MC Support
Old 10-17-2006, 07:08 AM   #1
Larry007's Avatar
Trade: Electrical Contractor
MC Support
When did they make the code change to MC cable? I could have swore it was 4'6", but it is now 6'. I am not in the field as much as I use to be, so when asked I said 4'6". I stand corrected....
Larry007 is offline
Old 10-17-2006, 05:24 PM   #2
mdshunk's Avatar
Re: MC Support
I can only remember 6' (NEC 330.30) for type MC cable.
Type AC cable is, and was as far back as I know, to be supported at 4-1/2'. Perhaps you got the two mixed up, since they both have the same general appearance? Or perhaps you were working with type AC before? Perhaps the "old timer" that taught you used the 4-1/2' AC rule for MC also?
In any event, it's of little consequence, since if you did it according to your memory, you'd have done better than code.
mdshunk is offline
Old 10-26-2006, 11:36 PM   #3
onewaywatt's Avatar
Trade: electrician
Re: MC Support
i would have bet that the supports for ac is three feet apart and twelve inches from boxes.
onewaywatt is offline
Old 10-26-2006, 11:40 PM   #4
mdshunk's Avatar
Re: MC Support
Twelve inches from the box is for secured.
Here's the code sections:
320.30 Securing and Supporting.
Type AC cable shall be
supported and secured by staples, cable ties, straps, hangers,
or similar fittings, designed and installed so as not to
damage the cable, at intervals not exceeding 1.4 m (4 12 ft)
and within 300 mm (12 in.) of every outlet box, junction
box, cabinet, or fitting.
330.30 Securing and Supporting.
Type MC cable shall be
or similar fittings or other approved means, designed
and installed so as not to damage the cable, at intervals not
exceeding 1.8 m (6 ft). Cables containing four or fewer
conductors sized no larger than 10 AWG shall be secured
within 300 mm (12 in.) of every box, cabinet, fitting, or
other cable termination.
mdshunk is offline
Old 10-27-2006, 06:14 AM   #5
ATS's Avatar
Trade: Electrical and mechanical contractor
Re: MC Support
Supporting mc and bx in commercial buildings can be soo dang time consuming and seemingly unnecessary, probably why so many times it is just strung about. It's nice though when it's at least on the top side of the framing members and not just lying on top of the ceiling tiles.
ATS is offline
Old 10-27-2006, 04:46 PM   #6
mdshunk's Avatar
Re: MC Support
When I don't have bar joists above the ceiling to rope the MC cable through, I use these puppies on the ceiling support wires: http://www.erico.com/products/CADDYc...uitHangers.asp
mdshunk is offline
Old 10-27-2006, 08:03 PM   #7
ATS's Avatar
Re: MC Support
Yep, the good ole batwings, I don't think we're allowed to do that anymore. Use the ceiling support wires that is.
ATS is offline
Old 10-27-2006, 09:03 PM   #8
mdshunk's Avatar
Re: MC Support
It kinda depends. If it's a fire rated drop ceiling, you need to run your own drop wires. If it's a ceiling drop wire that exists, but not necessary to hold the ceiling up, then you can use it. Otherwise, you're running your own drop wire.
mdshunk is offline
How Do I Support A Box... PSEG62 Electrical 5 01-02-2007 01:20 AM
Roof support C.C.R. General Discussion 3 07-24-2006 10:09 AM
Cabinet support EDT Finish Carpentry 4 05-04-2006 09:42 PM
Support Post banctecbobn Construction 4 04-24-2006 10:19 PM
Support columns MinConst Construction 12 03-20-2006 09:22 PM
