The Deck Guy
Outdoor 18 Ga Wire Vs. 18 Ga Lamp Cord?
Can someone with an electrical background please explain the difference to me between 18 gauge Outdoor Low-Voltage wire and 18 gauge Lamp cord?
I cannot tell any perceivable difference between the two when holding them side by side. In fact, I doubt you could either. The reason I ask is that I am having a hard time finding 18 ga outdoor wire locally and the LV LED light system I install specs 18 ga wire rather than the bigger stuff since the LEDs don't really draw the amps incandescents do. I do not bury the wire and it's only carrying 12V DC. Am I crazy to think that lamp cord wouldn't do the job perfectly????
Trade: home builder carpenter Central Alabama
Re: Outdoor 18 Ga Wire Vs. 18 Ga Lamp Cord?
its not the wire inside thats differnt its the insulation. Most indoor lamp cord and romex does not have a water proof cover. If you cannot find outdoor lv cord in bulk then try a trailer supply store. The wire they use for wiring the lights on utility trailers and big rig trailers will work fine and is for outdoor use but not to bury.
#3 | |
Fentoozler
Greg,
if this is not a "home project"...you do realize you'll need a bona fide EC for this. Quote:
[pages 27 - 28] I'm not trying to blow smoke up the fireman's butt... http://www.nj.gov/lps/ca/electric/mi...min_070208.htm ...people get nailed every month with fines starting at about $1000. I'd rather you be aware than be caught with your pants down. ::Climbing down from the soap box::
You had no luck at the big box stores? Can you use a larger size [say #16 ???]..it seems readily available at big box?
#4 | |
The Deck Guy
Re: Outdoor 18 Ga Wire Vs. 18 Ga Lamp Cord?Quote:
#5 | |
The Deck Guy
The 24 ga wires from my LED fixtures sure looks to be nothing special.
damn if i know how. I just know i have opened up non-burial romex that has got rained on and the paper insulation on the ground would be wet. Maybe it just wicked up the end but i try my best not to let any get wet.
#7 | |
Fentoozler
No one can tell me exactly what type insulation is on Romex wire.....they can tell me it is not THHN/THWN [rated for wet use], but that's about it. We're gonna need Leonard Nimoy on this:
Trade: Squirrel Handler
What about a UV rating for low voltage cable?
Some people climb mountains. I take out the trash. But we both do it for the same reason. |
| 3-way switch with 14/2 wire | wadswob | Electrical | 2 | 09-23-2008 08:33 AM |
| aluminum wire | darren | Electrical | 10 | 08-30-2008 03:56 PM |
| safe hot wire | driver | Electrical | 13 | 05-12-2006 11:18 PM |
