Problem Or Not?
Had to do some service on a spa to day, and the Patio outlet was dead ("hasn't worked for a year or two"). Took old GFI out of panel, and it was just plain sloppy/worn out. No shorts, put in new 15a breaker and GFCI outlet, all's well. But the A/C breaker is right above it 30a. It's got old #12 woven sheath romex with #16(?) ground for neutral. Is that cool or should I tell HO to call sparks to run new?
DISCLAIMER: I want no part of this, I just wanted power for my work. Though I will admit that I also put the cover back on the panel after they dug it out from under the workbench.
Trade: Electrician
Re: Problem Or Not?
I would with out a doubt tell them there's a problem with the correct wire size connected to a breaker that can over load that wire. ( #12 is good for 20a on branch circuits) are you sure its a 16 awg neutral? If its just a normal 12/2 non metallic sheathed wire. You could just change it to a 20a breaker if the AC. Unit doesnt call for more then 20 amps? Is it a 2 pole breaker? Sounds like it should be looked at. Yes it would be nice to notify the home owner. Your a nice guy right?
Re: Problem Or Not?
Yeah it's 30a, 220 double pole, for A/C compressor. 12-2w/grnd romex, but the old stuff with the little ground wire. 16 is a guess, but it's not a guess that it's smaller than #14.
Put your location in your profile! (Sorry....it seems there really are dumb questions) Last edited by neolitic; 11-01-2007 at 12:14 AM. |
Re: Problem Or Not?
The reduced size ground was featured in romex before 1967. It is not a problem, and no corrective action is necessary. It only has to carry fault current for a second (long enough to trip a breaker). The #12 on a 30 amp breaker for an air conditioning condensing unit is probably fine too. There's exceptions for air conditioning equipment in the code that will permit the breaker to be upsized a bit, when compared with wire gauge, to prevent the breaker from tripping while the compressor is starting.
#5 | |
Re: Problem Or Not?Quote:
Don't want to make trouble that isn't, but can't seem to let stuff pass that might be a problem. This kind of thing I know, that I don't know.
Trade: Residential Remodeling
Re: Problem Or Not?
Shouldn't he read the label on the A/C equipment and make sure?
#7 | |
Trade: Electrician
Re: Problem Or Not?
No, because he's not the F-ing electric police. It's not even his house. This can be a totally proper installation, and that's about all the casual observer (which is what he is) needs to know. If he was an inspector of some sort, or if his work concerned this particular equipment, then he might need to know more.
#9 | |
Al Smith
Trade: Electrical
Re: Problem Or Not?
That exception was for the older breakers, that were not HVAC rated. best to get a pro to look it over.
Trade: Electrician
Re: Problem Or Not?
i guess at first sight, a 12 hooked to a 30 amp breaker would be my concern in a resedential home. Not factoring in what mr shunk said in regrads to the bible itself. I guess i dont know that because i have yet to run across a situtation like this. I need to read more i suppose.
Electrician
Trade: Electrician
Re: Problem Or Not? |
Service & Repairs
Trade: Electrician
Re: Problem Or Not?
I wire condensing units based on minimum ampacity and maximum overcurrent protection.
Trade: electrician Phoenix AZ
Re: Problem Or Not?
Heh heh...md said the F word TWICE.
I guess I'm f...ing rubbin off on him. |
#16 | |
Al Smith
what are the Amish doing with electricity anyway? Thought that was verboten!Just kidding
Trade: electrician
| Ventilation problem with an indoor pool | frostbitten1 | Roofing | 10 | 05-27-2009 09:16 PM |
| Heat Exchanger Problem with Hayward Pool Heater | jtc1062 | HVAC | 2 | 10-22-2007 10:13 PM |
| Well problem | paintr56 | Plumbing | 10 | 02-09-2007 09:20 AM |
| Strange Fly Problem | johnnymac | Plumbing | 4 | 09-07-2006 02:30 PM |
| Electrical problem? | Brian | Electrical | 5 | 12-27-2005 11:16 AM |
