One More Basic Question.
Old 07-24-2007, 09:38 PM   #1
K2's Avatar
Can romex go straight into a water heater or does it need a box and flex. We don't see to many electric water heaters around here but i own one and the rope goes right in. Thanks!!
K2 is offline
Old 07-24-2007, 09:44 PM   #2
mdshunk's Avatar
Re: One More Basic Question.
Yes, but quite often the code violation in those cases is not having a local disconnect for the HWH if the panel is not within sight. Seems like I normally run romex to the disconnect, and a scrap of MC from the disconnect to the water heater. Not a requirement to use the MC, but I just like the looks of it. Some areas may have rules that would consider romex going to a water heater as being exposed to physical damage. If these rules exist, then you'd need to use a sturdier wiring method. I think it's silly, because I've never seen a damaged romex going to a HWH, save for the little wee one's people stash under counters.
mdshunk is offline
Old 07-24-2007, 09:56 PM   #3
K2's Avatar
Hmm, in sight. If the door were off the hinges I could touch the panel and the water heater at the same time but direct line of sight from the WH I can't see the panel and the door is kinda in the way. What do you think?? Disconnect?
K2 is offline
Old 07-24-2007, 10:00 PM   #4
SmithBuilt's Avatar
Trade: Commercial/Residental Construction
My inspector would say the door could be closed and the disco would be out of site.
SmithBuilt is offline
Old 07-24-2007, 10:04 PM   #5
GregS's Avatar
Trade: Low Voltage
This made me chuckle
GregS is offline
Old 07-24-2007, 11:13 PM   #6
mdshunk's Avatar
Oh, yes. Absolutely that's your disconnect. If you can see tha panel from the water heater, and the panel is less than 50 feet away, then that's your disconnect. Same goes for any piece of equipment that is required to have a disconnect. If the panel's right there, you're cool. If you can't see the panel or it's more than 50 feet away, you need a disconnect of some sort at your hardwired equipment. Makes sense. It's just a safety thing for whoever has to work on it later on.
mdshunk is offline
Old 07-24-2007, 11:21 PM   #7
K2's Avatar
Probably if you were messing with the WH the door would have to be open unless it weas one of those skinny guys. But hey I can fix it.
So I probably need a metal box and any old double pole single throw switch rated at 30 amps??
As usual I ask a question and find out I'm ok with regards to the question but that i have other problems.
K2 is offline
Old 07-24-2007, 11:24 PM   #8
K2's Avatar
Got it. I was typing at the same time. Thanks!!!
K2 is offline
Tight Space Stucco Question - Undershot between roof sections CGofMP Construction 3 03-24-2009 09:10 AM
Question about bidding vinyl wallcovering kanadaeh Painting & Finish Work 9 02-19-2009 05:29 PM
Basement Window Question gregt848 Windows, Siding and Doors 9 07-26-2006 06:29 PM
