Carpenter
No Power
This is a little change from what y'all used to seeing on here. I installed an amp in the little womans car tonite but have no power? It's a 1200 w. Sony amp, 4g. wire with 30amp inline fuse. Ground wire is prolly 16 g. or so. All fuses are good, power to the bus bar on the amp but no lights? There's a remote line that I have hooked up to a 30 amp fuse in the fuse panel cause I don't care to go into the dash & hook to the remote anntenna wire (factory radio, 04 Tahoe). Idunno, y'all reckon the ground wire ain't big enough?
Trailer park boy
Re: No Power
What circuit is the 30 amp fuse you plugged the remote wire into for?
"Industry without art is brutality"
Doofenshmirtz Evil Inc.
Re: No Power
Did you scrape of any paint that may be where you hooked up the ground?
in texas with framing and cornish people will do it for 3.00 a foot. What do yall think about that? Just laber |
Trade: Electrical
Re: No Power
Try another ground location.
Carpenter
Re: No Power
The 30amp fuse is the hvac/heater fuse. I did not scrape any paint away from the ground & I tried two different locations, one of which was an unpainted bolt.
Electrician
Trade: Electrical Contractor
Re: No Power
If the ground wire is to small it will get hot and smoke. But it will work until it burns clear. I think the ground is connected to a non grounded spot. Todays cars have a lot of plastic and a lot of rubber mounted parts. Not every screw and hunk of metal is connected to the -battery pole.
John |
#7 | |
Trade: Electrical
Re: No PowerQuote:
Diddo. |
Re: No Power
Meter between the positive and negative...
If your pulling 12v DC your neg is ok. What model amp? |
Trade: home builder carpenter Central Alabama
Re: No Power
Ah car audio, I know a little about it or used to. In '97 built completly by myself a $7500 system in my truck, won every show i went to in my power class and 10th place out of 100 much more expensive syterms at '99 USAC world finals in K C Kans. All my power and grounds where 8 gauge to dist blocks then 2 gauge to dedicated batt. The only connection to truck was a 8g charging wire to the alternater through a iscolator.
1st Check voltage at amp with meter 2nd If none run a jumper ground wire direcly to batt. 3rd Still dont work, jump the remote (blue wire) to hot 4th Still nothing connect a speaker directly to amp with short wires, adjust gains or eq if equiped 5th If works, find a chasis ground or run to batt. With at least 8g if amp is true 500 watts or more. 6th Still dont work, take that pos back ![]() To make things easier all this could be done on the work bench with battery and a speaker completly away from car Amps are rated at max power on paper into 4 ohms. NO amp will give you more than half max rating in actual output. Look for the rms rating and thats is you true output.The cheap ones will be much less than that. Sony is a good brand so 300x2 stereo 4 ohms- rms is probably correct for a 1200 max rating. Also most aftermarket amp are rated at 4 ohms stereo and most factory speakers are 8 ohm or more. While not a big problem that will cut power in half also. So if your amp is 1200 max and your factory speakers are 8 ohm your getting 150 watts to each speaker.still good (assuming 2 speakers) Last edited by dlcj; 12-10-2008 at 06:07 PM. |
Carpenter
Re: No Power
Imma try another ground wire
Doing what I do.
Re: No Power
so you did run the 4 gauge all the way to the fuse box?
i'd run a minimum of 8 gauge for ground. that 16 might show 12v, but can't handle the amperage requirement.
Around The House Remodeling and painting. |
Re: No Power
Thats true but for an amp that big, skip the fuse box and go directly to the batt with a inline fuse. Ground too if no better one can be found.
#13 | |
Doing what I do.
Re: No PowerQuote:
Carpenter
Re: No Power
It was the ground wire, I replaced it with 10g & found a "good" groundin' place. Like "jrclen" said, lots of rubber mounted parts that looks like it would be a good ground.
Thanks y'all for the help!
Electrician
Re: No Power
Glad you got working. Thanks for letting us know the outcome.
John |
Re: No Power
glad we could help.
wish i could still afford that hobby but with car audio like all electronics, if its a year old its out of date and you wont win a competition with it. |
Carpenter
Re: No Power |
| Lost power - cant locate fault | tool junkie | Electrical | 26 | 08-19-2008 08:52 PM |
| Power for engine block heaters? | J CORRIN | Electrical | 8 | 08-13-2008 01:23 AM |
| Affect of CFLs on power quality? | Electric_Light | Electrical | 2 | 11-29-2007 03:56 AM |
| Power Rollers.... | MarvinWilleyJr | Painting & Finish Work | 15 | 09-14-2007 10:12 PM |
| Solar Power Industry Dead In California | w6ire | Electrical | 2 | 06-28-2007 09:57 AM |
