Trade: Framing
Question About Gage
I know this has been talked about other threads but have a similar question.
I have been doing some sub/pick up work framing a garage on a one acre lot. The garage is about 300' or so from the house and main electrical box. The electrician did not start until I was after the job and I have not had time to stop by and ask him. What size gauge wire or wires would you run from a main electrical box to a garage like this? The purpose was a back shed not to be used all the time. I am not looking for anything exact just wondering what would be used? Like water can loose pressure over long distances, does this happen with electricity too. Any ideas?? Thanks, Mike |
woodchuck2
Re: Question About Gage
Need more info like the size service you are putting in the garage. Is it an overhead or direct burial, Is there a dis-connect that may be closer, what size panel is in the home, what size is the service feeding the home?
#3 | ||
And I do electrical, too!
Re: Question About GageQuote:
Yea. Give your electrician the information he needs and let him worry about it.
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. |
Yes, it's called voltage drop. Your electrician should be accounting for that.
220...221...whatever it takes! |
Master Electrician
Trade: Electrical
I usually run 750 MCM Cu to be safe.
First you do a load calculation, then a voltage drop calculation. The electrician won't have any problem with those calculations.
www.TigerElectrical.com |
Trade: Construction
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractor's to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs. Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.diychatroom.com/register.php/ We apologize for any inconvenience that this may have caused. This thread has been closed. |
| The Following User Says Thank You to BuiltByMAC For This Useful Post: | rselectric1 (12-12-2009) |
| Question from lawyer trying to help contractor | scp | Business | 52 | 02-25-2011 01:23 AM |
| Contract question | MACEXCAVATING | Excavation & Site Work | 4 | 12-20-2008 09:24 PM |
| HVAC Licensing question | kdan | General Discussion | 2 | 08-25-2008 09:17 AM |
