Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Electrical
Old 01-05-2006, 08:30 PM   #1
Trade: master electrician
Question prob with dimming lights
i'm having a problem with lights dimming at a costumer's house when the a/c compressor kicks on. he has a 200 amp panel with 4/0 alum. feeders. the compressor only draws about 25 amps on start-up, has a 45 amp breaker and #6 cu feeding it. i've checked all connections and nameplates - everything looks fine. any ideas or answers would be appreciated...
greenley is offline   Reply With Quote
Old 01-05-2006, 08:47 PM   #2
mdshunk's Avatar
Yup. Some compressors can draw hundreds of amps for a split second while they are starting. Some winking of the lights can be considered normal, but not desirable. You'll want to check the main lugs in the panel, lugs in the meter, the aerial drop tap, and the transformer secondary tap. If these check out, installing a "soft start kit" on the compressor unit will solve the winking light issue. Every manufacturer offers a soft start kit for their units, or generic soft start kits (from manufacturers like SUPCO) can be installed.
mdshunk is offline   Reply With Quote
Old 01-06-2006, 10:56 AM   #3
re
thanks for the advise md - i'll look into it...
Installation Of recessed lights Morry Electrical Picture Post 20 07-20-2007 08:56 PM
Digging Under The Lights? denick Excavation & Site Work 9 02-28-2007 06:52 AM
cans vs conventional lights / ceiling fans williefb Electrical 6 02-17-2007 10:13 PM
12 volt lights Bkessler Electrical 1 03-08-2006 06:36 PM
dimming lights in house Unregistered Electrical 4 02-16-2004 04:55 PM
