Noise From Breaker
Old 03-28-2009, 08:45 AM   #1
Robie's Avatar
Noise From Breaker
I take care of a customers summer home. They turn the hot water heater off for the winter season. I flipped the breaker yesterday to turn it back on and heard a faint noise coming from it. I immediately turned it back off. The noise literally sounded like a bowl of Rice Krispies just not as loud.
Any clues why the noise? I've never heard anything coming from a breaker box before.
Thanks.
If you have integrity, nothing else matters. If you don't have integrity, nothing else matters. ~Alan Simpson
Robie is offline
Old 03-28-2009, 08:54 AM   #2
And I do electrical, too!
480sparky's Avatar
Re: Noise From Breaker
It sounds like there's something arcing.
Call an electrician.
Site : the area or exact plot of ground on which anything is, has been, or is to be located.
Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision.
Cite : To mention in support, proof, or confirmation; refer to as an example.
480sparky is online now
Old 03-28-2009, 09:00 AM   #3
Robie's Avatar
Yeah, an electrician will definitely be called. Just wanted to get some ideas before I call the homeowner, plus I will be the one letting the elctrician in and just getting a little "prepared" here.
Robie is offline
Old 03-28-2009, 09:21 AM   #4
480sparky's Avatar
What brand is the panel, and how old is it?
Old 03-28-2009, 09:27 AM   #5
Robie's Avatar
Didn't pay any attention to the brand. The house is about 20 years old.
Robie is offline
Old 03-28-2009, 10:20 AM   #6
480sparky's Avatar
If you recall any of the breakers looking like any of these:
you're due for a panel change.
Old 03-28-2009, 02:30 PM   #7
Robie's Avatar
Nope...it didn't look like that. It was all black with no other colors.
His daughter and family are coming down next week and he wanted me to turn the hot water heater on ahead of time. Sounds like I should get an electrician in there first...yes?
Robie is offline
Old 03-28-2009, 02:33 PM   #8
mrmike's Avatar
Trade: Electrical & Carpentry
This was my post in the discussion just last week about a 200 main breaker burning up, but ertains to all breakers.
These breakers are a mechanical switch which under normal conditions, sit there year in & out in the "on" position & when they are exceeded their ampacity for a specified time they are supposed to trip. Well sometimes after sitting there that long they are "mechanically stuck" & don't work, causing this burn out. Yes some brands may fail more often like Federal pacific, but all of them can under certain situations like i described.
Usually they burn on one side, like shown. When they do this it is also a good idea to check for grounds & heavy loading on that Buss.
I got into the habit of closely listening for what I call 60 cycle hum, when I am working on any panel, & if I hear it , I trace it to the culprit & change that breaker out.
This one isn't burned out obviously but I would check the load on the it, and even if the water heater is fine, I would change the breaker anyway
mrmike is offline
Old 03-28-2009, 02:35 PM   #9
Home Depot aisle walker
willworkforbeer's Avatar
Trade: home remodeling
I'm not a liscensed electrician but I was adding a circuit in a house and found an electricuted frog behind a breaker, apparently came up the underground power, maybe that was a frog sizzling?
willworkforbeer is offline
Old 03-28-2009, 02:37 PM   #10
480sparky's Avatar
Originally Posted by Robie View Post
......Sounds like I should get an electrician in there first...yes?
That's your best bet.
Old 03-28-2009, 02:45 PM   #11
Robie's Avatar
Thanks guys...the e-mail is on it's way to the customer with the recommendation to get an electrician in.
Robie is offline
Old 03-29-2009, 01:23 AM   #12
scourt11's Avatar
Trade: Electrical Contractor
The breaker is shoot. Replace it
scourt11 is offline
Old 03-30-2009, 07:12 PM   #13
Robie's Avatar
Replaced the 30 amp breaker today and all seems well. The old one was full of, what looked like very thin pieces of metal. They came out when I shook it.
Thanks for the help.
Robie is offline
Old 04-07-2009, 12:36 PM   #14
ctiautomation's Avatar
Trade: Damien
LOL. I can relate to that.
ctiautomation is offline
blower noise on startup banctecbobn HVAC 3 03-09-2009 01:44 PM
AFCI breaker question. Jeff (socal) Electrical 24 12-27-2008 03:29 PM
Breaker keeps popping DErnest Electrical 2 09-15-2006 06:30 PM
Tapping noise ... RobertWilber Electrical 3 09-07-2006 07:22 PM
Furnace-gas forced air- high pitched noise saturn711 HVAC 3 03-25-2006 09:52 PM
