Trade: Finish Carpenter
Panel Extension
I am converting my garage to living space and would like to fur out existing wall to 6" for insulation purposes. The problem is the main electrical panel is in this wall. Do they make a "extension ring" to extend the panel box to make it flush again? (Panel is a 200A Square D QO)
I looked on Square D's site but didn't find what I was thinking about. Thanks |
Re: Panel Extension
No such extension exists. There are few options in your case. The code requires that a 30" wide x 36" deep area (measured from the plane at the front edge of the panel) be clear. In your case, you'd either have to have the panel moved out flush with the new wall or don't fur out a 30" wide area (centered on the panel) from the floor to the ceiling. There are lots of folks that would leave the whole panel recessed like that, and put a little cabinet door on the new finished wall surface. This is a code violation.
Trade: Squirrel Handler
Re: Panel Extension
Another idea is to bump out a closet, but that usually ends up getting filled with junk and or shelves, violating the code. You can frame in a set of bi-fold doors but they wont do much for drafts, a regular solid core door framed in flush with weather stripping would work good.
Re: Panel Extension
Thanks for the help, I'll probably just leave the 30 x 36 area recessed. (No door either!!!) Thanks again!!!
Custom Builder
Re: Panel Extension
Ditto MD.
Bob
Bob |
Re: Panel Extension
Md, how about hanging a picture over it? I did this in my last house because some moron put the box in the entry hallway, not very attractive.
Custom Builder
Re: Panel Extension
Md's so into his trade, he'd hang a picture of a service panel over the service panel.
![]() Bob
Bob |
Re: Panel Extension
#9 | |
Re: Panel ExtensionQuote:
No, the issue is the recessed panel. You can't fur out a wall and leave the panel recessed. You can absolutely hang a picture over a panel if you feel the need. Matter of fact, Cutler Hammer makes a very decorative (paintable/paperable) cover that can make a panel disappear. http://www.eatonelectrical.com/unsec.../SA31A01SE.PDF |
Re: Panel Extension
So, I guess that the issue boils down to whether the covering is hung by hinges or a wire? Hinges
Wires I'm glad that I only have the NMMA/ABYC to deal with.
#11 | |
Trade: General/ Electrical/ HVAC/ Refrigeration/ IT Contractor
(Although I also like the idea of the picture of a panel) |
| adding meter main panel?? | ko_jun | Electrical | 3 | 05-26-2007 10:42 PM |
| Simplex 120-volt Fire Panel | ethan | Electrical | 6 | 04-30-2007 02:47 PM |
| Sub panel | mjay | Electrical | 9 | 02-24-2006 11:41 PM |
| Upgrading Main Panel | DecksEtc | Electrical | 7 | 01-23-2006 07:54 PM |
