Is This A Regulation In Your City? *stud Guards*
Old 07-13-2008, 09:23 PM   #1
CHI LOW VOLTAGE's Avatar
Trade: LOW VOLTAGE a/v distribution, CCTV, home & business wiring and system integration
now i use them sometimes, i had a contract at a nice suburb of chicago and my god the city is a real pain in the ass. stud guards are needed EVERYWHERE in the house. even if my wires are 3"+ in the stud where the drywallers cant get to it, guess what i need stud guards there too.
had one of my installers come to the site 3 times because the city kept finding these 'infractions'
CHI LOW VOLTAGE is offline
Old 07-13-2008, 09:49 PM   #2
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
Re: Is This A Regulation In Your City? *stud Guards*
Do you mean nail plates?
Chicago is a real difficult place I see. Must be politics central!
Speedy Petey is offline
Old 07-13-2008, 09:51 PM   #3
mdshunk's Avatar
The NEC says 1-1/4" from the finished surface. Any closer and you need a nail plate. Lord only knows what Chicago did to bastardize this code section.
Now then, if you're talking about a "boot plate" used to mend a stud that you drilled too big of a hole in, that's a horse of another color.
mdshunk is offline
Old 07-13-2008, 09:53 PM   #4
Plumber / Carpenter
Bill's Avatar
Trade: Virginia Building and plumbing contractor
Send a message via Yahoo to Bill
Ain't no telling, I have found that the code book is like a bible, depends on ones interpretation!
Is it beer thirty yet
Virginia Department of Licensing
Virginia Plumbing Codes
Bill is offline
Old 07-13-2008, 09:55 PM   #5
GregS's Avatar
Trade: Low Voltage
Good thing they are cheap and easy to install.
Does the electrician, plumber and HVAC guy have to do the same thing? Or are they picking on you?
GregS is offline
Old 07-13-2008, 10:02 PM   #6
Plumber / Carpenter
Bill's Avatar
Here in VA we plumbers do not use them, we use Stud Guards which run about 15.00 a piece
Bill is offline
Old 07-13-2008, 10:30 PM   #7
GregS's Avatar
Trade: Low Voltage
What is a stud guard vs a nail plate?
Here I buy a box of 50 nail plates, 1.5x3" for $15.
I use them for vac pipes on holes through 2x4s.. and sometimes on wire runs, but not often since I keep them out of range of the drywallers. (it only takes one screw up to learn that lesson)
GregS is offline
Old 07-14-2008, 12:15 AM   #8
Dustball's Avatar
I'm pretty sure he meant stud braces/stud shoes which wraps around the stud.
Dustball is offline
Old 07-14-2008, 08:09 PM   #9
Electrician
fridaymean's Avatar
Trade: Electrician
Funny, Usually they don't care if you use a plate if it is communications wiring, only romex. Some places will require those simpson ties if you cut too much of a bottom or top plate. Or if you hole is too large most places will require you to place one of the stud mender contraptions shown above. What burb are you talking about being a pain, Lombard?
fridaymean is offline
Old 07-14-2008, 10:54 PM   #10
GregS's Avatar
Trade: Low Voltage
Can't say I have ever seen those used here on anything by anyone.
GregS is offline
Old 07-16-2008, 06:00 AM   #11
electrical contractor
brian11973's Avatar
Trade: electrical
I heard all about $75 "nail plates" when I worked for a company a while back. Never saw them, they were for too big of a hole in floor joists.
Can some one please post a pic of a $15 "nail plate"?
Nail plates are about $15 a box. "BOCA plates" ( 4" x 6" , handy for the home runs sometimes)that the plumbers use here on top & bottom plates are about $.75 . The Simpson Stud Guards are only about $2-3.
To all of the LV guys out there. You could learn something. It would be that the Code REQUIRES ALL ELECTRIC HOLES TO BE 1 -1/4 INCHES FROM THE EDGE!!!!!!!!!!! INCLUDING YOU WORK!!!!!!!!!!!! I'm sick & tired of MY job failing because YOU have never read the Code & think it does not apply to you!
brian11973 is offline
Old 07-16-2008, 04:59 PM   #12
mdshunk's Avatar
Actually, that's not totally accurate. The holes have to be 1-1/4" from the finished surface. If you're putting on 1/2" sheetrock, the hole can be as close as 3/4" to the edge. This is a very common misconception that the actual hole has to be 1-1/4" back on the lumber itself. Read the code section for yourself, if you care to, then impress the inspectors.
mdshunk is offline
Old 07-16-2008, 06:06 PM   #13
orson's Avatar
Trade: Kitchen & Bath
You think it's a pain to put them on, imagine how much fun it is to come back through, remove them, chisel the stud out, and remount the nail plate(I actually call them "stud guards" too, not sure where I picked that name up) flush to the stud before the drywaller starts hanging.
orson is offline
Werid code rules unique to your city john5mt Framing 25 08-19-2008 12:42 AM
Ex City Dump Truck WALKER Vehicles 0 09-01-2006 03:31 AM
Question about city taxes... slowsol Business 1 03-27-2006 07:33 PM
