tags, as close as possible to the opening tag. Creation Date: 12/20/2017 -->
Meter Pan And Outside Disconnect
Old 04-26-2009, 02:49 PM   #1
rustyjames's Avatar
Rewards Points: 1,532
I seem to recall where someone here mounted a service disconnect next to a meter pan and the inspector shot it down because it wasn't stacked. I'm getting ready to upgrade my service and want to mount the pan/disconnect side by side. Should I call the inspector and ask? I don't want him to think I'm a buffoon. TIA
rustyjames is online now
Old 04-26-2009, 03:22 PM   #2
petey_c's Avatar
Trade: Electrical Contractor
Rewards Points: 20
Re: Meter Pan And Outside Disconnect
Is the panel more than 5' from the meter? Avoid the buffoon issue all together and get a meter main....
petey_c is offline
Old 04-26-2009, 03:24 PM   #3
ampman
ampman's Avatar
Trade: providing pathways for electrons and protons
Rewards Points: 516
here we can go side by side or stacked only thing is POCO has height restrictions on meter
ampman is offline
Old 04-26-2009, 04:22 PM   #4
rustyjames's Avatar
Thanks everyone,
petey, I bought a top of the line meter/main and the power company said I couldn't use it, had to use their pan (it was like they stuck a stake thru my heart). My beaker panel is in the basement about 10' away, hence the outside disconnect.
It would be much easier for me to stack them but It'll look hideous, complicate my finishing details and the breaker will, in my opinion, be too low.
I'd hate to have everything assembled for inspection and have to wind up reworking it.
Old 04-26-2009, 04:26 PM   #5
rustyjames's Avatar
Yes, I'm limited on the position of meter, if I stack them the breaker switch will be pretty low.
Old 04-26-2009, 09:33 PM   #6
Head Grunt
woodchuck2's Avatar
Rewards Points: 2,196
X2 or they can go back to back. Here with all the snow fall stacking them will often leave your dis-connect below the snow line. This past winter i couldnt even see my dis-connect, it was buried in the snow.
woodchuck2 is offline
Old 04-26-2009, 11:11 PM   #7
kbsparky's Avatar
Trade: Electrical
Rewards Points: 150
Stacking them usually results in the bottom knockouts of the meter box rendered inaccessible. Hence the red flag.
Which POCO are you using?
kbsparky is offline
Old 04-26-2009, 11:16 PM   #8
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 10,400
Originally Posted by kbsparky View Post
Stacking them usually results in the bottom knockouts of the meter box rendered inaccessible. Hence the red flag.....
Why would that be a problem?
Why is there not a Flat Mars Society?.
480sparky is offline
Old 04-27-2009, 07:41 AM   #9
Head Grunt
woodchuck2's Avatar
I am curious of that too? Its the bottom knockout that i use to stack, if the meter socket has two off centered knockouts then i cut one in the center for my advantage. My inspector has no problems with cutting in your own knockouts either if you do then neatly and properly, not all panels/pans have them where you want/need them.
Old 04-27-2009, 08:06 AM   #10
Fentoozler
Celtic's Avatar
Rewards Points: 2,000
James....I had a similar situation in Northern NJ....the EI will allow me to mount the pan outside, then run about 5' outside and another 8' inside to the MCB panel ~ IF I use RMC.
My suggestion:
Speak to the EI before proceeding.
Celtic is offline
Old 04-27-2009, 10:17 AM   #11
rustyjames's Avatar
kbs, thanks-
PSE&G
Old 04-27-2009, 10:23 AM   #12
rustyjames's Avatar
My suggestion:
Celtic, thanks, that's what I'm going to do.
Old 04-27-2009, 12:08 PM   #13
Fentoozler
Celtic's Avatar
Originally Posted by rustyjames View Post
PSE&G
James...do you have a copy of the "green book" from PSE&G?
Celtic is offline
Old 04-27-2009, 01:25 PM   #14
rustyjames's Avatar
Celtic, yes, I have a PDF of it. I looked through it awhile ago but I don't seem to recall anything related to my question. I'll check it again. I emailed the inspector, waiting for his reply.
Old 04-27-2009, 04:23 PM   #15
Fentoozler
Celtic's Avatar
Celtic, yes, I have a PDF of it.... I'll check it again. I emailed the inspector, waiting for his reply.
It's not in there ...but at least now you have something to do while you wait
Seriously though....I was just curious if you had it ~ I would have sent you a link for future reference on other scenarios.
Celtic is offline
Old 04-27-2009, 04:36 PM   #16
rustyjames's Avatar
Cel, thanks again, I appreciate it . You're right; I needed something to do today anyway.
Old 04-27-2009, 05:03 PM   #17
Certified Remodeler
silvertree's Avatar
Trade: Kitchen bath remodeler
So help me God, I thought the thread was called
Peter Pan and outside disconnect?
I gotta get new reading glasses.
silvertree is offline
Old 04-27-2009, 05:10 PM   #18
Fentoozler
Celtic's Avatar
"That ain't what I'm talkin about you jive azz honkey MF".
Celtic is offline
Old 04-27-2009, 05:19 PM   #19
480sparky's Avatar
Old 04-27-2009, 05:48 PM   #20
Certified Remodeler
silvertree's Avatar
Electricians never disappoint
