tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
Pex
Old 02-15-2018, 07:31 PM   #1
npe1082's Avatar
Trade: MEP
Rewards Points: 28
Pex
Two part question, if I can get any guidance:
1) Can PEX be used as both electrical wiring and plumbing?
2) Is PEX compatible with both metal studs and wood studs? Are there any potential issues with either?
npe1082 is offline
Old 02-15-2018, 07:54 PM   #2
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 10,500
Re: Pex
1. No. Water only.
2. With metal studs, I'm sure you need to install grommets.
Why is there not a Flat Mars Society?.
480sparky is online now
Old 02-15-2018, 07:57 PM   #3
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,302
Re: Pex
Pex is a poor conductor of electricity, but a good conductor of water.
Golden view is offline
The Following 2 Users Say Thank You to Golden view For This Useful Post:
Rio (02-15-2018), SmallTownGuy (02-15-2018)
Old 02-15-2018, 08:20 PM   #4
Mordekyle's Avatar
Rewards Points: 3,304
Re: Pex
Maybe he was asking if it could be used as conduit?
Mordekyle is offline
Old 02-15-2018, 08:24 PM   #5
edward trowelhands
Trade: Diplomat
Re: Pex
Probably. Funny thing is, why not? How's it differ from PVC? Flexible, no joints to catch when pulling wire. One spool for P and E contractors.
Old 02-15-2018, 08:24 PM   #6
Box Builder
Morning Wood's Avatar
Rewards Points: 8,958
Re: Pex
Thats all I could think of too.
I would not use pex for conduit. Id use conduit for conduit.
Morning Wood is offline
Old 02-15-2018, 08:38 PM   #7
480sparky's Avatar
Re: Pex
It's not UL listed for the use.
Also, flex raceways have a habit of exceeding the 360 of bends rule.
Old 02-15-2018, 08:49 PM   #8
edward trowelhands
Trade: Diplomat
Re: Pex
I guess my question is more what's the inherent property of PEX that's preventing it from getting UL listed? The bends rule makes some sense though.
I will say it was standard practice in the sub arctic of Fairbanks Alaska to run Raychem self regulating heat trace through a run of Pex tied to the well line and other plumbing lines that were at risk of freezing. Easy to bend along with the line, good for higher temps, and possible to pull and replace the heat line deep under ground.
Old 02-15-2018, 11:28 PM   #9
Business Owner
P42003's Avatar
Trade: Pest & Termite Control
Rewards Points: 20
Re: Pex
Apparently Article 353 of the N.E.C. covers HDPE non-metallic conduit.
P42003 is offline
Old 02-15-2018, 11:32 PM   #10
Business Owner
P42003's Avatar
Rewards Points: 20
Re: Pex
H.D.P.E. Non-metallic conduit:
3.21.353.12. Uses Not Permitted.
It must not be used above 50C, either by reason of a high ambient temperature, or high operating temperatures of the enclosed conductors, or both. Polyethylene is flammable, and for that reason it is generally limited to direct burial applications. If not specifically prohibited, it is permitted above grade if encased in a concrete envelope not less than 50 mm (2 in.) thick. It is not permitted to be exposed, and it must not be used inside buildings.
P42003 is offline
Old 02-15-2018, 11:42 PM   #11
Business Owner
P42003's Avatar
Rewards Points: 20
Re: Pex
Looks like PVC has a much, much higher dielectric strength than HDPE for a given thickness, though I could be wrong.
P42003 is offline
Old 02-16-2018, 02:06 PM   #12
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 6,383
Re: Pex
Imagine working in a mechanical room that only had Pex for all the utilities.....oops I thought I was cutting the DWV pipe and just sawed into a 200 Ampere 4 wire service cable conduit........
I want a drinking water straw / UBS cable for my not-so-Smart phone.
Fouthgeneration is offline
The Following User Says Thank You to Fouthgeneration For This Useful Post:
Golden view (02-16-2018)
Old 02-18-2018, 07:11 AM   #13
npe1082's Avatar
Trade: MEP
Rewards Points: 28
Re: Pex
Thanks for all your feedback! If I am understanding correctly, the PEX is not the best option here for both plumbing/electrical.
If I go with metal studs and aluminum (for both wiring and piping), is this an issue, is galvanic corrosion?
npe1082 is offline
Old 02-18-2018, 07:41 AM   #14
480sparky's Avatar
Re: Pex
I gotta ask: WHY?
Old 02-18-2018, 07:47 AM   #15
Box Builder
Re: Pex
Aluminum piping? Aluminum wire?
Old 02-18-2018, 08:06 AM   #16
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 9,928
Re: Pex
I expect a big RED "thread closed" label any minute now...
SmallTownGuy is online now
The Following 2 Users Say Thank You to SmallTownGuy For This Useful Post:
avenge (02-18-2018), Morning Wood (02-18-2018)
Old 02-19-2018, 10:13 AM   #17
Pro or somethin'...
Anthill's Avatar
Trade: Tinwoodman
Rewards Points: 1,244
Re: Pex
both bad ideas.
Anthill is offline
Old 02-19-2018, 10:14 AM   #18
Pro or somethin'...
Anthill's Avatar
Trade: Tinwoodman
Re: Pex
Now you know where the Wall of Shame stuff comes from.
Anthill is offline
The Following User Says Thank You to Anthill For This Useful Post:
SmallTownGuy (02-19-2018)
Old 02-19-2018, 06:34 PM   #19
Stryker1-1's Avatar
Trade: Low Voltage Systems
Rewards Points: 1,268
Re: Pex
This sounds like one of those jobs that got grossly underbid and now every corner imaginable will be cut to save money
Sent from my SM-G870W using Tapatalk
Stryker1-1 is offline
