Pipe Thread ?
Old 04-27-2009, 11:38 PM   #1
K2's Avatar
Pipe Thread ?
What's the difference between electrician's pipe thread and plumbers pipe thread? There was some discussion on this today at work and nobody seemed to know for sure. Thanks..
K2 is offline
Old 04-28-2009, 12:07 AM   #2
Anti-wingnut's Avatar
Re: Pipe Thread ?
Plumbers and pipefitters use NPT, National Pipe - Tapered. Dedicated electrical contractors use NPSM, National Pipe- Straight Mechanical. Tapered pipe thread, because it is tapered, seals as it is tightened. Straight thread has a much higher degree of latitude, the fittings can be screwed much further into boxes, for instance.
I worked for years at a large mechanical contractor, and we used NPT dies on all out Rigid machines, because there was too much chance of a Fitter using the Sparky's machine by mistake.
Anti-wingnut is offline
The Following User Says Thank You to Anti-wingnut For This Useful Post:
homework (05-03-2009)
Old 04-28-2009, 12:08 AM   #3
johndel1971's Avatar
Trade: carpenter/mechanical contractor
Re: Pipe Thread ?
nothing, there both the same. we both use the same threading equipment to make the threads
johndel1971 is offline
Old 04-28-2009, 12:15 AM   #4
Re: Pipe Thread ?
That is in error. One is straight, one is tapered. Unless the electricians are using NPT
http://www.ridgid.com/ASSETS/1EE6566..._Selection.pdf
Old 04-28-2009, 07:16 AM   #5
mrmike's Avatar
Trade: Electrical & Carpentry
Re: Pipe Thread ?
I'll stick my 2 cents in here. Anti-wing nut you are completly right. I know this because I was an Industrial Electrician for 25 yrs. I have even heard arguments about if it was against code to use NPT for conduit or not............. I still don't know ..........
mrmike is offline
Old 04-28-2009, 07:55 AM   #6
And I do electrical, too!
480sparky's Avatar
Re: Pipe Thread ?
The rigid pipe electricians use is tapered.
It's required to be.
NEC 344.38 "..........Where conduit is threaded in the field, a standard cutting die with a 1 in 16 taper (¾-in. taper per foot) shall be used.
FPN: See ANSI/ASME B.1.20.1-1983, Standard for Pipe Threads, General Purpose (Inch)."
Site : the area or exact plot of ground on which anything is, has been, or is to be located.
Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision.
Cite : To mention in support, proof, or confirmation; refer to as an example.
480sparky is online now
Old 04-28-2009, 03:46 PM   #7
Re: Pipe Thread ?
Sparky,
You are so right. I was last involved in this stuff almost twenty yeaars ago. And our electricians used the fitters NPT dies, so we didn't have a clustered mess, but I knew then that outfits like dedicated (we were a control company with fitters and electricians) electrical contractors often preferred NPSM.
Old 05-01-2009, 06:10 PM   #8
te12c02w's Avatar
Trade: Electrical
Re: Pipe Thread ?
I'm glad someone brought this up. I have never known the correct answer myself. Is 1 in 16 (3/4" taper per foot) the same as NPT?
Jim R
te12c02w is offline
Old 05-02-2009, 01:24 AM   #9
Moderator
Double-A's Avatar
Re: Pipe Thread ?
Yes, all NPT is tapered at 1/16 (3/4" per foot). That is what makes it NPT.
New York Times, July 20, 2006
Double-A is offline
Old 05-02-2009, 06:19 AM   #10
mdshunk's Avatar
Re: Pipe Thread ?
I'm not sure where or how this straight thread rumor ever started, but it seems to be prevalent. I've got catalogs that go way back, and electrician's threads have always been tapered. I'll admit that I know contractors who have used straight thread dies, but that's never been the correct method.
mdshunk is offline
Old 05-02-2009, 08:54 AM   #11
480sparky's Avatar
Re: Pipe Thread ?
It comes from the UMEC (Urban Myth Electric Code). Don't you have a copy, Marc?
You may know some of the Articles in it: 100-foot maximum pipe run, no wire nuts in a panel, receptacle height requirements for dwellings, tandem breakers are for MWBCs, no splices in condulet bodies, requirements for 3-way switches at stairwells.......
Old 05-02-2009, 09:32 AM   #12
Lack Of All Trades
Darwin's Avatar
Trade: Professional handyman services
Re: Pipe Thread ?
It depends who's writing and posting those threads... If it's comedy you're lookin' for, I would say read the plumber's threads--those guys are HILLARIOUS !
Darwin is offline
Old 05-02-2009, 10:33 AM   #13
K2's Avatar
Re: Pipe Thread ?
So I guess the real question is can i go to the Home depot and buy nipples in the plumbing dept and use them between the meter can and the panel??
K2 is offline
Old 05-02-2009, 10:34 AM   #14
mdshunk's Avatar
Re: Pipe Thread ?
No, but only because they are not UL listed and no other reason.
mdshunk is offline
The Following User Says Thank You to mdshunk For This Useful Post:
K2 (05-02-2009)
Old 05-03-2009, 04:26 PM   #15
220/221's Avatar
Trade: electrician Phoenix AZ
Re: Pipe Thread ?
Is the UL listing somehow marked onto the electrical nipples?
Just because it's within code doesn't make it safe.
Just because it's against code doesn't make it unsafe.
220/221 is offline
Old 05-03-2009, 06:58 PM   #16
mdshunk's Avatar
Re: Pipe Thread ?
The UL only requires the 10' stick to be marked. The carton the nipples come in is marked UL-6.
mdshunk is offline
Old 05-03-2009, 09:30 PM   #17
ampman
ampman's Avatar
Trade: providing pathways for electrons and protons
Re: Pipe Thread ?
another myth the high leg must be marked orange
ampman is offline
Old 05-03-2009, 09:31 PM   #18
ampman
ampman's Avatar
Re: Pipe Thread ?
bonding bushings
ampman is offline
Old 05-03-2009, 09:41 PM   #19
K2's Avatar
Re: Pipe Thread ?
110.15?
K2 is offline
Old 05-03-2009, 09:43 PM   #20
K2's Avatar
Re: Pipe Thread ?
bonding bushings
What about them??
K2 is offline
pipe fence danalm Welding & Steel Trades 8 10-06-2011 05:28 PM
Min. post before starting thread? Deadhead Derek Site Help and Suggestions 21 02-16-2009 09:05 PM
Question/disscusion about pipe sizing. HallisseyDesign Plumbing 36 11-27-2008 11:49 PM
Pipe sizing eager2start Plumbing 23 11-21-2008 08:37 PM
teflon tape or pipe thread compound? jerry1967 Plumbing 3 10-21-2007 06:19 PM
