Power For Engine Block Heaters?
Old 08-12-2008, 03:05 PM   #1
J CORRIN's Avatar
Trade: Electrical
I was asked to bid a job for installing power for block heaters for 11 trucks. I know they just plug into a regular receptacle, but anybody know the amp draw on one of those? Will they trip a GFCI?
J CORRIN is offline
Old 08-12-2008, 03:20 PM   #2
Handle It!
MALCO.New.York's Avatar
Re: Power For Engine Block Heaters?
How about a make and model and size and draw?????
http://www.servicemate.com/catalog/p...CategoryID=162
From 300 to 1500 Watts.
This is more a job for a Diesel Mechanic than an Electrician.
Ultimate Wisdom---------
MALCO.New.York is online now
Old 08-12-2008, 04:05 PM   #3
J CORRIN's Avatar
Trade: Electrical
Not for sure the mak and model. Friend of mine works for a propane company and they want receptacles in the parking lot to plug in 11 trucks.
J CORRIN is offline
Old 08-12-2008, 04:47 PM   #4
Handle It!
Are you installing the Heaters or the Receptacles????
Depending on the heater, one MAYBE two per circuit! GFCI breakers.
You are going to be plugging the cord in to the truck and NOT the truck in to the receptacle.
Old 08-12-2008, 05:32 PM   #5
mdshunk's Avatar
I put them each on their own circuit, and use a seperate GFCI receptacle for each one. Most people will want them on a time clock too, so you're going to need contactors mounted in an enclosure to run them through.
mdshunk is offline
Old 08-12-2008, 11:44 PM   #6
Old School Marine
randomkiller's Avatar
Trade: Union Journeyman Electrician
The panel and timer method make a nice install.
"If we ever forget that we're One Nation Under God, then we will be a nation gone under." Ronald Reagan
randomkiller is offline
Old 08-12-2008, 11:53 PM   #7
cleveman's Avatar
Trade: custom home building
I always thought it would be splendifous if I could set up the receptacle and the prong on my truck so I could just drive right into the connection. This could also be a parking guide.
cleveman is offline
Old 08-13-2008, 01:08 AM   #8
Dustball's Avatar
The block heater for a Powerstroke is 1500 watts.
Dustball is offline
Old 08-13-2008, 01:23 AM   #9
Handle It!
Which is a Single 15 or 20 Ampere Circuit!
Rheem FVIR power vent water heaters Sewerologist Plumbing 11 02-19-2009 01:24 PM
Does fireplace opening in block wall opening need support? Square-One Masonry 6 11-22-2008 02:31 AM
Solar Power Industry Dead In California w6ire Electrical 2 06-28-2007 09:57 AM
Just boguth a new short block for race car:) IHI Off Topic (Non Trade) 4 09-21-2006 09:25 PM
Does fireplace opening in block wall opening need support? Square-One Construction 1 02-28-2006 01:59 AM
