Trade: Electrician
Neon Transformer
Can the secondary wires of a neon transformer that is mounted above a drop ceiling pass through the ceiling to the neon sign below? I'm not sure what type of cable they use for neon transformers. I'm thinking no but don't know what article.
Re: Neon Transformer
The secondary is normally done with "GTO Cable".
Trade: Electrician
Re: Neon Transformer |
Trade: Electric Sign
Not unprotected. Has to be in a conduit.
Trade: General/ Electrical/ HVAC/ Refrigeration/ IT Contractor
Trade: Union Electrician
I have only done one installation with neon, so I'm not an authority, but I do know that we installed the cables in aluminum rigid. I was told it was so the cables wouldn't induce on the raceway. I'm not sure if it was frequency problem or what. The frequency induction came up at Midway airport, where they had to install the feeds for the aircraft in aluminum because the source was running at 400 hertz and would have heated EMT or GRC. two cents
Union Electrician
Trade: Inside Wireman
In an aircraft they used aluminum conduit because weight is everything.
I don't know why you'd use it for something on the ground. It's a non ferrous metal, but still succeptable to magnetic induction(any conductor is) |
This was an install in the terminal for some kind of plug in FOR the airplanes. I don't know the details of what that might be ( perhaps a pilot out there could enlighten us). Anyways, think about what you said, magnetic induction. Aluminum rigid conduit is NOT magnetic. The conductors were copper, the raceway was aluminum. Sorry if I wasn't clear.
Union Electrician
Are you talking about what's reffered to as a Fox Cart? The device that plugs into a 30 or 60 amp 480 outlet and provides 400Hz to the plane, the machines themselves are made of steel by the way, and cabling is SO.
You were very clear GOOSE, perhaps I wasn't clear in my sentence that read; It's a non ferrous metal, but still succeptable to magnetic induction(any conductor is) |
Sparky, I'll be honest with you, I wasn't that involved with that install. I was working side by side with these guys and was simply curious why they were running aluminum. As for the amperage, who knows? I know they were running 2 1/2" pipe. I'm not saying that everything in the process was aluminum, just, the conduit, boxes, etc. Perhaps there is another reason, but I don't know it. You definitely sound like you know more about this. I was just throwing my two cents in.
That said, there must be a reason right? Thoughts? |
Union Electrician
Just curious Goose, what year are you?
I topped out three years ago.
Joe, I wanted to apologize. I realized what you were saying when You said that any conductor can induce a voltage, ferrous or otherwise. Duh, copper isn't ferrous either and it induces a current just fine. I was hung up on the magnetic part of it, and how aluminum isn't magnetic. That said, any thoughts on why aluminum pipe? Is there some kind of frequency hysteresis effect on steel conduit? I really do want to know. Again, I apologize for my ignorance. My head hangs with shame.
#14 | |
Union Electrician
Re: Neon TransformerQuote:
As far as aluminum conduit, I've only heard of it being used in corrosive environments and have never worked with it myself. |
No offense taken, Joe. I looked in the Chicago Code and found no requirement for aluminium, but it does require non metallic on the secondary (hope I'm reading this right). As for the high freq. power issue, I've been trolling engineering sites, aircraft sites, and others and have found nothing about alum. conduit. There is a lot of noise about magnetic flux and such, but apparently it's all regulated internally. I'll keep looking, but who knows, it might turn up something.
Old School Marine
Trade: Union Journeyman Electrician
I spent most of this past week working on a Verizon switch site. All the conduit in the switch room is aluminum. So yesterday I asked one of the engineers that came out to check on progress why they spec'd aluminum. He said there are two reasons. First of all, it provides a better ground than steel, he said if they made copper conduit that's what they would spec. Secondly (according to him) it cuts down on harmonic interference.
Thank you for that answer. Like I said, I've been trolling about in the high minded engineering sites and have found nothing relating to the high freq question specifically. I did find a section on one site called 'ask a rocket scientist', but I haven't heard back from them yet. Are the Verizon sites running high freq as well?
#18 | |
Old School Marine
| Are you psyched for transformer movie man! | Mike Finley | Off Topic (Non Trade) | 0 | 07-06-2007 12:06 AM |
| Calculating Transformer load | daiashi | Electrical | 5 | 02-05-2007 11:35 PM |
| Transformer needed... | gordfraser | Electrical | 4 | 01-07-2007 03:32 AM |
| Scott-Tee transformer connection | JAL | Electrical | 14 | 05-09-2006 10:34 PM |
