Quick Service Question
Old 06-25-2008, 01:34 PM   #1
Vermaraj's Avatar
I have a quick question for the sparkys:
For a new house, 400A (nominal) underground service, outdoor meter main w/6 service disconnects.
Can a load center located in the basement be fed by conductors run under ground in a conduit? Can this conduit run beneath the garage floor?
The answer seems obvious, but I have never seen it done before. We are doing a preliminary layout on a new house so I haven't got a sparky lined up yet.
Thanks,
Verm
Vermaraj is offline
Old 06-25-2008, 05:12 PM   #2
mdshunk's Avatar
Re: Quick Service Question
Yes, they sure can. No problem. Matter of fact, if the pipe is going to be below at least 4 inches of concrete, there's no minimum burial depth. The pipe can be just below the slab. Functionally, you'll want it deeper than that so that your sweep 90 up to the panel inside will be substantially underground and just have the vertical part sticking up.
mdshunk is offline
Old 06-25-2008, 06:02 PM   #3
listen twice talk once!
Bkessler's Avatar
Trade: electrician
I thought it was only 2 inches of concrete
Bkessler is offline
Old 06-25-2008, 06:09 PM   #4
Service & Repairs
Magnettica's Avatar
Trade: Electrician
I heard 8 feet!
Magnettica is offline
Old 06-27-2008, 09:31 PM   #5
Waco's Avatar
Trade: Electrical
Not to put too fine a point on it, but with a disconnect feeding the panel being fed beneath the slab, I think the conductor is handled like any other branch circuit . I think four inches of concrete is required if the wiring is to be considered "outside" the structure such as might be the case if it was a service cable going to the first main breaker well inside the structure.
I'm not going to look it up, but I wouldn't hesitate to run conduit under the slab for a subfeed.
Waco is offline
Quick question about durarock. A+Carpenter Ceramic & Stone Tile 4 04-22-2008 09:17 PM
Quick question for you guys 98mustangguy Ceramic & Stone Tile 1 03-16-2008 01:45 PM
Quick Question on how you would charge... DNJ6357 Framing 1 07-06-2007 02:15 AM
Service upgrade question ATS Electrical 17 09-05-2006 09:48 PM
Quick question maj Site Help and Suggestions 4 05-16-2006 07:31 AM
