Low Voltage Contractor
Trade: C-7
NEC Code
What type of service riser can be used if the service drop is not using the riser for support? It's point of attachment is an eyebolt. Main service size is 100A, single phase, 3-wire. Riser would come out of the panel 6', sweep 45 degrees to the left and go another 10'. It does not go through the roof and it would be fastened to the building every 24". Service conductors are #4 copper. Can I use PVC instead of IMC or rigid?
Electrical Contractor
Trade: Electrical
Re: NEC Code
PVC, IMC, EMT, RMC; all with conductors inside, ...or SEU cable. Take your pick.
Electrician
Trade: Electrician
Re: NEC Code
Depends on JHA, around here it would have to be imc, rmc, or aluminum....check your wire size too.
Trade: Electrical
Re: NEC Code
Friday, I do think you should make certain you point out your location.
Chicago has it's screwy rules about conduit only. The rest of the country is vastly more typical.
Trade: C-7
Re: NEC Code
It's in California and is zoned commercial. The building is not an MDU, and is owned by an association. I can't find anything in my 96 codebook, I'll call the bldg dept tomorrow to find out for sure.
Trade: Electrical
Re: NEC Code
What is an MDU?
You are still under NEC '96??? I didn't think anyone still was. The only restrictions will be local. Best to check.
Electrician
Trade: Electrician
Re: NEC Code
Speedy, you are correct. It seems alot of people have a problem about this areas specifics, but after doing both romex and pipe, I still prefer pipe.
Trade: electrical
Re: NEC Code
as stated above always check with JHA, no sense doing things twice. But I have never been told rigid was not enough
Trade: Electrical and mechanical contractor
Re: NEC Code
Check with AHJ, yeah I agree.
Thank you Mr. Inspector.
| Pull chain code. | K2 | Electrical | 12 | 04-10-2007 10:31 PM |
| 2 questions - one code, one structural | karma_carpentry | Decks & Fencing | 5 | 09-10-2006 02:55 PM |
| Code books?? | Luke's Dad | Construction | 15 | 06-25-2006 10:14 PM |
| Current Michigan energy code | frostbitten1 | Construction | 1 | 06-08-2006 10:18 PM |
| What building code book are you using? | K2 | Construction | 14 | 04-01-2006 09:52 AM |
