Multiple Door Chimes In A Large Home
Old 12-26-2008, 12:55 PM   #1
toolguyny's Avatar
Trade: handyman
Question
I built a large home for my parents, 6 years ago or so, its a ranch home, 3000 sq ft on the main level +.....altogether there is over 9000 sq ft of finished space... so there are 5 chime boxes, the system worked fine with the exception of one of the boxes up until last summer, I've replaced the transformer and it has gone again. I now am thinking I've missed something in the whole schematics of the system? I know I researched at the time I installed it and did as I found appropriate.... however is more voltage nessecary due to the amount of wiring maybe? If someone has done this and knows the precise needs, please lead me to the knowledge. Thanks
toolguyny is offline
Old 12-26-2008, 07:24 PM   #2
Sean
SLSTech's Avatar
Re: Multiple Door Chimes In A Large Home
I'm confused, everything worked fine for 5 years, or only 4 boxes worked fine up till a year ago? When the problems started was any work being done around the same time? Have you tested the continuity of the lines? Not that is should matter - but what are the lengths of each run from the chime to the door bells
SLSTech is offline
Old 12-26-2008, 07:27 PM   #3
Handle It!
MALCO.New.York's Avatar
Five chimes on One Transformer??? If so, then Yes, that VERY WELL may be the problem. You need to look at the Mili-Amp requirement versus the mA output of the TX.
Ultimate Wisdom---------
MALCO.New.York is offline
Old 12-26-2008, 10:28 PM   #4
mdshunk's Avatar
You're going to need a pretty stout transformer to run 5 chimes. Take an ohm measurement and do the math to find out what VA transformer you need to run the 5 connected chimes. My rules of thumb tell me you'd need at least 50va to run 5 "ordinary" NuTone 'ding-dong' type chimes; more if any of them are fancy. Just take an accurate ohm reading and go from there.
If you feel the transformer was properly sized, then check the system for shorts, ideally with a megger at 100 volts.
mdshunk is offline
Old 12-27-2008, 01:44 PM   #5
220/221's Avatar
Trade: electrician Phoenix AZ
Just add another transformer?
Just because it's within code doesn't make it safe.
Just because it's against code doesn't make it unsafe.
220/221 is offline
Old 12-27-2008, 02:44 PM   #6
acrwc10's Avatar
Trade: Electrical contractor/General contractor/ ICC certified electrical inspector
Could also be that the load is to much when the button is held in and it causes the transformer to overload and fail, you may want to think about using the type of chime that has a battery in it and is only triggered by the voltage from the button/transformer.
acrwc10 is offline
Old 12-28-2008, 09:56 AM   #7
Baltimore Electrician
JohnJ0906's Avatar
Trade: Electrician
Even in houses where we install 2 chimes, we have to change the transformer. As memory serves, the basic "ding-dong" chimes we use are 16v, 10 va.
John from Baltimore
"One Day at a Time"
All replies based on the 2008 NEC
Originally Posted by celtic
Deny Everything, Admit Nothing, Demand Proof
JohnJ0906 is offline
Old 12-28-2008, 11:04 AM   #8
mdshunk's Avatar
Can't do that on AC. When you parallel transformers, they'll fight each other.
mdshunk is offline
Old 12-28-2008, 11:08 AM   #9
Handle It!
But most chime Transformers are a DC output.
Old 12-28-2008, 11:47 AM   #10
acrwc10's Avatar
Go look again, Young grass hopper, they are AC to AC.
acrwc10 is offline
Old 12-28-2008, 11:51 AM   #11
acrwc10's Avatar
Although since it is "Alternating" I guess you are correct 1/2 the time.
acrwc10 is offline
Old 12-28-2008, 12:18 PM   #12
mdshunk's Avatar
I've never seen a DC chime transformer, but some chimes do come with a diode or 1/2 wave rectifier to install in the feed to that particular chime. Mostly the cheesy dollar store electronic chimes that play the top 50 big band hits.
mdshunk is offline
Old 12-28-2008, 09:38 PM   #13
Service & Repairs
Magnettica's Avatar
Trade: Electrician
I would like a chime that plays Rock N Roll All Nite And Party Everyday.
Magnettica is offline
Old 12-28-2008, 10:32 PM   #14
mdshunk's Avatar
I think ELK products has one you can load with your own MP3 files. They call it a "recordable voice module". I've used it for businesses to mix with the PA with an announcement as to which door is being buzzed. http://www.elkproducts.com/products/elk-124.htm
mdshunk is offline
Old 12-28-2008, 10:39 PM   #15
Service & Repairs
Magnettica's Avatar
Trade: Electrician
Thank you. I will definitely look into that.
Old 12-28-2008, 10:57 PM   #16
toolguyny's Avatar
Trade: handyman
Old 12-28-2008, 11:01 PM   #17
mdshunk's Avatar
OK.... I thank the few that attempted at a helpful post, but the system is already in place, I'm not interested in changing out all the chimes and spending 100's $$, there has to be a reasonable repair. 5 chime boxes... 4 of which worked for 5 - 6 years, I am going to disconnect the 5th box (that never did work) that is unnessessary due to the use of the space its in, its not utilized in a manner after the fact, where it even needs to have one. So there will be 4, the house is 88 feet long plus breezeway and garage ... so the structure is 132 feet long.... 2 of the chime boxes are within approx 8 - 10 feet of the furthest end of the house from the garage.... there are 5 door buttons.. which is irrelevent other than the overall footage of line taking current.... its about 110 feet from one end of the system to the other. I've replaced all the buttons, they had originally purchased the cheapest..... plastic things... and they literally disintigrated from sunlight and weather, the buttons are now all heavy duty metal buttons. Transformers as I am aware do not change currency from ac to dc but reduce line voltage. The chimes are simple front door/back door 1 and 2 note chimes.. no diodes. Thanks again for any HELPFUL responses.
Brother, you really need to check to see what the VA rating of the transformer is. You CANNOT run 4 chimes on a stock 10VA transformer.
mdshunk is offline
Old 12-28-2008, 11:03 PM   #18
toolguyny's Avatar
Trade: handyman
change the transformers? as in.. use a larger transsformer or replace (change) the transformer... I have "replaced" it twice this year.... I know something is not right for the need to replace it frequently for sure. They are a basic 1 note back door / 2 note front door chime.
Old 12-28-2008, 11:12 PM   #19
Handle It!
http://www.youtube.com/watch?v=Env5iMrBjws
Old 12-28-2008, 11:13 PM   #20
mdshunk's Avatar
I've said it twice, and I don't know any other way to say it. Now you're starting to piss me off. What size is the transformer you used? If you don't know, I can almost guarantee you that you used the wrong one. You also have not taken the ohm readings I asked about, or taken any megger readings. These are the basic troubleshooting things you need to do to narrow down your problem, if one exists. Jumping up and down and exclaiming that "something is not right" is not troubleshooting. What do you want? I can't come to your house and fix it. The ball is in your court.
mdshunk is offline
Home improvement show will575 Marketing & Sales 2 11-23-2008 02:05 PM
Illinois Mechanics Lien Forms and Instructions Ed the Roofer Business 4 02-23-2008 08:58 PM
Another reason to hate home depot nywoodwizard General Discussion 79 09-11-2007 10:46 PM
Chicago Home Repair License? Grumpy Contractor Licensing 24 09-15-2006 12:48 AM
Drug caches found in Home Depot vanities HandyAl General Discussion 1 06-14-2006 08:14 PM
