Painting Romex?
Old 04-15-2009, 09:19 PM   #1
philcav7's Avatar
Trade: Home Theater Design & Installation
Painting Romex?
I am doing a small job in an older home with low (6' 8") ceilings in the basement. Due restricted height the client wants to simply paint the subfloor and joists, rather than installing a finished ceiling.
Is there any problem with painting over the romex wire? Or can you direct me to the section of the nec that covers this topic?
Thanks.
philcav7 is offline
Old 04-15-2009, 10:46 PM   #2
joelv1967's Avatar
Trade: GC, Elec, Plumb
Re: Painting Romex?
Thanks.
I assume you are talking about Romex(tm) that is running through the floor joists, and not romex that is....say.... stapled to the edge of the joists - (I hope). If this is the case, why not put up some 1/8" paneling or something in this price range. It would look much better for very little money/effort. As far as painting, I know there are codes about paint/texture/etc. inside of the boxes, but don't recall anything preventing you from spraying paint inside of the bays of the floor joist (resulting in painting the Romex).
joelv1967 is offline
Old 04-15-2009, 10:50 PM   #3
And I do electrical, too!
480sparky's Avatar
Re: Painting Romex?
Originally Posted by joelv1967 View Post
.........As far as painting, I know there are codes about paint/texture/etc. inside of the boxes, .......
Do tell!
Site : the area or exact plot of ground on which anything is, has been, or is to be located.
Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision.
Cite : To mention in support, proof, or confirmation; refer to as an example.
480sparky is online now
Old 04-15-2009, 10:51 PM   #4
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Re: Painting Romex?
I had the same type job a few weeks ago. Owner wanted to "straighten out" an electrical mess left behind by her ex-husband. She thought it'd be a good idea to just paint the open floor joists. Not sure how all that worked out because I haven't been back since.
Magnettica is offline
Old 04-15-2009, 10:56 PM   #5
joelv1967's Avatar
Re: Painting Romex?
Originally Posted by 480sparky View Post
Do tell!
Must be a local code...In vegas, you will fail if the inspector finds paint/texture/other building material inside boxes...plus you can only have 1/4" of insulating sleeve and/or paper in the box.
Old 04-15-2009, 11:02 PM   #6
480sparky's Avatar
Re: Painting Romex?
Who fails (and who pays), the electrician, drywaller or the painter? What about other trades that use the wires to puncture their tubes of caulking? Does the trim carpenter get dinged for putting sawdust in the air and it settles in the boxes?
And if you can 'only have ¼" of sheath', and the NEC requires a minimum of ¼", then you must have exactly ¼". No more, no less. So you fail if you have .2499 or .2501 inches?
Old 04-15-2009, 11:10 PM   #7
joelv1967's Avatar
Re: Painting Romex?
These idiots in Vegas fail anybody for anything. Of course they don't measure the sheath, but if it is over 1/2", I get failed.....So between 1/4 to 1/2 and your good. As for the dust, etc. When I make up my boxes, I have to stuff them with paper to keep all the wall mud, texture, etc. out....If not I will be vacuuming them out so I don't fail.
Old 04-16-2009, 01:34 AM   #8
#1 stunner
Static Design's Avatar
Trade: Design/Build
Send a message via AIM to Static Design
Re: Painting Romex?
I've seen it painted several times in basements with low ceiling height, they haven't burnt down yet.
Static Design is offline
Old 04-16-2009, 08:09 AM   #9
Baltimore Electrician
JohnJ0906's Avatar
Trade: Electrician
Re: Painting Romex?
That sounds like a very wide interpretation of 110.12(B)
John from Baltimore
"One Day at a Time"
All replies based on the 2008 NEC
Originally Posted by celtic
Deny Everything, Admit Nothing, Demand Proof
JohnJ0906 is offline
Old 04-17-2009, 08:34 PM   #10
philcav7's Avatar
Re: Painting Romex?
Yes. That is exactly what I was referring to...the wires in the bays between the joist. There are no wires on the bottom of the joist, they are stapled to the sides and ran through holes drilled through the joist.
I could have the wires and boxes taped off and leave them unpainted but would would look as appealing. I asked my electrician the other day...he was unaware of any local codes regarding it. I will make a call on Monday a see what they say.
I really want to used a dropped ceiling so I can insulate and use acoustical treatments above the ceiling tiles. This is an option. The only challenge will be the large steam heating lines that are located in three areas.
Thanks again guys.
philcav7 is offline
Old 04-19-2009, 10:43 PM   #11
pulpfiction32's Avatar
Trade: Electrician
Re: Painting Romex?
we do work for an insurance contractor . Say for example a kitchen fire occurs and there is mostly smoke damage to the house. they pull all of the drywall out and spray the ceiling ,studs and sub floor with primer to lock out the smell and yes the inspectors have seen romex sprayed with primer and they have never said a word
pulpfiction32 is offline
Old 04-21-2009, 02:48 PM   #12
ampman
ampman's Avatar
Trade: providing pathways for electrons and protons
Re: Painting Romex?
ask the manufacturer
ampman is offline
Old 04-21-2009, 09:54 PM   #13
woodchuck2
woodchuck2's Avatar
Re: Painting Romex?
I would talk them into a drop cieling myself. You can install that and take up only a few inches of space so you should still have 6'4"-6'6" of ceiling hight left. Its also a nice noise barrier, a far better look, and you could talk them into recessed lighting or fluorescent lights too.
woodchuck2 is offline
Old 04-21-2009, 10:10 PM   #14
GregS's Avatar
Trade: Low Voltage
Re: Painting Romex?
Go over the face of the box with some wide tuck tape. I do this for my low-vo stuff with I rough-in and when I come back I just punch the tape out and everything is there, nice and clean with no mud, paint or sawdust on it.
GregS is offline
Old 04-21-2009, 10:11 PM   #15
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Re: Painting Romex?
Maybe I'm too far west...why is the romex exposed and accessable to human touch?
Chris
Chris Johnson is online now
Old 04-23-2009, 09:45 PM   #16
philcav7's Avatar
Re: Painting Romex?
The basement is unfinished so the wiring that is running through the floor joist as it travels from one side of the house to the other is visible. Do you have some local code that prohibits ANY visible NM wiring?
At any rate, I was able to talk him into a dropped ceiling. That was truely the best case scenario. There will be one low spot where a soffit will be built around the steam heating lines.
Thanks for the insight!
philcav7 is offline
Old 04-24-2009, 10:33 PM   #17
I'm a Mac
Re: Painting Romex?
Yea, we can not have any romex exposed to human touch here.
Chris
Painting business start-up questions oneelwayfan_com Painting & Finish Work 56 02-02-2010 01:55 AM
Painting and handyman, should I simplify? englishdave Business 9 04-14-2009 07:19 PM
Houston Painting Contractors Needed! Mr. Mike Painting & Finish Work 2 02-03-2009 11:20 AM
painting over enamel stripes mfrancis Painting & Finish Work 2 11-17-2008 10:30 AM
painting pipe fence diesel power Painting & Finish Work 14 09-06-2008 10:37 AM
