Quick Question
Old 03-03-2012, 08:50 PM   #1
Roscoe's Avatar
Quick Question
I'm not an electrician so i'm asking some. Is it still possible to get shocked while you are installing recepticals while they are hot even if you are wearing rubber soled boots? Since you aren't grounded.
Roscoe is offline
Old 03-03-2012, 08:52 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Re: Quick Question
Yes.
Tinstaafl is online now
Old 03-03-2012, 08:54 PM   #3
Roscoe's Avatar
Re: Quick Question
Thanks. Because the panel is grounded?
Roscoe is offline
Old 03-03-2012, 09:00 PM   #4
TNTSERVICES's Avatar
Trade: General
Re: Quick Question
All you need to do is ground yourself while holding the hot. Ever touch a screwdriver to the box when you were screwing the terminal down? BOOM! Same thing if you touch the wire and the box. You have completed the circuit.
Tried & True on Facebook
Tried & True Website
Superior-Sheds Website
Originally Posted by maninthesea View Post
Instructions are just the manufacturers opinion
TNTSERVICES is offline
Old 03-03-2012, 09:05 PM   #5
Capra aegagrus
Tinstaafl's Avatar
Re: Quick Question
Because you might inadvertently contact hot and neutral (or ground) at the same time.
Experience will acquaint you with the various scenarios that can come into play, hopefully non-fatally. Or you could spend a few less years learning the theory of electrical circuitry and spare yourself much of the uncertainty and pain.
I Mester (03-03-2012)
Old 03-03-2012, 09:06 PM   #6
Roscoe's Avatar
Re: Quick Question
Got into a disagreement with a guy today while putting some plugs in. He said he only got shocked because he was sitting on the ground on not standing on he feet. I told him that if he didnt believe me to stand up and touch it but he wouldnt.
Roscoe is offline
Old 03-03-2012, 09:16 PM   #7
Trade: General
Re: Quick Question
Or just flip the breaker off?
The Following 3 Users Say Thank You to TNTSERVICES For This Useful Post:
72chevy4x4 (03-10-2012), CCCo. (03-03-2012), J M J (03-31-2012)
Old 03-03-2012, 09:21 PM   #8
Roscoe's Avatar
Re: Quick Question
I suggested that but he's a know it all and said it wouldnt shock him. He doesn't work for me or it would have been off for sure.
Roscoe is offline
Old 03-03-2012, 09:25 PM   #9
Construction Connoissuer
CCCo.'s Avatar
Trade: Construction Remodeling - Renovations Repairs
Location: Kirklin, IN "Proudly Serving Central Indiana Area"
Re: Quick Question
Rule #1
You don't change receptacles hot
Hell yes you'll get shocked and it's not a fun experience
Tell the guy that you got into in a disagreement with to pound sand and kill the power
You don't need an electrician to answer this either, just a little common sense
James Crow - Crow Contracting Company - Central Indiana Remodeling Contractor
Facebook l Youtube l Merchant Circle
Home, Kitchen & Bath Remodeling - ~ - Facility Maintenance & Repair Solutions
Want to contact us? - Email ~ james@crowcontractingco.com - Or Call ~ 765.279.8271
CCCo. is offline
Old 03-03-2012, 09:28 PM   #10
Roscoe's Avatar
Re: Quick Question
I guess I must have a little common sense since I was right.
Roscoe is offline
Old 03-03-2012, 09:28 PM   #11
summithomeinc's Avatar
Trade: Home Improvements/Handyman Services
Re: Quick Question
If you want to take the wires out of the back of a swich when they are the push in kind....It's a bad idea to leave the power on and use a spade bit to push in the back of the switch
I need more tools.
summithomeinc is offline
Old 03-04-2012, 10:49 PM   #12
Da Grump
plummen's Avatar
Trade: plumbing/electrical/hvac
Re: Quick Question
Originally Posted by CCCo. View Post
Rule #1
I change plugs out hot all the time.
But Im gifted,or is that touched or maybe its a little of both!
plummen is offline
The Following User Says Thank You to plummen For This Useful Post:
svronthmve (03-04-2012)
Old 03-07-2012, 11:21 PM   #13
Chief Infidel
Irishslave's Avatar
Re: Quick Question
Rubber screwdriver blade?
Governments view of the economy can be summed up in a few short phrases: If it moves, tax it. If it keeps moving, regulate it. If it stops moving, subsidize it--Ronald Reagan
Irishslave is offline
Old 03-21-2012, 09:19 PM   #14
ThomasElectric's Avatar
Trade: Electrical
Re: Quick Question
A. You were installing receptacles. "Plugs" are on the ends of cords.
B. Just the fact that you had the conversation in this little story tells me neither of you are qualified to be doing this work.
ThomasElectric is offline
The Following 2 Users Say Thank You to ThomasElectric For This Useful Post:
jb4211 (03-21-2012), TNTSERVICES (03-22-2012)
quick question about poured concrete basement walls eurovw89 Framing 16 02-07-2012 09:05 PM
quick question for NJ contractors s&mll Decks & Fencing 14 06-04-2009 04:41 PM
Quick question for you guys 98mustangguy Ceramic & Stone Tile 1 03-16-2008 12:45 PM
quick question sdc1 Roofing 1 02-23-2008 01:35 PM
