Power From Meter Box
Old 09-20-2007, 09:15 PM   #1
Joetexx's Avatar
Trade: Windows, Siding, Roofing
I'm working on a house that has no electric or meters in there sockets....but there is hot juice coming from the pole to the meters....
I used alagitor clips and an extension cord to connect to the hot side of the meter box and then plugged in my battery chargers and blew them up....
i want to be able to use my air compressor, so how do i connect the compressor to the direct hot line coming into the house...
any suggestion would be helpfull....joe
Joetexx is offline
Old 09-20-2007, 09:23 PM   #2
Electrical Contractor
Speedy Petey's Avatar
Trade: Electrical
Re: Power From Meter Box
I really don't mean to be nasty, but as Nelson Muntz would say...HA HA!
You have NO place messing in a live meter pan. Good for you that all you blew up was a couple of chargers. Hopefully that is all it took to convince you not to mess around where you DO NOT belong. The consequences could have been MUCH worse!!!!!
What you did was hook them up to 240v instead of 120v, and I for one will not give you details how to do something HIGHLY illegal.
CALL AN ELECTRICIAN and get this hooked up legally and safely.
Speedy Petey is offline
Old 09-20-2007, 09:43 PM   #3
Fentoozler
Celtic's Avatar
You get what you pay for.
You stole the power...I'd say you and the POCO are even ~ they might not though.
#1 suggestion:
Stick to what you know.
You're lucky you are able to confess your crime tonight....as opposed to having your next of kin making funeral arrangements.
Call a qualified electrician before you kill yourself or someone else!
Celtic is offline
Old 09-20-2007, 09:53 PM   #4
Union Electrician
Sparky Joe's Avatar
Trade: Inside Wireman
Wouldn't it be nice though if he got double the voltage from his batteries, and they never needed a recharge again because the power was free.
Sorry in advance for acting silly
Sparky Joe is offline
Old 09-20-2007, 09:55 PM   #5
Fentoozler
Celtic's Avatar
How To Save Money On Batteries
Celtic is offline
Old 09-20-2007, 10:51 PM   #6
L. B. Condulet's Avatar
Trade: Super Electrician
Everybody should have one of those little gas powered generators. They've gotten cheap enough that they are just another power tool.
L. B. Condulet is offline
Old 09-21-2007, 12:03 AM   #7
Repair/Remodeling Tech.
jproffer's Avatar
Trade: Repair and Remodeling Services
If only that were true
Some brands might have 32 AA batteries in them, but not all...because I took one apart at work today...no go...sorry. Just had 4 big cells inside, similar to the second video.
BTW...what he says at the end...is pretty much what I said. But really I didn't care...wasnt my battery
Jim P.
jproffer is offline
Old 09-21-2007, 12:16 AM   #8
Fentoozler
Celtic's Avatar
ssssshhhhhhhhhhh
Celtic is offline
Old 09-21-2007, 02:04 AM   #9
Union Electrician
Sparky Joe's Avatar
Get your cheap skate electrical contractor or general contractor to set up some damned temporary power at the site. Surely they must realize these aren't the dark ages and it takes power tools to get a job done.
And do not think that just because the power is on the side of a house that it's governed like a house. I'm not sure what the primary main switches are rated on a power line, but it's a whole hell lot more than any kind of power you've ever seen. Or perhaps a "life lesson" is what's needed in some people's cases.
So many times people feel an electric shock and say "that wasn't so bad", but have no clue what an electrical explosion can do. If it doesn't implode your chest from the compression or make you deaf, or give you cataracs 3 years down the road, it will definetly melt the skin from your hands and face at temperatures 5x hotter than the sun(35k farenheit).
DO NOT ever stick your hands or tools or clips or whatever inside a meter socket
Old 09-21-2007, 05:51 PM   #10
Electrician
fridaymean's Avatar
Trade: Electrician
Ask an electrician to jumper the socket. Around here they really do not care if you move the lines yourself and put in a temp service. (like when they tear down a house and rebuild a bigger one in its place) Some villages/munis want you to get an inspection, but once they know you, they don't mind if you do it and get it inspected when the new service is put on the new house. Then the poco comes and installs new, or move the old lines back over.
The power company does not care if an electrician jumpers the socket. They will even come out and jumper for you. I belive they do charge a flat rate when the meter is not installed though for the electricity you use.
fridaymean is offline
Old 09-21-2007, 06:56 PM   #11
Andy in ATL's Avatar
Trade: electrician
Although a Ga. power lineman gave me a set of meter jumpers he made it VERY clear to only use them to test a house after trim out and don't let GA power catch me using them.Much easier than my other method of jumping the meter. The perfect tool for the perfect job.
Andy in ATL is offline
Old 09-21-2007, 09:11 PM   #12
MSSI's Avatar
Trade: Electrician
Dont hook up a 120v charger to 240V via the meter socket
MSSI is offline
Old 09-22-2007, 06:04 PM   #13
BigMikeB's Avatar
Trade: HVAC
Take a pair of car booster cables, hook one lead to each of the top meter connectors and the other ends to your nuts while standing in water.
BigMikeB is offline
Old 09-22-2007, 08:17 PM   #14
MFWIC
Tmrrptr's Avatar
Trade: house painter
Years ago I rented out a piggyback temp panels for a buck a day plus a charge for install & pickup. Don't think they're legal anymore.
r
Tmrrptr is offline
Old 09-23-2007, 09:30 PM   #15
Old School Marine
randomkiller's Avatar
Trade: Union Journeyman Electrician
You forgot he needs to put on his PPE first including flash shield
randomkiller is offline
Old 09-23-2007, 10:19 PM   #16
Fentoozler
Celtic's Avatar
All geared up and ready to go, SIR!
Celtic is offline
Old 09-23-2007, 10:42 PM   #17
Old School Marine
Aye aye captain videoooo!
Old 09-29-2007, 07:24 PM   #18
220/221's Avatar
Trade: electrician Phoenix AZ
Where's that, cause I'm movin!
220/221 is offline
Old 10-01-2007, 06:11 PM   #19
Kingfisher's Avatar
Easy way is buy a 400w converter from HD/lowes for $30 plug it into your truck then plug in any brand battery charger or any other house hold iteam. Lot cheaper than $90 for a single brand car charger. Just don't charge more than one battery without letting the truck idel for 5 min. or you be sorry RRRRRRerrrrerree learned that the hard way lucky it was a stick
Kingfisher is offline
Old 10-02-2007, 07:42 PM   #20
Fentoozler
Celtic's Avatar
Originally Posted by zekideguito View Post
Hello,
As I suggest do not use alligator clip, its danger specially if your load are big.
Actually, it's a danger regardless of the load.
Celtic is offline
Power Rollers.... MarvinWilleyJr Painting & Finish Work 15 09-14-2007 10:12 PM
Solar Power Industry Dead In California w6ire Electrical 2 06-28-2007 09:57 AM
Don't miff the meter reader boman47k General Discussion 12 04-27-2007 08:35 AM
Expansion joints for underground fed meter cans mdshunk NEC Discussion 12 02-02-2007 03:13 PM
Water heater, elec., power surge problem ??? tzzzz216 Plumbing 8 11-05-2006 10:24 PM
