Oil Filled Rad---$ To Run ?
How much does it cost to run one of these? we have a few in my shop, i am just trying to get some rough idea. Brand is Pelonis, model#HO0218. 120V AC 60Hz 1500W. IT has low-med-high, and a thermostat-min/max. I USUALLY dont go beyond med, and keep the therm in the middle. thanx. G
Handle It!
Re: Oil Filled Rad---$ To Run ?
Quite inefficient.
Lets say "Medium" is 1000w. 1000w x 1 hour of usage is 1 KWH. 1 KWH x number of hours of usage = Exact Power Consumption Costs. (Hours x Watts/1000 = KWH) Check your Con-ed or LIPA bill for the rates. http://www.lipower.org/pdfs/account/rates_resi.pdf (LIPA Rates) http://en.wikipedia.org/wiki/Oil_heater I had one once. My biggest gripe was the lack of radiant or forced air Heat Flow.
Something to One may be Nothing to another! Ultimate Wisdom--------- http://www.youtube.com/watch?v=OW-cnizLDEE Last edited by MALCO.New.York; 11-24-2008 at 11:41 PM. |
Numbers as posted above.
Around here with rates from .07 residential to .10 commercial and at assumed medium setting of 1000 watts it will cost .07 to .10 a hour per heater. Or the same as 10 100 watt light bulbs. 8 hours a day, 22 days a month, it would cost $12.32 to $17.60 a month per heater. |
| Block Walls | DaHammer | Masonry | 29 | 03-06-2009 07:11 PM |
| ice issues | RailingMan | Construction | 4 | 11-24-2008 08:51 AM |
| Vinyl Window questions- most preferred | davinci | Windows, Siding and Doors | 21 | 04-28-2008 09:53 PM |
| foam filled frames-need some names of Co's | davinci | Windows, Siding and Doors | 3 | 03-28-2008 03:50 PM |
| Hollow steel lally or concrete filled? | kusa24 | Construction | 4 | 04-23-2006 08:49 AM |
