Recessed Lighting In A Kitchen
Old 10-06-2009, 01:30 PM   #21
Ohmy's Avatar
Trade: Electrical Contractor
Re: Recessed Lighting In A Kitchen
Originally Posted by bert0168 View Post
We usually put them just off the edge of the countertop. This way as you stand at the top you won't cast your shadow on the work surface.
Just my .02
Ditto on this suggestion. We try to put ours right on the end of the countertops unless there is structural issue (90% of our installations are remodel). I have noticed many kitchens with recessed lights way to close to the uppers and 1/2 way over them. It puts a nasty glare on the uppers and you don't get good light into the room.
Ohmy is offline
Old 10-06-2009, 01:36 PM   #22
Ohmy's Avatar
Originally Posted by 220/221 View Post
I have been using Counter Attacks halogen/zenon. They throw a lot of light but it is coming from 10" out from the wall, 20" above the top and I am working at about 20" from the wall.
There are 2 schools of thought on lighting design.
Some of my customers seem to think they will look up at the ceiling. For them, I will line everything up as proportionally as I can. For those who ask me to do what's best, I will put the light where it's needed. In an ideal world, the two methods will coincide.
I agree with 220/221, second school of the thought is much better. Why put a light in the ceiling that isn't where you need it. Also, recessed lights go a much longer way towards lighting countertop space then UC lights. UC lights are great but they don't get turned on as often as they should and do little for your main work spaces (sink, stove top, and island).
Ohmy is offline
Old 10-12-2009, 02:19 PM   #23
Phillip Marsh's Avatar
Trade: builder
If you look at the picture Angus242 posted you will see 3 different types of lights being used with pendants, cans, and under cabinet lights. If you are redoing your kitchen and will have bare walls to work with the labor will be low and the cost of the fixtures is trivial in the overall scheme of things.
And you are doing this for cosmetic reasons anyway as your old kitchen worked for cooking. Better lighting will make the woman using it happier and will do a lot more for showing off the kitchen when you decide to sell your house. Not a smart place to cut corners.
Phillip Marsh is offline
Old 10-14-2009, 12:33 AM   #24
Electrosexual
Zinsco's Avatar
Here's something I sometimes do with under cabinet fluorescent lights, I get "Gels" from the theatrical lighting and grip store in Hollywood. Gels are basically colored sheets of cellophane. You can get all kinds of great colors that will really make the counter tops come alive. I had a customer with salmon colored tiles, I got light salmon colored gels, cut them and laid them in the plastic lens and the result was much warmer than the typical cool or warm white lamp.
Zinsco is offline
Old 10-15-2009, 05:46 PM   #25
Immanuel's Avatar
Trade: Electrical
Just make sure you use actual lighting gels ... they are heat resistant , colored cellophane is not (and can melt ... or catch on fire) Usually they come (depending upon where you buy them from) in sheets 3' x 2'.
Immanuel is offline
Old 10-15-2009, 05:48 PM   #26
And I do electrical, too!
480sparky's Avatar
They (gels, not the cellophane) will wrinkle from the heat, but that's normal.
Site : the area or exact plot of ground on which anything is, has been, or is to be located.
Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision.
Cite : To mention in support, proof, or confirmation; refer to as an example.
480sparky is offline
Recessed lighting for shallow ceiling? Chris G Electrical 16 12-02-2009 04:44 PM
Google Seminars For Success... Ivinni Marketing & Sales 193 02-07-2009 08:22 PM
Kitchen lighting? wraiths Electrical 8 10-27-2007 03:44 AM
recessed lighting clearance skidmark845 Electrical 6 07-09-2007 12:02 PM
Installing new lighting in kitchen (Besa) pitterpat Electrical 10 12-30-2006 08:50 PM
