Trade: sr custom electric
Questions
2 quetions. one what do i tell my customers about why they need to have a range and dryer receptacles changed to four wire?
2. Why do they need arc faults? |
#2 | ||
Re: QuestionsQuote:
Interior Remodeling
Trade: Interior Remodeling
Re: Questions
MDSHUNK,
When you say arc faults what do you mean by that, I'm not too up to date on my electric (Exp./code wise). Could you explain what that means so can take a mental note on it
Electrician
Re: Questions
A arc fault circut in a nut shell knows your getting stray curent before you even fell it. If a child was to put a paper clip in the outlet the arc faultwould trip before the child was shocked
Interior Remodeling
Re: Questions
Is it like a GFCI breaker? Same concept?
#6 | |
Re: QuestionsQuote:
210.12 Arc-Fault Circuit-Interrupter Protection. (A) Definition. An arc-fault interrupter is a device intended to provide protection from the effects of arc faults by recognizing characteristics unique to arcing and by functioning to de-energize the circuit when an arc fault is detected. (B) Dwelling Unit Bedrooms. All 120-volt, single-phase, 15- and 20-ampere branch circuits supplying outlets installed in dwelling unit bedrooms shall be protected by a listed arc-fault circuit interrupter, installed to provide protection of the branch circuit. Exception No. 1: The location of the arc-fault circuit interrupter shall be permitted to be at other than the origination of the branch circuit in compliance with (a) and (b) (a) The arc-fault circuit interrupter installed within 1.8 m (6 ft) of the branch circuit overcurrent device as measured along the branch circuit conductors. (b) The circuit conductors between the branch circuit overcurrent device and the arc-fault circuit interrupter shall be installed in a metal raceway or a cable with a metallic sheath. [ROP 2–134a] Exception No. 2: AFCI protection shall not be required for an individual branch circuit supplying a dedicated outlet for life support equipment in dwelling unit bedrooms. Such receptacles shall be marked “Life Support Equipment Only.” FPN: For information on types of arc-fault circuit interrupters, see UL 1699-1999, Standard for Arc-Fault Circuit Interrupters. Notice that this applies to all 120 volt, 15 and 20 amp outlets in bedrooms. An outlet is not just a receptacle. The code defines an outlet as: Outlet. A point on the wiring system at which current is taken to supply utilization equipment. This means that all 120 volt, 15 and 20 amp receptacles, lights, smoke detectors, etc. in a bedroom need AFCI protection. The exception is for life support stuff like an oxygen generator or IV pump. There are commercially available receptacle covers that are embossed “Life Support Equipment Only.” You don't need to AFCI, for instance, a 220 volt air conditioner receptacle, because it isn't 120 volt. |
Electrician
Re: Questions
Same thing
Re: Questions
An AFCI is different than a GFCI, but an AFCI does offer some level of GFCI protection. Confused yet?
A GFCI will only detect faults between either the hot and the ground, or the neutral and the ground. A GFCI will trip at 6 milliamps of imbalance to provide protection of people. An AFCI will also detect the same faults as a GFCI, but will trip at 30 milliamps to provide protection of equipment only. This trip level is way too high to ever protect people the way a GFCI will. Also, unlike a GFCI, an AFCI contains additional electronics that detect certain disturbances in the sinusoidal waveform of the AC power, unique to arcing and sparking type faults. As a result, AFCI's, unlike GFCI's, will trip under arcing circumstances too. |
Interior Remodeling
Re: Questions
So, if I were to change just outlets out in a bedroom, I would also need to change the breaker to that room to a AFCI breaker to keep up with code? If so, just one more thing to get paid for
#10 | |
Re: QuestionsQuote:
You may run into trouble... The typical AFCI will protect a single circuit, that is a single 14-2 or 12-2 cable. Before AFCI's came on the scene, it was normal for bedroom circuits to leave the panel as a multiwire circuit. Two circuits on one 14-3 or 12-3 cable to serve several areas. If this bedroom you intend to AFCI protect is served by a circuit that is in a 14-3 or 12-3 cable, you need to use a double pole AFCI breaker. These are darned expensive, and Cutler Hammer is the only manufacturer making them at the present time as far as I am aware. A normal AFCI breaker would run around 40 bucks. The last double pole AFCI that I bought was $154 dollars at the wholesale house. Do your homework by looking in the panel before you jump at upselling AFCI's where they otherwise wouldn't be legally required. You can (and I have) upsold people on AFCI protecting every 120 volt circuit in the entire panel. This is an easy $1000 profit for an electrician for not too much work. |
Interior Remodeling
Re: Questions
Why do they not just make it code to just have all breakers GFCI'd to protect the whole house from human shock, Also would doing this "child proof" the outlets?
I'm just stirring the:
Trade: .
Re: Questions
part of the reason not to GFCI everything is because things like refrigerators and such can play hell with GFCIs. If you are on vacation and your fridge pops the GFCI you get to come home to a lot of rotten food, a flood in your kitchen (maybe) and a lot of cursing.
Memorable Places - My little home on the web Member of the White Knights Of Contractor Talk |
#13 | |
Re: QuestionsQuote:
#14 | |
Re: QuestionsQuote:
Make this mental note... if you're on a service call for a faulty freezer receptacle, don't open the freezer no matter how curious you are. The smell of 200 pounds of rotten deer meat and several dozen rancid trout will stick with you for quite some time.
Interior Remodeling
Re: Questions |
#16 | |
Electrical Contractor
Trade: Electrical
Re: QuestionsQuote:
Remodeler
Re: Questions
I take it there are no arc fault products available at the point of use (duplex style) like GFCIs?
#18 |
Trade: Electrical Contractor
Re: Questions
Not yet, but I am sure they are coming!
We are the people (our parents warned us about) (Jimmy Buffett) |
#19 | ||
Re: QuestionsQuote:
| Lots of questions about drywall and bathrooms | nobody | Drywall | 30 | 11-27-2008 01:33 PM |
| Few questions for a Handyman or Contractor in VA | ButlerDesigns | Business | 5 | 05-22-2008 12:12 PM |
| I'm new and i have questions... | Jadzu | General Discussion | 2 | 08-25-2006 07:03 AM |
| Qualifing Questions For Customers | dfwhomeremodele | Marketing & Sales | 19 | 03-22-2006 01:15 PM |
