Error Corrector
Trade: Maintenance Manager
Need A Cheap Wire Tracer
I've got a string of porchlights to locate a loose or broken hot lead in. I've got continuity in the neutral and ground and don't want to open every fixture if I don't have to. Can anyone recommend a cheap tracer like one of these? (I doubt I'll use it for much more than this repair, so cheap and effective is what I need). http://www.amazon.com/Gardner-Bender...6743510&sr=1-2
http://www.amazon.com/Toner-Tracer-T...6743510&sr=1-3 |
Super B
Re: Need A Cheap Wire Tracer
Hmm, I'm no electrician but, if they are on a string, wouldn't they work up to the break in continuity? Anyway, I made a continuity tester from an old smoke detector and some sprinkler wire. So loud I can hear it from the back yard to the front yard, no problem.
#3 | |
Fentoozler
Re: Need A Cheap Wire TracerQuote:
You do realize there IS a N-G connection back at the main panel....
Steve
Trade: Remodeling and Custom Cabinets
I have a unit close to the Tone Tracer. Works good on DE-ENERGIZED ckts so turn off the breaker before use or it will be a paperweight! I picked up a screw in type receptacle from Lowes, unscrew light bulb, screw in receptacle and hang a short section of line cord off of it. Use clips off tone generator to feed tone via line cord.
This unit works well on phone/cat5-6 also. |
#5 | ||
Error Corrector
woodchuck2
Re: Need A Cheap Wire Tracer![]() ![]()
