Master Electrician
Trade: Electrical
Ohm's Law
Does it really matter unless your an electrical engineer or doing serious design calculations? I've been doing all types of electrical work for 9 yrs and really never needed it except for forum talk and for fun at night.
Celtic's #1 Fan
Trade: electrical
Re: Ohm's Law
bubbles....hahaha...nice name
![]() i use parts of ohms law daily to determine circuit sizes, amperages, etc. |
Master Electrician
Trade: Electrical
Re: Ohm's Law
I've probably been computing load calcs and amps and volts subconciously for years since the physics days way back when. I basically use P=IxE to get everything I need. I'm mainly wondereing because there is so much emphasis from employers and test saying you must know Ohms Law!!! I really never needed it and probably won't in reality?? I have an old timer working for me and he knows none of that stuff but he can walk into a bee's nest and staighten it out like know one can.
Trade: Electrical
Re: Ohm's Law
Without a working knowledge of ohm's law, how would one figure out how many feet of electric heat you could put on a circuit or a electric line break t-stat? How would you know how many outside 75watt or 150watt lamps you could put on a 20a breaker or a 15 amp toggle switch? I use ohm's law at least once a week, even if I don't really sit down and figure anything out. It is like a code book, every spark should at least know how to apply it to his own work. If you can't remember it, write it in your code book or just look at the front of Ugly's cover.
Jim R |
#5 | |
Trade: Former Electrician
Re: Ohm's LawQuote:
Fentoozler
Re: Ohm's Law
Mahlere...remember when you used to blow bubbles?
I think he's here to say HI!
Celtic's #1 Fan
Trade: electrical
Re: Ohm's Law |
Fentoozler
Re: Ohm's Law
Old School Marine
Trade: Union Journeyman Electrician
Re: Ohm's Law
Now that wasn't his girl friends cat right?
Fentoozler
Re: Ohm's Law
Not unless the cat can read and type(write)
Celtic's #1 Fan
Trade: electrical
Re: Ohm's Law |
Service & Repairs
Trade: Electrician
Re: Ohm's Law
If I needed to light a specific area with 400 watt MH, I could only do 4 of them at 120 volts (cont load). But if I needed more than that, I could do 8 of them and operate them at 240 volts. That's basic Ohm's law right there. I don't know how you could work out in the field w/o simple knowledge like that. I have the fancy Mike Holt Ohm's law pocket-size sticker on the back of my calculator at work. Comes in handy sometimes.
Master Electrician
Trade: Electrical
Re: Ohm's Law
I've done all those things mentioned above just using pie. I thought OHms had to do with relationship of EMF , Current and Resistance? That is one I rarely use and only for fun. I appreciate all the comments. I guess PIE and E=IR are both Ohms then?
Union Electrician
Trade: Inside Wireman
Re: Ohm's Law
R is ohms
R=E/I is ohms law P=ExI is the power formula |
"da Whale don't hesitate"
Trade: Hard Surface Flooring
Re: Ohm's Law
Ohm's Law is THE fundamental first piece of knowledge needed to do ANY electrical/electronic work. (I was an aviation electronics tech in the Navy way before I did floors) It was the first thing they taught us at tech school.
Precision Flooring (772) 237-9900 Tile, Hardwood, Laminate, and Resilient Installation, Sales & Repair - "We do it right the FIRST time" |
#16 | |
Union Electrician
Re: Ohm's LawQuote:
| 800a Mdp | Ken@K&R | Electrical | 21 | 01-22-2007 08:24 PM |
| Max distance for Gen. | sparky66 | Electrical | 14 | 01-18-2007 09:51 PM |
