Overhead Lighting Exposed Truss & Rafter
Old 11-05-2006, 01:11 AM   #1
Amp's Avatar
Trade: Electrician
I have been asked to install overhead lighting in a new build with exposed finished truss and rafter ceiling. Above that is insulated roofing. All I can think of is track or indirect.
Amp is offline
Old 11-05-2006, 04:08 AM   #2
woody11973's Avatar
Trade: electrical
Re: Overhead Lighting Exposed Truss & Rafter
Could You be a little more specific?
On a similiar job me ( the EC), the BO, & electrical fixture store rep (the owner), thought some LV suspenstion cable type lighting would work in this sitation,
woody11973 is offline
Old 11-05-2006, 07:39 AM   #3
mdshunk's Avatar
Often, pipe is run on top of the roof deck and boxes penetrate the decking. The insulation board is put down on top of the pipe, with grooves where necessary. Wiremold is another option. Track/cable is another.
mdshunk is offline
Old 11-05-2006, 04:22 PM   #4
Amp's Avatar
Trade: Electrician
Thanks for the ideas. Running pipe on top of the roof deck would make sense if recessed lighting was an option. It seems like a hassel when track would be easier. I guess track is a little old school. My experience is commercial and new house detail is a bit out of my area. I will look into the low voltage option as well.
Amp is offline
Old 11-07-2006, 03:00 PM   #5
Philadelphia electrician
RobertWilber's Avatar
Trade: Electrical contractor
I vote for LV cable
BTW, is the roof system integrated? or is it ceiling finish, with insulation board on top, with roof base on top? maybe you could channel the insulation before they lay the roof base on? Then you could use MC cable or some other system?
How about flat, undercarpet system components fastened to the ceiling? Can they paint that stuff?
This sounds like fun ...
RobertWilber is offline
Area lighting for Pipe Guy mdshunk Electrical 5 01-26-2009 02:25 PM
Allowances and Overhead elitenw Business 3 12-28-2006 08:30 PM
rafter table/span question bobbrown Framing 14 11-14-2006 07:13 PM
Residential General Lighting Circuits toastermaker Electrical 11 02-26-2006 01:04 AM
Landscape Lighting NightScenes Landscaping 0 01-11-2006 06:58 PM
