Practical Discussion About Bus Duct
Old 08-24-2009, 07:41 AM   #1
ricky001's Avatar
Trade: electrical control panel
Wink
A conversation on electrical bus duct is influenced and biased by the experience and expertise of the individuals
There is service bus, feeder bus, and plug in bus duct. Service bus duct typically takes power from the main outdoor transformer to the main indoor switchboard. Feeder bus typically takes power from the main switchboard to another area of the facility. Plug-in bus duct distributes power in an area by allowing you to tap into the bus duct, using bus plugs that feed individual machines, motors, panels, disconnects, etc. In this discussion, we are mainly talking about plug-in bus duct and bus plugs.
Do you want a centralized distribution system or a de-centralize system? An example of a centralized system would be a 1200 amp panel board with 12 molded case circuit breakers sized between 100 amps and 600 amps. Each circuit breaker powers a feeder to an individual machine, disconnect, motor, or sub panel. So there are 12 conduits coming out of the 1200 switchboard and going to 12 separate loads. A decentralized distribution system would be a 1200 amp bus duct going from the main 1200 amp switchboard, right through the middle of a production area, hanging from the trusses, and having 12 bus plugs attached to it. Each bus plug is used to feed 12 separate loads, such as a 225 amp panel, a 25 hp motor. 4 molding machines, a step down transformer, and four other production machines spread around the production area. Instead of 12 feeders from the main switchboard, there would be one bus duct and 12 short drops, i.e. feeders, from overhead bus plugs, attached to the bus duct.
ricky001 is offline
Old 08-24-2009, 09:03 AM   #2
You did what??
J F's Avatar
Re: Practical Discussion About Bus Duct
Nice to meet you too.
J F is offline
Old 08-24-2009, 01:23 PM   #3
Jim M's Avatar
Trade: Electrical Contractor
This guy is apparently spamming all the boards. He posted this drivel at a home inspectors site too.
Please shut him down.
Jim M is offline
Old 08-25-2009, 10:11 AM   #4
woodchuck2
woodchuck2's Avatar
Is he trying to impress us with his great knowledge or something . Hell, i can copy and paste too , would that make me seem smarter .
woodchuck2 is offline
Old 08-26-2009, 07:36 PM   #5
ampman
ampman's Avatar
Trade: providing pathways for electrons and protons
he is smoking the "blue smoke"
an army of sheep lead by a lion will defeat an army of lions lead by a sheep
ampman is offline
Best way to Install 6" duct swp4lfe HVAC 1 08-14-2009 10:55 PM
Insulating duct work john916 HVAC 4 02-19-2009 07:38 PM
duct design and adding on questions 72chevy4x4 HVAC 4 01-20-2009 10:45 PM
Metal ducts or Flexible duct in use? Charlot HVAC 2 10-30-2008 04:52 AM
un wrapped duct work ofourcobra HVAC 10 09-26-2008 08:29 PM
