Trade: Union Carpenter
Recessed Lights Problem
hello everyone i just installed 8 new ic cans. 6 on one dimmer and 2 on another. added a new 15 amp circut and ran 12-2 wire to a junction box in basement and then to the switches and then to the cans. when i restore power the lights will not come on. im pretty sure my wiring is correct, i have the 2 white wires nutted together and then 1 black wire to each black wire in switch and grounds to ground. when power is on i tested all the wires and power is there but the lights will not come on anyone have an idea whats wrong with that picture thanks!
And I do electrical, too!
Re: Recessed Lights Problem
Are your dimmers turned all the way down?
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. |
Your wiring sounds correct, so you either explained what you did wrong, you didn't actually do what you thought you did, or there's another problem. Did you wire the dimmers hot, perhaps? That can blow up a dimmer in a heartbeat.
I'm concerned that what you have done might be illegal, considering your geographic location and your listed trade. |
Re: Recessed Lights Problem |
#5 | |
Re: Recessed Lights ProblemQuote:
further explanation of switch wiring as i think the problem is somewhere there since power is going to the wires in between cans:
2- 12-2 wires coming into the box splices the 3 grounds together, splices the 2 whites together and one black to one black on dimmer and other black to remaining red on dimmer. 1 wire from switch leftover for 3 way wiring that is not needed. thanks again guys |
#7 | |
Trade: Contractor
Why are you using 3-ways for this. That's your problem. Take em out and put single poles in. |
| The Following User Says Thank You to mdshunk For This Useful Post: | precisionbuild (02-01-2009) |
#10 | |
Master Electrician
Trade: Electrical
It looks like you might be sucessfully switching the traveler back and forth? lol
You got a meter? |
The black should go to you power that feeds the switch. One red should go to the black wire that goes to the lights.
Master Electrician
Trade: Electrical
just touch the black to black and bypass switch and see if they flick on for a test.
Not the black leads on the switch.. the blacks that feed the switch. In other words, bypass the switch and see if the lights come on.
#18 |
How are you 'checking' for power?
#19 |
| Solved the lighting problem in my van! | gury | Vehicles | 5 | 01-30-2009 12:09 PM |
| recessed lights | Boycer88 | NEC Discussion | 2 | 01-25-2009 04:38 PM |
| cutting holes in aluminum soffit for can lights | buckeyeso2 | Windows, Siding and Doors | 18 | 08-26-2008 01:59 AM |
| metal halide lighting problem | 72chevy4x4 | Electrical | 1 | 08-15-2008 05:20 PM |
| Installation Of recessed lights | Morry | Electrical Picture Post | 20 | 07-20-2007 09:56 PM |
