Planer 3 Phase????
Old 12-16-2006, 05:26 PM   #1
painterman's Avatar
Trade: Historic Restorations
Planer 3 Phase????
Just bought a 14 inch planer from an auction. It has an odd plug on the end.How can I tell if it is a three phase motor. There are only two wires going into the motor from the main switch.I can post pic if needed.
Stan
painterman is offline
Old 12-16-2006, 05:33 PM   #2
mdshunk's Avatar
Re: Planer 3 Phase????
Post a clear pic of the plug, and perhaps one of the motor.
Does nothing on it have a dataplate (motor, or machine near where cord enters)?
mdshunk is offline
Old 12-16-2006, 06:25 PM   #3
painterman's Avatar
Motor plate says 220v 3hp. Could this still be a three phase motor. Should be able to get some pics later if still needed.
thanks
Stan
Old 12-16-2006, 06:41 PM   #4
painterman's Avatar
Pic of plug and control box
Planer 3 phase????-2006_1216new_planer0005.jpg   Planer 3 phase????-2006_1216new_planer0002.jpg
Old 12-16-2006, 06:42 PM   #5
painterman's Avatar
Control box
Old 12-17-2006, 09:27 AM   #6
MSSI's Avatar
Trade: Electrician
I would say if the motor has only 2 wires its not 3phase..Unless one is missing somehow..is there a diagram under the coverplate for the motor? I used to see those plugs in DC environments...
MSSI is offline
Old 12-17-2006, 09:57 AM   #7
DGFVT
CE1's Avatar
Trade: Electrical
The plug is a 3 phase one but it might have been used for single phase 240 volt with a ground and maybe a neutral. The neutral would be for the motor control circuit. Some times the plug on a piece of equipment is not a good indication of what the power requirements of the machine is, especially if it a used piece of equipment. You really need to check out the name plate on the motor and maybe even the control box. It would be well worth your money to have an electrician do an onsite inspection. I have done this a lot and sometimes there are surprises as to how the equipment was wired up by the previous user. You never know what the guy before you has done so be careful out there.
CE1 is offline
Old 12-17-2006, 11:49 AM   #8
Koha, The Electrician
koha's Avatar
Trade: Freelance Electrician
Unless your motor was used in some very rare ancient or foreign power scheme like a corner grounded delta it is in all probability a single phase motor.
Of course there is a possibility that it is a DC motor in which case it will have brushes and a commentator.
If you have any doubt rip it off and take it to your local rewind shop. There you may find some expert advise on a proper controller with modern overload and short circuit protection.
koha is offline
Old 12-17-2006, 02:46 PM   #9
Union Electrician
Sparky Joe's Avatar
Trade: Inside Wireman
[QUOTE=koha;165731]Of course there is a possibility that it is a DC motor in which case it will have brushes and a commentator.
QUOTE]
If that's the case then just ask the commentator. (commutator)
Sparky Joe is offline
Old 12-17-2006, 03:30 PM   #10
MSSI's Avatar
Trade: Electrician
Common Tater......Name:  tater.jpg
MSSI is offline
Old 12-17-2006, 07:33 PM   #11
painterman's Avatar
Ok thanks for all the input (even the potato humor) The pic of the motor plate would indicate that it is a single phase motor.
3 Phase calculation HELP southern elec Electrical 10 06-13-2007 11:24 AM
Single to 3 phase invertors/converters?? bantanic Electrical 17 02-14-2007 09:41 PM
Three phase in home Bkessler Electrical 10 01-23-2007 08:02 AM
Another 3 phase problem.... gordfraser Electrical 13 11-10-2006 08:03 PM
DeWalt 734 Surface/Thickness Planer dayspring Finish Carpentry 2 05-17-2006 05:47 AM
