Outlet Damaged?
Old 08-06-2004, 10:31 AM   #1
Unregistered
Guest
Unregistered's Avatar
Posts: n/a
Outlet Damaged?
I recently bought a dryer and the necessary 3-blade cord. My brother plugged the cord in to see if it would fit the outlet but did not attach the other end of the cord to the dryer, since he was just testing it. As a result, the exposed metal clamps/hooks on the other end of the cord touched eachother. So before he even got the prongs into the outlet (he must have stuck it in enough so that he broke the plane of the outlet) the juice traveled thru the cord and sparked out the other end. Stupid, I know. Anyway the cord tunred black in places and melted in small areas. The outlet is dark brown and I can't tell if it is black too but what I am wondering is what are the chances that there was damage done?
Can I just get another cord and tell him to be more careful in hooking it up this time? Or do I need an electrician to check it before I can use it? Thanks!
Old 08-07-2004, 11:09 AM   #2
Electrical Contractor
jbfan's Avatar
Trade: Electrical Contractor
Re: Outlet Damaged?
I would recomend that you replace the outlet and the cord. The outlet may be fine but, 5 bucks is a small price for peice of mind. Make sure you turn the breaker off and replace the wires as you find them.
Tell your brother he is lucky to still be here!
We are the people (our parents warned us about) (Jimmy Buffett)
jbfan is offline
Old 10-08-2004, 04:20 PM   #3
Unregistered
Guest
Posts: n/a
Lightbulb
Re: Outlet Damaged?
Look at me I'm Sandra D
water damaged enclosed porch rhinoguy Construction 0 03-14-2007 12:25 PM
Furnace plugged in to wall outlet? rhinoguy HVAC 12 02-21-2007 07:01 PM
HELP.....Rained Damaged Concrete! 9452 Construction 2 12-27-2006 09:05 AM
208 to 110 for outlet on pole Bkessler Electrical 3 11-16-2006 06:14 PM
how to replaced damaged shingles? jerry1967 Roofing 2 06-28-2006 09:26 AM
