Question For The REDI-KILOWATTERS
Old 09-07-2008, 02:32 PM   #1
JonM's Avatar
How does this work for the entire house if it is connected to just one breaker and the bus bar?... http://www.lightningrodparts.com/surge.html
JonM is offline
Old 09-07-2008, 02:46 PM   #2
mdshunk's Avatar
Re: Question For The REDI-KILOWATTERS
That product is called a TVSS (Transient Voltage Surge Supressor) or "panel protector" for slang. To put it in simple terms, it's connected to the panel bus, and the ground wire. When it senses a surge event, it "opens a gate" and permits the surge voltage to flow as freely as possible to the earth. Will stuff in your house still get blown up? Potentially, yes, but this will give your gear a fighting chance. Everyone should have one. They are no substitute for point of use surge supression at your computers, entertainment gear, etc. The panel protector just lets more of the surge voltage go to the earth and less through your home's wiring. Without it, all the lightnig is blazing through the home's wiring, reaking havoc.
The one's from StediWatt are the finest, but the SyCom one you linked to is certainly quite respectable. Most of the panel manufacturers (Square D, Cutler Hammer, etc.) make one that plugs on just like a breaker, only it has no handle. Just indicator lights.
mdshunk is offline
Old 09-07-2008, 03:09 PM   #3
JonM's Avatar
Thank you for making it clear.......have a cookie..
JonM is offline
Old 09-07-2008, 03:29 PM   #4
We are no longer required
to pay for electrical opinions
in pies.
neolitic is offline
Old 09-07-2008, 04:13 PM   #5
Master Electrician
Bubbles's Avatar
Trade: Electrical
We have had about 5-10 lightning damage calls over last couple years. In almost all the cases the HO had most of the items previously mentioned. But, in almost all the cases but one the lightning bolt went through roof, hit branch conductor and backed up on it blowing everthing up in most cases (dishwasher, electronics, clocks even,) all those things are nice and everything if you have money to afford them all, but, in my opinion the best solution is unplug ( and put the plug far from rec.) all the top dollar valuables in all storms if possible.
good luck
Bubbles is offline
Old 09-07-2008, 05:34 PM   #6
JonM's Avatar
Is something like this any better?....
http://www.growtron.com/Hubbell-Brya...20HBL65MPC.htm
JonM is offline
Old 09-07-2008, 05:48 PM   #7
mdshunk's Avatar
Just the same thing, in a different place. You'd have to get permission from the power company to use one like that in the meter socket, and 9 chances out of 10, they won't let you.
mdshunk is offline
Old 09-08-2008, 01:32 AM   #8
listen twice talk once!
Bkessler's Avatar
Trade: electrician
Which would be good for a Zinsco 100 amp resi ,(vertical bus)?
Bkessler is offline
Old 09-08-2008, 07:07 AM   #9
Capra aegagrus
Tinstaafl's Avatar
Replacement.
Tinstaafl is online now
Old 09-08-2008, 05:31 PM   #10
mdshunk's Avatar
Replacement.
mdshunk is offline
Old 09-08-2008, 07:44 PM   #11
Electrical Contractor
jbfan's Avatar
Trade: Electrical Contractor
My poco has the same thing that they will install for about $7.50 a month, but will not let you install one.
We are the people (our parents warned us about) (Jimmy Buffett)
jbfan is offline
Old 09-10-2008, 10:04 PM   #12
Union Electrician
Sparky Joe's Avatar
Trade: Inside Wireman
Does the power company then also gaurantee it's protection?
Sparky Joe is offline
Contractor law question for california contractors saucedo80 Painting & Finish Work 7 04-18-2009 01:07 PM
Answer a Question with a Question Nathan Off Topic (Non Trade) 151 10-07-2008 03:07 PM
HVAC Licensing question kdan General Discussion 2 08-25-2008 09:17 AM
