Trade: electrician
Mounting Conduit On Existing Flat Roof
Can any one recommend a product or method to run conduit on an existing flat roof? First time for everything! Thanks in advance for your input.
Trade: Electrical Contractor
Re: Mounting Conduit On Existing Flat Roof
Here is a web site and Picture that has what I hope you are looking for.
http://www.pipepier.com/ [IMG]file:///C:/DOCUME%7E1/bob/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG] |
Trade: electrician
That was fast! thank you.
Trade: electrician Phoenix AZ
One hole straps on short pieces of PVC.
Just because it's within code doesn't make it safe. Just because it's against code doesn't make it unsafe. |
I usually use one hole straps on chunks of 4x4 pressure treated lumber.
#6 | |
And I do electrical, too!
Re: Mounting Conduit On Existing Flat RoofQuote:
Same here. If it's a rubber-membrane roof, I also collect scraps to place between the 4x4 and the roof. Let the roofing crew know you'd like the scraps, and they'll most likely save some for you.
Site : the area or exact plot of ground on which anything is, has been, or is to be located. Sight : The power or faculty of seeing; perception of objects by use of the eyes; vision. Cite : To mention in support, proof, or confirmation; refer to as an example. |
Trade: electrician
Thanks for the input everyone, I think I am going to try the first product recommended. The cost is pretty low and I think it will look nice. I need to run 2" rigid (engineer's specs) for the air handlers on a private school, should be a money maker.
I don't know. The last time I looked in to those heavy rubber chunk things with the Kindorf groove buit-in, they were something like 8 bucks a piece. Not really what I'd call cheap, but maybe you don't need very many.
Trade: electrician
According to the website the "classic" is $2.70 each and the "deluxe" is $11.00 each. I need about 20 of them and I bid the job at almost $25,000, so it really isnt all that much in the scheme of things. This is an upscale school in an upscale community, so nothing but the best will do. This whole job is going to cost the customer almost $100 k.
Smart phone? Scan me!
Trade: Painting/Framing/Drywall
Isn't there going to have to be a temperature factor added to the calculation to keep the temp of the wire down? in the NEC 2008codebook table 310.15(B)(2)(c) provides temperature values that must be added to the expected ambient temperature.
Good luck though man! |
#11 | |
Trade: electrician
Will be someday soon! LOL glad you took that good, don't want to come across as a know it all, I am learning.. actually.. in school for electrical, we just went over that stuff the other day
Trade: electrician
Good for you and best of luck. The people that take things the wrong way on these forums dont hang around very long. And by the way we all are learning, thats why we are here.
Re: Mounting Conduit On Existing Flat Roof |
#15 | |
Celtic's #1 Fan
Trade: electrical
#16 | |
Service & Repairs
Trade: Electrician
Trade: General Contractor, Electrician
I learned those temperature correction factors for my electrical classification test a few months ago... Didn't realize it was so new in the NEC.
Anyway, those special blocks are cool, and not that expensive. I just do the pressure treated blocks. But you have to think, who the heck is going to go on the roof and see them? Not saying you should "cheat" them, but if they never see them, it will be kind of pointless... |
#18 |
#19 |
Service & Repairs
Trade: Electrician
Any time you see a thin black line to the left of a paragraph in the NEC it means that it's new or the wording has changed.
Although looking at it now the 2008 uses shaded sections for new or modified wording so the thin line might just be for new. |
#20 |
Read the last paragraph on page 1. That explains the lines, bullets and grey shading.
| Tying into existing roof | Milhaus | Framing | 9 | 11-06-2008 12:03 PM |
| 2 storey deck on top of flat roof | woodworkbykirk | Decks & Fencing | 5 | 10-27-2008 09:59 AM |
| roof mounting | Island Mike | Outdoor Lighting | 9 | 11-02-2007 03:20 PM |
| Framing of gable roof on existing house. | loogout1 | Framing | 25 | 06-05-2007 08:14 AM |
| Do You Need A New Roof ??? | Perfect Roofing | Roofing | 0 | 02-10-2005 02:46 AM |
