Low Voltage Lighting...
Old 10-16-2006, 02:20 PM   #1
wraiths's Avatar
Trade: Electrical Contractor
Hello all, Need some answers about low voltage lighting from all the experts out there? I've only used lv lighting a time or too but am in the middle of a remodel an the owners have decided to install more lv lights. My questions start with where do you normally install your transformers in the attic, the basement, I was going to install these in the attic but was concerned about the heat up there what do you think.The times that I have used lv the houses had a mechanical room where the tranformers were located this home doesnt have one. Also I think if you go over 100va you can no longer wire them as class 2 circuits. So do you fuse the secondary side? Any help is greatly appreciated. Thanks
wraiths is offline
Old 10-16-2006, 11:23 PM   #2
mdshunk's Avatar
Re: Low Voltage Lighting...
The indoor low voltage lighting transfomers have their own fuse or breaker.
I install them where ever I can. In the basement, laying on top of the cupboards, in the garage, mechanical room, etc. I'd suggest you look at the proposed manufacturer's spec sheet with regard to operating ambient before you install one in the attic, however.
mdshunk is offline
Old 10-17-2006, 09:35 PM   #3
wraiths's Avatar
Thanks MD for the reply. There supposed to be coming in thurs. so I'll check the manufacturer specs . Thanks again....
wraiths is offline
High Voltage vs Low Voltage Lights robertc65 Outdoor Lighting 16 04-04-2011 06:26 AM
Area lighting for Pipe Guy mdshunk Electrical 5 01-26-2009 02:25 PM
Can I provide flood lighting via Low Voltage robertc65 Outdoor Lighting 8 11-06-2007 10:42 AM
Residential General Lighting Circuits toastermaker Electrical 11 02-26-2006 01:04 AM
Landscape Lighting Association LandscapePro Landscaping 20 01-16-2006 11:23 PM
