2008, 08:57 AM   #2
mdshunk's Avatar
Re: Relay Switch 1950's Burnt!
Yes, the GE low voltage switching systems are still being installed to this day. I work on them pretty regularly. They're not really that difficult to service, technically, but the relay panels are often a mess. The relays are made by GE, and they are part number RR-7 or RR-9, depending on whether they have the aux pilot contact. Touchplate is still in business too. You can still buy all that stuff, and like I say, it's still being installed to this very day.
mdshunk is offline
Old 02-09-2008, 03:02 PM   #3
7 card stud master
james8199's Avatar
Trade: electrician
I've done a bunch of these, and usually remove the entire system. Most of the ones I've done the relay panels were fires waiting to happen and HO's wanted them replaced anyways.
"Oh, you hate your job? Why didn't you say so? There's a support group for that. It's called EVERYBODY, and they meet at the bar."
-Drew Carey
james8199 is offline
Old 02-09-2008, 05:41 PM   #4
Service & Repairs
Magnettica's Avatar
Trade: Electrician
I've come across a system like this once a long time ago. If it was an older system I'd look to eliminate it and rewire. I know there are some good new systems out there but I haven't enough experience working with them to actually sell any of them. The one I'm thinking of comes in a blue box, maybe Leviton?
Magnettica is offline
Old 02-09-2008, 05:42 PM   #5
220/221's Avatar
Trade: electrician Phoenix AZ
At least my last one wasn't in the attic. Touchplate system circa 1960.
I always recommend just yanking them and dropping line voltage sw legs.
Just because it's within code doesn't make it safe.
Just because it's against code doesn't make it unsafe.
220/221 is offline
Old 02-09-2008, 05:48 PM   #6
Master Electrician
Bubbles's Avatar
Trade: Electrical
Nice pic. I wish I had my camera. The one I was on was 6inchx20in with 20 old romex going in with sometimes 4-6 conductors under wire nuts half falling off. I think every rec,fixture,switch, we looked at trying to find problem had very loose connections as well. Probably better suggest a rewire considering previous mess. Thanks for tips..
Bubbles is offline
Old 02-09-2008, 10:05 PM   #7
Dustball's Avatar
Related thread I started-
http://www.contractortalk.com/showth...ltage+lighting
Dustball is offline
Old 02-10-2008, 08:16 AM   #8
Master Electrician
Bubbles's Avatar
Trade: Electrical
Thanks dustball. Nice thread. I'm more worried about something else in house catching fire if we just redo the LV system so in this situation I think I will suggest some ideas you had in that thread.
Once again nice thread
Bubbles is offline
Old 03-17-2008, 01:09 AM   #9
Gruff's Avatar
So, I'm moving into a home that has this ancient low voltage system, with the horizontal rocker switches - many of them are broke or don't turn on the device. Is there somewhere on-line that I can purchase these? Common sense would dictate a professional electrician check the entire system. Your assistance would be greatly appreciated. Thanks,
Gruff is offline
Old 03-17-2008, 01:46 AM   #10
mdshunk's Avatar
Any electrical supply house should be able to get these from GE for you.
mdshunk is offline
Multiple fixtures on switch loop KenHaynes Electrical 2 12-05-2007 03:15 PM
Dimmer switch blowing out glock40 Electrical 4 03-13-2006 07:54 PM
smart light switch circuit toastermaker Electrical 7 12-07-2005 11:45 PM
