listen twice talk once!
Trade: electrician
Need Help Again
I was working in an apartment with radiant ceiling heat, and while cuting a hole for a new fan we hit a wire. Now the owner of the apartment was sure there was no wires where the fan was going but unforutunely she was wrong. So this wire is about 18 gauge solid and its embedded between .5 inch drywall and a .375 inch of plaster. And of course there's no heat now. How can this be repaired. She speaks of an electrician that has made repairs in the past but unfortunetly he is not with us anymore. Thanks AGAIN brian go wings!
Trade: General/ Electrical/ HVAC/ Refrigeration/ IT Contractor
Re: Need Help Again
Its probably not a wire... its your heating element. Without knowing what type it is I can't answer if it can be spliced or crimped but my first guess is no.
Just a suggestion... next time pull out your tone and probe set or spray a light water mist on the ceiling and turn on the heat so you can see where the elements are. |
Re: Need Help Again
There is no repair for that resistor wire. DO NOT try to fix it. It will be a hazard. The repair is new ceiling radiant heat, a baseboard heater, or highwall electric heat. You can't fix cut cable heat.
Trade: electrician
Re: Need Help Again
Ok I was afraid of that, The owner already has a cove heater ready to install. Thanks again for the info. bk wings 1 edmonton 0
Union Electrician
Trade: Inside Wireman
Re: Need Help Again
Tough break dude.
Though I'd like to ask what would happen if he did butt splice a peice of #12 between the cut wires? |
Re: Need Help Again
It would turn that piece of #12 into a heating element, and it would get MUCH hotter than the calibrated resistor wire of the actual ceiling heat cable.
#7 | |
Union Electrician
Re: Need Help AgainQuote:
I would think that where the repair was made you wouldn't get any heat, at most. |
Re: Need Help Again
Most heat cable is around 10 watts per square foot when installed. At 240 volts, that heat cable would have a resistance of about .016 ohms per inch of heat cable. (1000 watt of heat being about 300 lineal feet of cable). Each inch of cable is dissipating about .27 watts.
The resistance of #12 copper is only .00187 ohms per lineal foot. Or, .789 ohms per 300 lineal feet. Each inch of #12 will dissipate about 20 watts of heat. Now, I have not plugged in the "series resistor" calculation for a piece of low ohm #12 in with higher ohm ceiling heat cable, which will make it's effective heat dissipation less. I can tell you from days of foolishness past, that this repair section will get very hot. |
#9 | |
DGFVT
Trade: Electrical
You could repair the heating panel by using a non-insulated (preferably a high temp nickel alloy) crimp butt splice. The real problem is insulating the splice by replacing the insulation that the heating element was imbedded in originally. If it is not done right, there will be a hot spot where the splice was made. This is a VERY BIG liability problem. I would be very cautious because the electrician before you maybe did it this way. Always assume that they guy that was there before you most likely did it WRONG until proven otherwise. In commercial and industrial applications it would be possible to splice a heating element with no real problems because the splice location could maybe reinsulated. But for residential applications NO WAY. Be careful out there. |
#10 | |
I'm curious if the butt splice were of the correct material how long would it last and how much of a danger would it pose if you installed an AFCI breaker. The connection is between fire rated materials and the AFCI should trip if the connection starts to fail. Any Ideas? Last edited by DaveTap; 11-09-2006 at 05:05 PM. |
Union Electrician
Re: Need Help Again
in my book Watts = I squared x R. With a lower R you have lower watts.
Re: Need Help Again |
#13 | |
DGFVT
Trade: Electrical
Again No Way!!
Union Electrician
Re: Need Help Again
In the control box, where the heat trace recieves it's power, how are those splices made?
#15 | |
Union Electrician
Cabinetmaker
Re: Need Help Again
Has anyone just called the mfg,state the problem and ask them how to fix? Might just have a kit they use in mfg to repair such problems? This cant be the first time this problem has occurred.
JackM |
#18 |
Trade: electrician
Re: Need Help Again
Read this thread on raidient ceiling heat
